Hi Guys,
I was fiddling around with karaf console and checked the Hue binding if it was running normal (at that moment i had high cpu load, due to Visual studio core…). Now, my system runs perfect with CPU use around 20-30% and a load around 0.4 - 0.6. But i saw a lot of messages comming from the hue binding.
(i’m running Openhab 2.5 stable on a Raspberry Pi3b by the way)
I’m curious if it’s normal behaviour or if there is something wrong with openhab. These are the messages I get every 0.5 second when I change the log for the hue binding to DEBUG or TRACE:
07:40:52.960 [DEBUG] [al.discovery.HueLightDiscoveryService] - discovered unsupported sensor of type ‘Daylight’ and model ‘PHDL00’ with id 1
07:40:52.964 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘8’ added.
07:40:52.969 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘12’ added.
07:40:52.974 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘21’ added.
07:40:52.980 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘23’ added.
07:40:52.985 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘33’ added.
07:40:52.991 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘34’ added.
07:40:52.996 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘40’ added.
07:40:53.001 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘41’ added.
07:40:53.006 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘47’ added.
07:40:53.011 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘48’ added.
07:40:53.016 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘49’ added.
07:40:53.020 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘50’ added.
07:40:53.025 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘51’ added.
07:40:53.050 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘52’ added.
07:40:53.054 [DEBUG] [hue.internal.handler.HueBridgeHandler] - Hue sensor ‘69’ added.
Just curious if it’s normal behaviour
