Hi There,
after installing the latest openHAB build i get a regular error from the homematic binding. Can somone confirm that this is an error or that only i have problems.
2018-01-11 09:36:25.224 [ERROR] [ematic.handler.HomematicThingHandler] - Can't convert BOOL value '0' with OnOffTypeConverter for 'LEQxxxxx:0#LOWBAT'
org.openhab.binding.homematic.internal.converter.ConverterTypeException: Can't convert BOOL value '0' with OnOffTypeConverter for 'LEQxxxxx:0#LOWBAT'
at org.openhab.binding.homematic.internal.converter.type.AbstractTypeConverter.convertFromBinding(AbstractTypeConverter.java:114) ~[214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.handler.HomematicThingHandler.updateChannelState(HomematicThingHandler.java:250) ~[214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.handler.HomematicThingHandler.updateDatapointState(HomematicThingHandler.java:226) ~[214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.handler.HomematicBridgeHandler.onStateUpdated(HomematicBridgeHandler.java:233) ~[214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.lambda$0(AbstractHomematicGateway.java:615) ~[214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:61) [214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.eventReceived(AbstractHomematicGateway.java:612) [214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleEvent(RpcResponseHandler.java:94) [214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleMethodCall(RpcResponseHandler.java:47) [214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.server.RpcResponseHandler.handleMethodCall(RpcResponseHandler.java:64) [214:org.openhab.binding.homematic:2.3.0.201801092213]
at org.openhab.binding.homematic.internal.communicator.server.BinRpcResponseHandler.run(BinRpcResponseHandler.java:46) [214:org.openhab.binding.homematic:2.3.0.201801092213]
