That didn’t take long. Both bridges went offline. When they came back, they were effectively static. Changes on the app don’t show up on OH. Commands don’t send. Nada. I’m worried we have some sort of exhaustion issue happening. Possibly related to the delay, not sure why. You may need to purge the queue out when the devices comes online to make sure there isn’t anything hanging out that is stale and old.
EDIT: Let me add some extra context I just noticed. My zwave motion sensors and rules could be causing this condition to happen. Effecitvely the rule says “if there has been no motion for X seconds, and any lights are on in that room, turn them off”. That runs via cron every second. Because the bridge was offline for some period of time, it looks like the status of the devices never updated so it kept trying to fire that rule off which would cause 4-5 lights to try to shut off every second. I’m updating my rules to not do this kind of flood anymore, but it semi-confirms that the queue could be causing the issue.
2020-11-21 16:27:01.578 [DEBUG] [n.internal.handler.LeapBridgeHandler] - End of input stream detected
2020-11-21 16:27:01.578 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 2
2020-11-21 16:27:01.579 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 3
2020-11-21 16:27:01.583 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 4
2020-11-21 16:27:01.583 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 5
2020-11-21 16:27:01.583 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 6
2020-11-21 16:27:01.584 [DEBUG] [n.internal.handler.LeapBridgeHandler] - Message reader thread exiting
2020-11-21 16:27:01.584 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 9
2020-11-21 16:27:01.584 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 11
2020-11-21 16:27:01.584 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 7
2020-11-21 16:27:01.584 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 10
2020-11-21 16:27:01.585 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 1
2020-11-21 16:27:01.585 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 8
2020-11-21 16:42:32.753 [DEBUG] [n.internal.handler.LeapBridgeHandler] - End of input stream detected
2020-11-21 16:42:32.754 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 10
2020-11-21 16:42:32.756 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 11
2020-11-21 16:42:32.764 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 40
2020-11-21 16:42:32.764 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 39
2020-11-21 16:42:32.766 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 37
2020-11-21 16:42:32.767 [DEBUG] [n.internal.handler.LeapBridgeHandler] - Message reader thread exiting
2020-11-21 16:42:32.767 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 16
2020-11-21 16:42:32.767 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 34
2020-11-21 16:42:32.767 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 35
2020-11-21 16:42:32.767 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 41
2020-11-21 17:59:50.941 [WARN ] [n.internal.handler.LeapBridgeHandler] - Communication error, will try to reconnect. Error: Connection or outbound has closed
2020-11-21 17:59:50.941 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 2
2020-11-21 17:59:50.942 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 3
2020-11-21 17:59:50.942 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 4
2020-11-21 17:59:50.942 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 5
2020-11-21 17:59:50.943 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 6
2020-11-21 17:59:50.943 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 17:59:50.956 [DEBUG] [n.internal.handler.LeapBridgeHandler] - Attempting to reconnect to the bridge
2020-11-21 17:59:50.956 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 9
2020-11-21 17:59:50.956 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 10
2020-11-21 17:59:50.956 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 11
2020-11-21 17:59:50.956 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 7
2020-11-21 17:59:50.956 [DEBUG] [n.internal.handler.LeapBridgeHandler] - Disconnecting
2020-11-21 17:59:50.957 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 8
2020-11-21 17:59:50.957 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 1
2020-11-21 17:59:50.957 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 2
2020-11-21 17:59:50.957 [DEBUG] [n.internal.handler.LeapBridgeHandler] - Opening SSL connection to 10.255.0.196:8081
2020-11-21 17:59:50.958 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 4
2020-11-21 17:59:50.958 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 5
2020-11-21 17:59:50.958 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 6
2020-11-21 17:59:50.958 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 9
2020-11-21 17:59:50.958 [DEBUG] [utron.internal.handler.LutronHandler] - Bridge status changed to OFFLINE for lutron device handler 10
Eventually they come back online and it looks like they try to send commands continously.
2020-11-21 18:01:38.050 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/44/commandprocessor"},"Body": {"Command": {"CommandType": "Go
ToDimmedLevel","DimmedLevelParameters": {"Level": 0, "FadeTime": "00:00:01", "DelayTime": "00:00:00"}}}}
2020-11-21 18:01:38.150 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/23/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:38.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:01:38.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/33/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:38.951 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:01:38.953 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:01:38.953 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/3/commandprocessor"},"Body": {"Command": {"CommandType": "GoT
oFanSpeed","FanSpeedParameters": {"FanSpeed": "Low"}}}}
2020-11-21 18:01:38.955 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:01:39.049 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/44/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:39.150 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/23/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:39.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:01:39.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/33/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:39.950 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:01:39.952 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:01:39.952 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/3/commandprocessor"},"Body": {"Command": {"CommandType": "GoT
2020-11-21 18:01:39.953 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:01:40.050 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/44/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:40.150 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/23/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:40.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:01:40.949 [TRACE] [n.internal.handler.LeapBridgeHandler] - Sending command {"CommuniqueType": "CreateRequest","Header": {"Url": "/zone/33/commandprocessor"},"Body": {"Command": {"CommandType": "Go
2020-11-21 18:01:40.950 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
They come back online but seem to start queueing up until finally all the log shows is…
2020-11-21 18:37:05.173 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:06.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:06.171 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:06.173 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:06.174 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:07.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:07.167 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:07.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:07.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:08.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:08.166 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:08.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:08.169 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:09.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:09.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:09.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:09.171 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:10.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:10.167 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:10.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:10.169 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:11.166 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:11.167 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:11.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:11.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:12.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:12.166 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:12.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:12.169 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:13.165 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:13.168 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:13.169 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:13.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:14.166 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:14.167 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
2020-11-21 18:37:14.169 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,4,1,25
2020-11-21 18:37:14.170 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,31,1,0,0.25
2020-11-21 18:37:15.166 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,45,1,0,0.25
2020-11-21 18:37:15.167 [TRACE] [n.internal.handler.LeapBridgeHandler] - Received request to send Lutron command: #OUTPUT,57,1,0,0.25
