I only had the ops4j.pax prompt moving from an OpenHABian M3 install to M3.
Would it be possible to coordinate OpenHABian with OH releases? It appears to me you are needing to scurry around after a release to fix OpenHABian.
1. Dummy Item could not be found in my rules here the sample:
// my rule points to a LICHT_OUT_DIMM_OLD wich will hold the last state
var DimmerItem DimmOldValueSaveItem = LICHT_OUT_DIMM_OLD;
// default.item worked 2.x M1/M2/M3
Dimmer LICHT_OUT_DIMM_OLD "Old Values Store"
// have to change it to a dummy channel!
// default.item M4
Dimmer LICHT_OUT_DIMM_OLD "Old Values Store" { channel=""}
2. HueEmulation is not working since m2?
Here the Log:
16:45:43.746 [INFO ] [.io.hueemulation.internal.ConfigStore] - Hue Emulation pairing disabled
16:45:45.179 [WARN ] [mulation.internal.HueEmulationService] - The UPnP Server service has not been started!
16:45:45.183 [INFO ] [mulation.internal.HueEmulationService] - Hue Emulation service available under /api
16:45:45.628 [INFO ] [hueemulation.internal.upnp.UpnpServer] - Hue Emulation UPNP server started on 127.0.0.1:8080
Not yet able to test this but should be the fix. I really need to find time to make the necessary changes to bin/update so that this process can be called externallyâŠ
