yep, goog shot:+1:
for whatever reasons the jvm get local ip tries to resolve the hostname locally, which usually results in 127.0.0.1; so you replaced this with the correct ip
However, I’m looking for more stable way by processing the local interface list and getting the ip from there.
I’ve rewritten the initialization code and it runs on my system. However, I’m not able to produce a build
- my 2.4 setup is screwed, so I did a re-install
- the fresh install fails executing the Eclipse startup tasks
- I restored my 2.3 environment and was able to do a successful debug
- now the mvn build reports errors “Illegal character in path at index 55: http://download.eclipse.org/smarthome/updates-release/${esh.releaseVersion}”
it seems that something is wrong with the OH build environment.
Disappointing, but first I need to get the dev environment running again - not the first time ![]()
