fyi: refactoring started
@bknow @Ronald_Schulz @JuergenCarstensen ok, find a new build for OH3 here
https://github.com/markus7017/myfiles/blob/master/magentatv/org.openhab.binding.magentatv-3.1.0-SNAPSHOT.jar?raw=true
please test and provide feedback
include TRACE log
hello markus, I put the jar to the addons folder but it wont install, even with a full reboot it get not recognized.
the log says:
2021-03-01 21:44:29.817 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.magentatv-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.magentatv [294]
run
feature:install openhab-transport-upnp
on the OH console
nope, doesnt install
same log entry
there must be more in the log, what are the lines aftereards?
I did a complete rebuild for both releases, please check, make sire you habe the version in the UI deinstalled, check with bundle:list that there is only 1 instance
Good morning Markus, thank you for your effort, unfortunately I get this error too.
2021-03-02 07:17:08.255 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.magentatv-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.magentatv [291]
I am running UPNP
Thank you for your help
Update : `2021-03-02 08:58:01.733 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.magentatv-3.1.0-SNAPSHOT.jar
Unresolved requirement: Import-Package: org.apache.commons.net.util; version=ā[3.7.0,4.0.0)ā
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]`
how I can get these extended logs? I only see the short one.
Hello Ronald, when the system starts up you can see it in the āFront tailā log.
looks like the same messages and some missingpackages to import?
2021-03-02 19:15:25.507 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.magentatv-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.magentatv [297]
Unresolved requirement: Import-Package: org.apache.commons.net.util; version="[3.7.0,4.0.0)"
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [bundleFile:3.6.4]
ok, thatās the info I was looking for
it seems that removed Apache Commons, I need to check how to replace that dependency with Java native code
I thank you. Is working. Iām still testing them all, but it already looks very good. ![]()
I updated 2.5.13-SNAPSHOT and 3.1-SNAPSHOT so both versions are in sync
installation and login are working
THANK YOU ![]()
now Iāll setup and play with the OH3 widget possibilities and the interaction with my (older) Samsung TV.
btw. Thanks also for the Carnet binding - so I could combine my aWattar flexible price solution with the Keba Wallbox with my audi etron and only the lag of connectivity to audi is sometimes a problem (but this the fault of audi network)
let us know about your results
I could also make templates available in my myfiles repo ro share with other users
And yes, Audi has a strange understanding of Smart car services, esp when they start charging for unstable servicesš¤Ŗ
Yes, this would be great - Iām quite new in OH and already learend its better to back up requlary (after loosing 2 weeks setup & configuration). So every inspiration would be perfect.
fyi: openhabian / openhab has an integrated backup/restore feature for the config
Yes but I installed pixel, Zigbee2mqtt, mosquitto, Homematic IP, Grafana and the influxDB with some browser autostart and (7inch) Display on/off switches
So I learned how a full SD Image is working.
