Hy @all,
its been a while. I recently had to re-install my openhab instance. But after that, MagentaTV binding is not working anymore. I tried it with the Backuped UserId from my old things config but this is not working. So i did the following:
- Removed everything related to MAgentTV from OH (things, items, sitemap entries)
- Stoped OH
- Cleared cache
- Downloaded DEV Build and moved it to the addons folder
Also iāve checked if Smartcontrol is enabled - its enabled.
Binding was recognized by OH so i tried to add a new thing. Unfortunately after entering my Credentials the UserID is not generated. See Trace log here:
11:16:07.200 [DEBUG] [tatv.internal.MagentaTVHandlerFactory] - Initialize network access
11:16:07.312 [DEBUG] [scovery.MagentaTVDiscoveryParticipant] - Discovered an MagentaTV Media Receiver Receiver Wohnzimmer, UDN: 6d308421-631a-5767-ae09-AC6FBB72B244, Model MR401B_ACN.R01A5
11:16:07.319 [DEBUG] [scovery.MagentaTVDiscoveryParticipant] - Create Thing for device Receiver Wohnzimmer with UDN 6d308421-631a-5767-ae09-AC6FBB72B244, ModelMR401B_ACN
11:16:07.327 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' to inbox.
11:16:07.328 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' has been added.
11:16:08.574 [WARN ] [.apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
11:16:08.592 [WARN ] [.apache.cxf.jaxrs.utils.ResourceUtils] - No resource methods have been found for resource class javax.ws.rs.core.Response
11:16:08.632 [DEBUG] [ternal.network.MagentaTVNotifyServlet] - Servlet started at /magentatv/notify
11:16:08.643 [DEBUG] [tatv.internal.MagentaTVHandlerFactory] - NotifyServlet started
11:16:34.284 [DEBUG] [re.model.rule.jvmmodel.RulesRefresher] - Thing "magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244" added => rules are going to be refreshed
11:16:34.287 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' has been removed.
11:16:34.305 [DEBUG] [tatv.internal.MagentaTVHandlerFactory] - Create thing type magentatv:receiver
11:16:34.350 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' changed from UNINITIALIZED to INITIALIZING
11:16:34.374 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' changed from INITIALIZING to UNKNOWN
11:16:39.391 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Credentials missing or invalid! Fill credentials into thing configuration or generate UID on the openHAB console - see README
11:17:33.591 [DEBUG] [atv.internal.handler.MagentaTVHandler] - Receiver Wohnzimmer: Thing config updated, re-initialize
11:17:33.609 [TRACE] [ntatv.internal.MagentaTVDeviceManager] - Lookup device, uniqueId=7C358A00F54D7CCBB0309111DF1AA1D7
11:17:33.615 [DEBUG] [ntatv.internal.MagentaTVDeviceManager] - Device with id 7C358A00F54D7CCBB0309111DF1AA1D7 was not found in table (0 entries
11:17:33.642 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' changed from OFFLINE (CONFIGURATION_ERROR): Credentials missing or invalid! Fill credentials into thing configuration or generate UID on the openHAB console - see README to UNKNOWN
11:17:38.644 [DEBUG] [atv.internal.handler.MagentaTVHandler] - Receiver Wohnzimmer: Login with account *SensitiveDataCovered*@t-online.de
11:17:38.649 [DEBUG] [ntatv.internal.network.MagentaTVOAuth] - Authenticate with account *SensitiveDataCovered*@t-online.de
11:17:38.655 [DEBUG] [ntatv.internal.network.MagentaTVOAuth] - OAuth: HTTP Request
HTTP GET https://slbedmfk11100.prod.sngtv.t-online.de:33428/EDS/JSON/Login?UserID=Guest
Data=<none>
11:17:38.661 [TRACE] [ntatv.internal.network.MagentaTVOAuth] -
Headers=Accept-Encoding: gzip
User-Agent: Jetty/9.4.20.v20190813
Accept: */*
Cache-Control: no-cache
Host: slbedmfk11100.prod.sngtv.t-online.de
Accept-Language: en-US,en;q=0.9,de;q=0.8
Cookies=[]
11:17:39.046 [DEBUG] [ntatv.internal.network.MagentaTVOAuth] - OAuth: HTTP Response
Status=200 OK
Data={"enctytoken":"D34DC43E562577AF414E9314602A60F7","encryptiontype":"0002","platformcode":"0200","epgurl":"http://appepmfk10009.prod.sngtv.t-online.de:33220","version":"MEM V200R008C18SPC200B043","epghttpsurl":"https://appepmfk10009.prod.sngtv.t-online.de:33227","rootCerAddr":"http://appepmfk10009.prod.sngtv.t-online.de:33220/EPG/CA/iptv_ca.der","upgAddr4IPTV":"https://slbedifk11100.prod.sngtv.t-online.de:33428/EDS/jsp/upgrade.jsp","upgAddr4OTT":"https://slbedmfk11100.prod.sngtv.t-online.de:33428/EDS/jsp/upgrade.jsp,https://slbedmfk11100.prod.sngtv.t-online.de:33428/EDS/jsp/upgrade.jsp","EPGDomainNameList":[{"key":"2","value":"appepmfk10009.prod.sngtv.t-online.de"},{"key":"3","value":"80.157.246.61"},{"key":"4","value":"80.157.246.61"},{"key":"5","value":"80.157.246.61"},{"key":"6","value":"80.157.246.61"},{"key":"7","value":"80.157.246.61"}],"sam3Para":[{"key":"SAM3ServiceURL","value":"https://accounts.login.idm.telekom.com"},{"key":"OAuthScope","value":"ngtvepg"}]}
11:17:39.050 [TRACE] [ntatv.internal.network.MagentaTVOAuth] -
Headers=Server: openresty/1.0.0.2
Date: Thu, 22 Apr 2021 09:17:39 GMT
Content-Type: text/plain;charset=UTF-8
Transfer-Encoding: chunked
Connection: keep-alive
Keep-Alive: timeout=3600, max=767
X-Frame-Options: SAMEORIGIN
Access-Control-Allow-Methods: POST,OPTIONS,GET,*
Access-Control-Allow-Credentials: true
Access-Control-Allow-Headers: accept, origin, content-type,Authorization,authorization,X_CSRFToken,If-None-Match,*
Set-Cookie: JSESSIONID=H7B81190EC550D6ED5A86097B6939BCB2C613941B7C3B1E625442F69711223BC97895A950996F017F31CE301BB55D477E; Path=/EPG/; Secure; HttpOnly
Content-Encoding: gzip
Vary: accept-encoding
X-XSS-Protection: 1; mode=block
X-Download-Options: nosniff
X-Content-Type-Options: nosniff
11:17:39.078 [DEBUG] [ntatv.internal.network.MagentaTVOAuth] - OAuth: epghttpsurl = https://appepmfk10009.prod.sngtv.t-online.de:33227/EPG
11:17:39.081 [TRACE] [ntatv.internal.network.MagentaTVOAuth] - sam3Para.SAM3ServiceURL = https://accounts.login.idm.telekom.com
11:17:39.087 [TRACE] [ntatv.internal.network.MagentaTVOAuth] - sam3Para.OAuthScope = ngtvepg
11:17:39.093 [DEBUG] [ntatv.internal.network.MagentaTVOAuth] - OAuth: HTTP Request
HTTP POST https://accounts.login.idm.telekom.com/oauth2/tokens
Data=password=qQ0klnxUfa6cFqrs&scope=ngtvepg+offline_access&grant_type=password&username=*SensitiveDataCovered*%40t-online.de&x_telekom.access_token.format=CompactToken&x_telekom.access_token.encoding=text%2Fbase64&client_id=10LIVESAM30000004901NGTVWEB0000000000000
11:17:39.095 [TRACE] [ntatv.internal.network.MagentaTVOAuth] -
Accept: */*
Content-Length: 249
Cookies=[]
11:17:39.315 [INFO ] [ntatv.internal.network.MagentaTVOAuth] - HTTP reqaest failed for URL https://accounts.login.idm.telekom.com/oauth2/tokens
java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:685) ~[bundleFile:9.4.20.v20190813]
at org.openhab.binding.magentatv.internal.network.MagentaTVOAuth.httpRequest(MagentaTVOAuth.java:236) [bundleFile:?]
at org.openhab.binding.magentatv.internal.network.MagentaTVOAuth.getUserId(MagentaTVOAuth.java:145) [bundleFile:?]
at org.openhab.binding.magentatv.internal.handler.MagentaTVControl.getUserId(MagentaTVControl.java:94) [bundleFile:?]
at org.openhab.binding.magentatv.internal.handler.MagentaTVHandler.getUserId(MagentaTVHandler.java:351) [bundleFile:?]
at org.openhab.binding.magentatv.internal.handler.MagentaTVHandler.initializeThing(MagentaTVHandler.java:169) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:163) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:198) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:190) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:444) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:390) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:316) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseFields(HttpParser.java:1139) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1498) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:135) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:154) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) ~[?:?]
... 1 more
11:17:39.343 [DEBUG] [atv.internal.handler.MagentaTVHandler] - Receiver Wohnzimmer: org.openhab.binding.magentatv.internal.MagentaTVException: HTTP reqaest failed for URL https://accounts.login.idm.telekom.com/oauth2/tokens (class java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header)
11:17:39.346 [DEBUG] [atv.internal.handler.MagentaTVHandler] - Receiver Wohnzimmer: Communication Error - org.openhab.binding.magentatv.internal.MagentaTVException: HTTP reqaest failed for URL https://accounts.login.idm.telekom.com/oauth2/tokens (class java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header), switch Thing offline
11:17:39.365 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'magentatv:receiver:6d308421-631a-5767-ae09-AC6FBB72B244' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): org.openhab.binding.magentatv.internal.MagentaTVException: HTTP reqaest failed for URL https://accounts.login.idm.telekom.com/oauth2/tokens (class java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header)
May i kindly ask you to check whats wrong here? If you need other Logs/Infos dont hesitate to reach out to me.
