Magic Binding [4.0.0.0;5.0.0.0)
The Magic Binding is a virtual device binding which provides different Things, Channels and supporting functionality for easy UI testing.
You can find the source code in the openhab-core repository.
There is also a Magic Binding for openHAB 3 in the Marketplace.
Supported Things
Thing Type Name Description
magic:action-module Magic ActionModule Thing A Thing with an ActionModule
magic:bridgedThing Magic Bridged Thing A magic bridged thing.
magic:button Magic Button A button triggering different events.
magic:chatty-thing Magic ChattyThing A thing that periodically sends data.
magic:color-light Magic Light - Color A dimmable light with changeable colors.
magic:configurable-thing Magic Configurable Thing A thing that can be configured.
magic:contact-sensor Magic Sensor - Door/Window Contact A door/window sensor indicating an open/close status.
magic:delayed-thing Magic Delayed Online Thing A thing that goes online after some time.
magic:dimmable-light Magic Light - Dimmable A dimmable light
magic:dynamic-state-description Magic DynamicStateDescription Thing A Thing with a DynamicStateDescription
magic:extensible-thing Magic Light - Extensible A generic light thing with extension channels
magic:firmware-update Magic Firmware Updatable Thing A thing which allows updating its firmware
magic:image Magic Image A thing providing an image
magic:location-thing Magic Location A location thing providing a location channel.
magic:magic-bridge1 Magic Bridge 1 The 1st magic bridge
magic:magic-bridge2 Magic Bridge 2 The 2nd magic bridge
magic:online-offline Magic Online Offline An online/offline toggle thing
magic:onoff-light Magic Light - On/Off A on/off light
magic:player Magic Player Thing A media player
magic:rollershutter Magic Rollershutter Thing A rollershutter
magic:thermostat Magic Thermostat A thermostat for set point temperature and current temperature.
Resources
Hi Wouter,
i’m a total newbie on openhab (and linux) and i would try some configuration without getting hardware in advance. your magic-binding looks very interresting, but i’m not able to get it into my oh-server. could you please help?
kind regards
Hello! What openHAB version are you using? I see this addon is currently not set to be compatible with the latest releases so that maybe the reason it does not show up.
Hi Wouter,
i’m running the newest stable (think should be 4..20.). i’ve got managed to install your addon after setting the config to "show possible incompatibe bindingsl " (or something like that). Now i ran into the next problem. how do i simulate that a “magic door contact to changes from close to open”
is there any documentation about your addon?
kind regards, Marco
P.s. i think having a “sensor emulator” is a really great thing. i thank you very much for your work on this
Hi Wouter,
Does it make sense to update the binding for oh5.x and also in next generation?
Hi @milo, I updated the version range and added an entry for openHAB 5 as well so the magic will also work with newer versions:
