Is there another way to send HSB Values to the Arilux (AL-C01) Controller without reflashing them?
Hello Nico111,
I guess that you are talking about AL-SL 01. If so, I’m using it with WIFI Led bind and original firmware and works perfectly. As I know, you can send HSB values. I have configured " LD382A" as protocol.
Nope I’m talking about this one.
Seams to be the same that I’m using. I have found several model name for the same device.
https://www.banggood.com/ARILUX-AL-LC01-Super-Mini-LED-WIFI-Smart-RGB-Controller-For-RGB-LED-Strip-Light-DC-9-12V-p-1058603.html?rmmds=search&cur_warehouse=CN
Yeah it’s the same, They produce them and label different names on it.
Basically just a ESP8266
Follows this you can do it with magichome without Tasmota.
Hi Andreas,
thanks for sharing. Could you also add your sitemap configuration so I can get it to work?
