2022-01-02 13:27:26.597 [WARN ] [rnal.service.RemoteControllerService] - Cannot open remote interface (Unknown response received for access query)
2022-01-02 17:52:42.571 [INFO ] [rnal.service.RemoteControllerService] - Using Legacy interface
2022-01-02 17:59:39.679 [WARN ] [ab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : smtp.strato.de:465
2022-01-02 17:59:39.682 [WARN ] [ab.binding.mail.internal.SMTPHandler] - java.util.ServiceConfigurationError: javax.mail.Provider: com.sun.mail.imap.IMAPProvider not a subtype
2022-01-03 07:07:00.905 [WARN ] [ab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : smtp.strato.de:465
2022-01-03 07:07:00.930 [WARN ] [ab.binding.mail.internal.SMTPHandler] - java.util.ServiceConfigurationError: javax.mail.Provider: com.sun.mail.imap.IMAPProvider not a subtype
when triggered
2022-01-03 09:49:22.096 [WARN ] [ab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : smtp.strato.de:465
2022-01-03 09:49:22.107 [WARN ] [ab.binding.mail.internal.SMTPHandler] - javax.mail.MessagingException: IOException while sending message;
nested exception is:
javax.activation.UnsupportedDataTypeException: multipart/alternative;
boundary="----=_Part_44_9220965.1641199761607"
Getting the same error with new javascript rules as the one in the post by rikoshak at the top. Strangely it seems to be an intermittent problem for me.
As I already said a month ago: this is an issue with classloading. There is nothing a user can do to fix it. It either requires changes in core or in the binding.
Does anyone know the status or even what will be required to resolve this bug? 2 months now. Without emails to get alerts we can’t move forward with OH3 which we really want to do for other reasons.
Emails started working last night. I have 3 systems running openHABian OH3. I had a test email rule set to send an email on a time trigger (which wasn’t sending any) on one of these systems. I rebooted that system last night and woke up to a bunch of emails. I paused & unpaused the rule & it continues working. So I copied the rule to the other two systems. One started working, the other did not. I rebooted the one that wasn’t sending emails & it’s now working.
I’m running two different OH3.2 system, with the latest upgrade, which were I have now the same error.
Mail which should send out triggered by a rule will not more send to SMTP.WEB.DE mail server.
The error which I can see in the logfile from OH3 is the following:
i just set up my new openhab (openHAB 3.2.0, Release Build) and installed the mail binding (Mail - Bindings | openHAB). I get the same error like is it decribed in that posting - it does not matter if I use HTML oder plain mail or other smtp-servers / settings.
2022-03-29 13:41:02.104 [WARN ] [ab.binding.mail.internal.SMTPHandler] - javax.mail.MessagingException: IOException while sending message;
boundary=“----=_Part_0_525284277.1648554060618”
I send days ago a mail to one if the maintainer here, Kai Kreuzer.
No feedback, about how it could happen to release a 3.2.0 main release,
which contain such showstopper that sendmail is not working out of the box.
Total unhappy about the status.
The openHAB Cloud Connector actions. If I decide I need mail again for some reason and the problem isn’t fixed I’ll use msmtp and the executeCommandLine Action.
There are lots of other options like Telegram also available.
You should demand your money back.
Or perhaps more usefully, volunteer to test new releases?
I doubt that sending emails to developers not responsible for the problem binding will help much.
Sorry will not come down on this level of communication, as I deliver all the time all Information
I can share if an error on a stable version comes up.
Just for completeness, sendMail is working in textual rules like
sendmail.rules
val mailActions = getactions("mail", "mail:smtp:domain")
rule "sendMail Test"
Item MyTestItem changed
var testmessage = " State of testitem:" + MyTestItem.state
mailActions.sendMail("sender@domain", "subject", testmessage)
