Hey again @crnjan
Thanks for your quick answer and the easy trick. ![]()
This would be very helpful to have, yes!
Some things I recognized while fiddling around with the ECharts:
Line charts (and maybe other chart types) will set its own background in dark mode, instead of being transparent as in light mode - so that custom styling on the enclosing component gets hidden behind.
You mentioned it already, but there are some missing components & props within the inline help (like
oh-chart-title,oh-chart-toolbox,oh-chart-tooltipand maybe moreā¦) -
Somehow connected to the above point - itās hard to abstract the configuration of the charts from the ECharts example page to the YAML configuration in OH.
Understanding what is a component and what is a setting took me some time and Iām still struggling on some of themā¦
Example #1: Assigning a background gradient to a line-chart.
How would I translate this part
new echarts.graphic.LinearGradient(0, 0, 0, 1, [{
to usable YAML?See full ECharts example (linear gradient)
areaStyle: { color: new echarts.graphic.LinearGradient(0, 0, 0, 1, [{ offset: 0, color: 'rgb(255, 158, 68)' }, { offset: 1, color: 'rgb(255, 70, 131)' }]) }, -
Or is it even necessary to work with these custom echart graphic classes (if this is the right term hereā¦)?
Example #2: Changing the timestamp-format in the tooltip.
I couldnāt find anything obvious about changing the tooltip-timestamp to a local format (like
dd. MM yyyy) in the docs - a google search brought me to this function (which donāt work):Example changing timestamp in a tootltip (via google search)
tooltip: { trigger: 'axis', formatter: function(params) { params = params[0]; var chartdate = echarts.format.formatTime('dd-MM-yyyy', params.value[0]); var val = '<li style="list-style:none">' + params.marker + params.seriesName + ' ' + params.value[1] + '</li>'; return chartdate + val; } }, -
I could imagine that executing js functions isnāt allowed for security reasons?! Or did I miss anything here?
I think adding the single axis (timeline)-chart could also be helpful in the future, to achieve something like the BasicUI timeline inside the MainUI without have to fiddle something similar with f7-components:
See ā Timeline for Basic UI - #15 by Mihai_BadeaThe single axis type, looks like it would fit that use-case?!
Maybe youāll find time give me some advice here or at least use this for future development of the implementation. ![]()
Thank you!
