OpenHab 5.20
How do I remove that CHAT button from the sidebar?
Thanks!
OpenHab 5.20
Thanks!
I had read that there was some development going on to make it adjustable which buttons are visible. But I havenāt seen in in the changelogsā¦
The PR is still waiting for review:
Perhaps you could make some noise for it to get some attention ![]()
This PR doesnāt touch the Chat, because the chat feature was added after I initially created that PR.
In any case, I donāt think hiding the chat belongs in that PR.
The chat visibility should be turned on/off via the Help & About where the rest of the browser UI options are located.
I had a look at this. Thereās currently already a āHide chat inputā but for habot. So weād need to refactor / rename that to avoid ambiguity. Iām guessing the plan may be to completely remove habot? I donāt know! In any case itās not āas simple as I initially thoughtā - as things usually are!
@florian-h05 wdyt?
Yes, it is the plan to remove the HABot entry from the overview tab or replace it with an entry to the chat functionality.
HABot 2018-2026. RIP.
Ahead of its time ![]()
In that case, we could just recycle the existing chat option and remove the habot at the same time rather than inventing another storage key.
