MainUI copy/paste of cells?
I tried to copy/paste a widget, unfortunately I didn’t find a paste button. there’s nothing in the clipboard.
whats that copy button for?
You can find another button in the top right corner where you can edit the yaml of the whole page. You can paste the code for a single widget there.
Edit: Oh I see that copying does not work… never tried that but you can click edit yaml and copy the code from there
There is a Paste menu item in the containing element :slight_smile: e.g. when you have copied a widget in a column, then you will find the paste button in the menu for the column.
I was also looking for this menu item for hours and found by accident.
But in the meantime i am using the YAML as well unless I am on my Mobile tweaking the pages…
Cheers Jonathan
