Hi there,
maybe im “thinking too complex” but is there a way to have a Widget on Main UI which contains multiple widges in an horizontal arrangement and is continuously scrollable horizontally?
Im Using openHAB 3.2.0
The Swiper Widget comes very close, but i would like to have a “spaceless arrangement” of multiple widgets next to each other
This means, that in the default configuration e.g. 1,5 widgets are visible
(The swiper-widget always shows only one of the configured contained widgets)
In my special case:
I would like to have a single row for all my webcam widgets where each and every picture is directly besides the previous
All the webcam widgets have exactly the same size, thats why i think it would look good if i have one single row for all these similar widgets and can easyily and quickly scroll horizontally through these widgets
Here i created a f7-swiper with two slides
In the first step i want to achieve that i can show multiple slider per view with the “slides-per-view” option
But it doesnt work
Also “slidesPerView” does not work
Is this even possible or do i have to go down another path to achieve
slides-per-view: auto
centered-slides: true
uid: SwiperAutoCenter
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: May 13, 2022, 7:18:35 PM
component: f7-swiper
pagination: true
slides-per-view: 2 <<<< THIS DOES NOT WORK
slots:
default:
- component: f7-swiper-slide
slots:
default:
- component: oh-button
text: test1
text: test2
slots:
default:
text: test3
text: test4
