I have a very short question that I didn’t find the answer to using Google or the forum search.
I created a rule in MainUI. I’m switching on some lights at a specific time, but only if the sun is low enough below the horizon. I’ve got the item and all that, but should I compare the sun’s height with a pure number i.e. “<= -6” or should it refer to the UoM like “<= -6|°”?
What type is the Item? That will tell you the answer. If it’s a Number:Angle you probably need to use a Script Condition and use the units. If it’s just a Number there are not units.
As always, best way to find out is to test. The comparison in MainUI is smart enough to only compare the value of the state so just entering “-6” as the value to compare against works.
