Hi All,
It seems when you access HabPanel through openhab cloud you cannot write. Does anyone know how to change this so you can write changes to the Habpane UI through it?
Thanks!
Hi All,
Thanks!
I was told a while ago that there is a 2000 line limit on writes via the cloud and I’ve noticed that “Delete” isn’t allowed.
I use a VPN to get direct access.
Thanks so theres no way to do it? You cant even using Habmin to delete items for example!
08:56:28.205 [ERROR] [.io.openhabcloud.internal.CloudClient] - Unsupported request method DELETE
As far as I know, that’s correct.
The only way to Delete items via a web interface is to be on the local LAN, or virtually on the Local LAN.
I use the VPN on my AVM FritzBox, or I create a port tunnel via a SSH session.
