I updated the build last night with the latest database - it was built this afternoon as I forgot to trigger the build yesterday.
Yes - in order to update the thing configuration you will need to delete and add the thing back again.
@chris , seems to be working! From time to time it has a hiccup (might be the device itself) but overall it is working as expected. Works well with HabPanel and Sitemaps! Thanks for the help!
Thanks @chris itās working now. However as @fifo mentioned it behaves strange. Iām setting colour once but itās bouncing values for some reason:
2018-04-30 23:45:43.259 [ome.event.ItemCommandEvent] - Item 'ZWaveNode12QubinoKitchenRGBWDimmer_ColorControl' received command 359,100,74
2018-04-30 23:45:43.263 [vent.ItemStateChangedEvent] - ZWaveNode12QubinoKitchenRGBWDimmer_ColorControl changed from 0,0,0 to 359,100,74
2018-04-30 23:45:44.177 [vent.ItemStateChangedEvent] - ZWaveNode12QubinoKitchenRGBWDimmer_ColorControl changed from 359,100,74 to 0,100,20
From my value 359,100,74 itās changing to 0,100,20. And in openhab.log it is completely different.
2018-04-30 23:45:43.603 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report BLUE 0
2018-04-30 23:45:43.803 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report GREEN 0
2018-04-30 23:45:43.973 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report WARM_WHITE 0
2018-04-30 23:45:44.173 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report RED 51
2018-04-30 23:45:44.174 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report finished {BLUE=0, GREEN=0, WARM_WHITE=0, RED=51}
Please provide a debug log and Iāll take a look at whatās happening.
2018-05-01 08:03:59.654 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:03:59.654 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 16: Node advancer - PING: Transaction complete (SendData:Request) success(false)
2018-05-01 08:04:16.127 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Command received zwave:device:8307e216:node17:color_color --> 359,100,74
2018-05-01 08:04:16.139 [DEBUG] [ternal.converter.ZWaveColorConverter] - NODE 17: Converted command '359,100,74' to value 74 0 1 for channel = zwave:device:8307e216:node17:color_color, endpoint = 0.
2018-05-01 08:04:16.149 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Creating new message for application command SWITCH_COLOR_GET 3
2018-05-01 08:04:16.150 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Creating new message for application command SWITCH_COLOR_GET 0
2018-05-01 08:04:16.150 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Creating new message for application command SWITCH_COLOR_GET 4
2018-05-01 08:04:16.151 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Creating new message for application command SWITCH_COLOR_GET 2
2018-05-01 08:04:16.157 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-05-01 08:04:16.158 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 15 00 13 11 0E 33 05 05 02 4A 03 00 04 01 00 00 01 00 FF 25 86 C6
2018-05-01 08:04:16.159 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 15 00 13 11 0E 33 05 05 02 4A 03 00 04 01 00 00 01 00 FF 25 86 C6
2018-05-01 08:04:16.160 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
2018-05-01 08:04:16.161 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-05-01 08:04:16.161 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2018-05-01 08:04:16.162 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2018-05-01 08:04:16.167 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2018-05-01 08:04:16.168 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.170 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.171 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-05-01 08:04:16.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.172 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-05-01 08:04:16.172 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
2018-05-01 08:04:16.191 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 86 00 00 03 6E
2018-05-01 08:04:16.192 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.193 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 86 00 00 03 00 00 60
2018-05-01 08:04:16.193 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 86 00 00 03 00 00 60
2018-05-01 08:04:16.194 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=86 00 00 03
2018-05-01 08:04:16.194 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 134, Status = Transmission complete and ACK received(0)
2018-05-01 08:04:16.195 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.199 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.202 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=17, callback=134, payload=11 0E 33 05 05 02 4A 03 00 04 01 00 00 01 00 FF
2018-05-01 08:04:16.203 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=86 00 00 03
2018-05-01 08:04:16.204 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=134, expected=SendData, cancelled=false transaction complete!
2018-05-01 08:04:16.208 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.214 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.216 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 56ms/3560ms.
2018-05-01 08:04:16.217 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2018-05-01 08:04:16.218 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 11 03 33 03 03 25 87 65
2018-05-01 08:04:16.218 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 0A 00 13 11 03 33 03 03 25 87 65
2018-05-01 08:04:16.227 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.229 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.230 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-05-01 08:04:16.231 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.233 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-05-01 08:04:16.234 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
2018-05-01 08:04:16.303 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 87 00 00 08 64
2018-05-01 08:04:16.304 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.305 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 87 00 00 08 00 00 6A
2018-05-01 08:04:16.305 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 87 00 00 08 00 00 6A
2018-05-01 08:04:16.306 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=87 00 00 08
2018-05-01 08:04:16.306 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 135, Status = Transmission complete and ACK received(0)
2018-05-01 08:04:16.307 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.308 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.309 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=135, payload=11 03 33 03 03
2018-05-01 08:04:16.309 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=87 00 00 08
2018-05-01 08:04:16.310 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=135, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2018-05-01 08:04:16.326 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 11 04 33 04 03 00 D0
2018-05-01 08:04:16.327 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.327 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 11 04 33 04 03 00 D0
2018-05-01 08:04:16.328 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 11 04 33 04 03 00 D0
2018-05-01 08:04:16.329 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 03 00
2018-05-01 08:04:16.330 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-05-01 08:04:16.330 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.331 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.331 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class COLOR
2018-05-01 08:04:16.332 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Received COMMAND_CLASS_SWITCH_COLOR V2
2018-05-01 08:04:16.333 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Process Color SWITCH_COLOR_REPORT
2018-05-01 08:04:16.334 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report GREEN 0
2018-05-01 08:04:16.334 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=135, payload=11 03 33 03 03
2018-05-01 08:04:16.335 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 03 00
2018-05-01 08:04:16.336 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=135, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2018-05-01 08:04:16.336 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.337 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 117ms/3560ms.
2018-05-01 08:04:16.338 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2018-05-01 08:04:16.339 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 11 03 33 03 00 25 88 69
2018-05-01 08:04:16.339 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 0A 00 13 11 03 33 03 00 25 88 69
2018-05-01 08:04:16.348 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.351 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.352 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-05-01 08:04:16.352 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.353 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-05-01 08:04:16.353 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
2018-05-01 08:04:16.368 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 88 00 00 02 61
2018-05-01 08:04:16.369 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.371 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 88 00 00 02 00 00 6F
2018-05-01 08:04:16.373 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 88 00 00 02 00 00 6F
2018-05-01 08:04:16.374 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=88 00 00 02
2018-05-01 08:04:16.374 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 136, Status = Transmission complete and ACK received(0)
2018-05-01 08:04:16.375 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.376 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.376 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=136, payload=11 03 33 03 00
2018-05-01 08:04:16.377 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=88 00 00 02
2018-05-01 08:04:16.378 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=136, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2018-05-01 08:04:16.382 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 11 04 33 04 00 00 D3
2018-05-01 08:04:16.383 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.384 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 11 04 33 04 00 00 D3
2018-05-01 08:04:16.385 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 11 04 33 04 00 00 D3
2018-05-01 08:04:16.393 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 00 00
2018-05-01 08:04:16.395 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-05-01 08:04:16.396 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.398 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.400 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class COLOR
2018-05-01 08:04:16.400 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Received COMMAND_CLASS_SWITCH_COLOR V2
2018-05-01 08:04:16.402 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Process Color SWITCH_COLOR_REPORT
2018-05-01 08:04:16.403 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report WARM_WHITE 0
2018-05-01 08:04:16.403 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=136, payload=11 03 33 03 00
2018-05-01 08:04:16.404 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 00 00
2018-05-01 08:04:16.405 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=136, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2018-05-01 08:04:16.405 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.406 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 66ms/3560ms.
2018-05-01 08:04:16.407 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
2018-05-01 08:04:16.408 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 11 03 33 03 04 25 89 6C
2018-05-01 08:04:16.408 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 0A 00 13 11 03 33 03 04 25 89 6C
2018-05-01 08:04:16.417 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.450 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.451 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-05-01 08:04:16.454 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 89 00 00 02 60
2018-05-01 08:04:16.457 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.459 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 11 04 33 04 04 00 D7
2018-05-01 08:04:16.459 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-05-01 08:04:16.460 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
2018-05-01 08:04:16.461 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=1
2018-05-01 08:04:16.462 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 89 00 00 02 00 00 6E
2018-05-01 08:04:16.463 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 89 00 00 02 00 00 6E
2018-05-01 08:04:16.464 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=89 00 00 02
2018-05-01 08:04:16.467 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 137, Status = Transmission complete and ACK received(0)
2018-05-01 08:04:16.468 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.469 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.469 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=137, payload=11 03 33 03 04
2018-05-01 08:04:16.470 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=89 00 00 02
2018-05-01 08:04:16.470 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=137, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2018-05-01 08:04:16.471 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.471 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 11 04 33 04 04 00 D7
2018-05-01 08:04:16.472 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 11 04 33 04 04 00 D7
2018-05-01 08:04:16.473 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 04 00
2018-05-01 08:04:16.476 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-05-01 08:04:16.477 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.478 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.479 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class COLOR
2018-05-01 08:04:16.480 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Received COMMAND_CLASS_SWITCH_COLOR V2
2018-05-01 08:04:16.480 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Process Color SWITCH_COLOR_REPORT
2018-05-01 08:04:16.481 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report BLUE 0
2018-05-01 08:04:16.481 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=137, payload=11 03 33 03 04
2018-05-01 08:04:16.482 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 04 00
2018-05-01 08:04:16.485 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=137, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2018-05-01 08:04:16.486 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.499 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 90ms/3560ms.
2018-05-01 08:04:16.501 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-05-01 08:04:16.502 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 11 03 33 03 02 25 8A 69
2018-05-01 08:04:16.503 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 17: Sending REQUEST Message = 01 0A 00 13 11 03 33 03 02 25 8A 69
2018-05-01 08:04:16.512 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.516 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.517 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-05-01 08:04:16.519 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-05-01 08:04:16.520 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-05-01 08:04:16.520 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: Sent Data successfully placed on stack.
2018-05-01 08:04:16.533 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8A 00 00 03 62
2018-05-01 08:04:16.537 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.540 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 8A 00 00 03 00 00 6C
2018-05-01 08:04:16.541 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 8A 00 00 03 00 00 6C
2018-05-01 08:04:16.542 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=8A 00 00 03
2018-05-01 08:04:16.542 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 17: SendData Request. CallBack ID = 138, Status = Transmission complete and ACK received(0)
2018-05-01 08:04:16.543 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.544 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.544 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=138, payload=11 03 33 03 02
2018-05-01 08:04:16.545 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=8A 00 00 03
2018-05-01 08:04:16.545 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=138, expected=ApplicationCommandHandler, cancelled=false MISMATCH
2018-05-01 08:04:16.547 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 11 04 33 04 02 12 C3
2018-05-01 08:04:16.549 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-05-01 08:04:16.552 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 04 00 11 04 33 04 02 12 C3
2018-05-01 08:04:16.553 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0A 00 04 00 11 04 33 04 02 12 C3
2018-05-01 08:04:16.554 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 02 12
2018-05-01 08:04:16.556 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-05-01 08:04:16.559 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-05-01 08:04:16.561 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@aa1c8d8 already registered
2018-05-01 08:04:16.561 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class COLOR
2018-05-01 08:04:16.563 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Received COMMAND_CLASS_SWITCH_COLOR V2
2018-05-01 08:04:16.564 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 17: Process Color SWITCH_COLOR_REPORT
2018-05-01 08:04:16.565 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report RED 18
2018-05-01 08:04:16.566 [INFO ] [.commandclass.ZWaveColorCommandClass] - NODE 17: Color report finished {GREEN=0, WARM_WHITE=0, BLUE=0, RED=18}
2018-05-01 08:04:16.567 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveColorValueEvent
2018-05-01 08:04:16.568 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveColorValueEvent
2018-05-01 08:04:16.568 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint = 0, command class = COLOR, value = 0
2018-05-01 08:04:16.569 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Updating channel state zwave:device:8307e216:node17:color_color to 0,100,7 [HSBType]
2018-05-01 08:04:16.574 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Updating channel state zwave:device:8307e216:node17:color_temperature to 0 [PercentType]
2018-05-01 08:04:16.584 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=17, callback=138, payload=11 03 33 03 02
2018-05-01 08:04:16.593 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 11 04 33 04 02 12
2018-05-01 08:04:16.598 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=138, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2018-05-01 08:04:16.599 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.600 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-05-01 08:04:16.602 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 17: Response processed after 97ms/3560ms.
Node 17 is my device
@goopilot Did you ever get this resolved? Iām looking at getting one of these controllers, but donāt want something that will make uncommanded changes. Thanks
I think my issue was that I was sending HSL format instead of RGB. Need to test it with RGB.
Gotcha. Please let me know what you find out. Iād really like to get a few of these setup. Thanks!
I recently purchased one of these, and the color selector isnāt matching up. This is the way the item color selection is listed in my items file:
Color mBthSnkLgtRGBWClr "Sink Color Lights Color" <colorlight> (gMaster,gMasterBath) {channel="zwave:device:01FFFFFF-FFFF-FFFF-FFFF-160118150928:node36:color_color"}
Is there something obvious that Iām doing wrong? Thanks
Actually, it looks as if the color wheel works, just that the colors are incorrectly assigned. Almost like the displayed color wheel is off by 90 degrees. Any ideas are welcome.
So, what I found out, and this might pertain to you as well @goopilot, the wires soldered to the RGBW strip were IN THE WRONG ORDER FROM THE FACTORY! I couldnāt believe it. I cut the shrink tube off to change the connector to something more standard, and there it was. Now it all works. I need to work out a better control scenario, but at least itās functioning correctly.
