I copied the jar file directly to the addons folder, restarted OH2, and also checked with bundle:list -s in the console. (org.openhab.binding.wmr-1.9.0.jar)
It´s displayed as “active”, but I don´t see it on the PaperUI to retrieve channels, etc.
Restarted OH several times, also deactivated “access remote repositary”, it´s still not there.
I even see a logfile entry “connected to WMR HID device”…
channel is for the newer 2.x bindings
your Item config looks good (uses the old style 1.x binding config)
In general:
You need to be able to access the USB port that is connected to the Weather Station
Usually there should be a $OPENHAB_CONF/services/wmr.cfg file to set some basic binding parameters (although this binding does not seem to make use of a cfg file)
You need to play with the item configs. I am not sure what the id part of the {wmr = "id: temp.indoor.temperature"} is supposed to be…
I couldn’t find much explanations in that thread. You will need to play around with it to see if you can make it work.
What is the communications protocol of this Weather Station (which model do you have?)
Maybe you can use another binding to pull info from it.
