- Platform information:
- Hardware: MacMini(2018), 3.6 GHz Intel Core i3, 8 GB RAM
- OS: Mac OS 10.14.3
- Java Runtime Environment: jdk-12.0.2.jdk
- openHAB version: 2.4.0
I’m moving an HA system to OH2, and have a Aeotec Gen 5 Z-Stick. I’m using the Z-Wave Binding (Chris Johnson).
I’m testing the installation using an available Home Manageables HM-LM001 lighting module which apparently is comparable with this binding (https://github.com/openhab/org.openhab.binding.zwave/blob/master/doc/erone/hmlm001_0_0.md)
Using Paper UI for discovery, the device shows up as a BASIC_TYPE_SLAVE but otherwise an unknown device.
I’ve noticed that the Z-Wave Binding Supported Things list does NOT include the HM-LM001, so it looks like I need to manually add it in order for this device to be recognized.
Per https://www.openhab.org/docs/configuration/things.html, it appears I need to create a .thing file in the things directory with a line like this:
Thing <binding_id>:<type_id>:<thing_id> “Label” @ “Location” [ ]
Where can I get the information to complete this line for this device?
