I’ve worked on this some and I’m seeing that the device is now reporting back when the door is opened but I never get a closed response:
Line 22661: 2016-06-14 09:12:40.385 [DEBUG] [.z.internal.ZWaveActiveBinding:466 ]- NODE 13: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
Perhaps I have the device configured incorrectly?
Contact Door_Laundry "Laundry Door [%s]" <door> (Laundry,Doors) { zwave="13:command=SENSOR_BINARY,respond_to_basic=true", imperihab="room:Laundry,label:Laundry Door" }
Here’s a look at the zwave.log file pertaining only to this node:
Search "node 13" (176 hits in 1 file)
C:\openhab\logs\zwave.log (176 hits)
Line 181: 2016-06-14 08:23:02.193 [INFO ] [rialApiGetInitDataMessageClass:60 ]- NODE 13: Node found
Line 200: 2016-06-14 08:23:02.193 [DEBUG] [b.z.i.protocol.ZWaveController:506 ]- NODE 13: Init node thread start
Line 226: 2016-06-14 08:23:02.364 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:138 ]- NODE 13: Serializing from file etc\zwave\node13.xml
Line 235: 2016-06-14 08:23:02.427 [DEBUG] [b.z.i.protocol.ZWaveController:539 ]- NODE 13: Restore from config: Ok.
Line 252: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - EMPTYNODE: queue length(0), free to send(true)
Line 260: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false)
Line 266: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:337 ]- NODE 13: Node advancer: Initialisation starting
Line 271: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to PROTOINFO
Line 279: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true)
Line 281: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:346 ]- NODE 13: Node advancer: PROTOINFO - send IdentifyNode
Line 302: 2016-06-14 08:23:02.442 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 304: 2016-06-14 08:23:02.442 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- NODE 13: Init node thread finished
Line 489: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 13: ProtocolInfo
Line 490: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 13: Listening = false
Line 491: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 13: Routing = true
Line 492: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 13: Beaming = true
Line 493: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 13: Version = 4
Line 494: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 13: FLIRS = false
Line 495: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 13: Security = false
Line 496: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 13: Max Baud = 40000
Line 497: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 13: Basic = Routing Slave
Line 498: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 13: Generic = Binary Sensor
Line 499: 2016-06-14 08:23:02.489 [DEBUG] [i.p.s.IdentifyNodeMessageClass:110 ]- NODE 13: Specific = Routing Binary Sensor
Line 500: 2016-06-14 08:23:02.489 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class NO_OPERATION
Line 501: 2016-06-14 08:23:02.489 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class BASIC
Line 502: 2016-06-14 08:23:02.489 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class SENSOR_BINARY
Line 509: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - PROTOINFO: Transaction complete (IdentifyNode:Request) success(true)
Line 510: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 511: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 512: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - PROTOINFO: queue length(0), free to send(true)
Line 513: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - PROTOINFO try 1: stageAdvanced(false)
Line 514: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to NEIGHBORS
Line 515: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - NEIGHBORS try 0: stageAdvanced(true)
Line 516: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:356 ]- NODE 13: Node advancer: NEIGHBORS - send RoutingInfo
Line 517: 2016-06-14 08:23:02.489 [DEBUG] [p.s.GetRoutingInfoMessageClass:30 ]- NODE 13: Request routing info
Line 520: 2016-06-14 08:23:02.489 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 744: 2016-06-14 08:23:02.572 [DEBUG] [p.s.GetRoutingInfoMessageClass:49 ]- NODE 13: Got NodeRoutingInfo request.
Line 745: 2016-06-14 08:23:02.572 [DEBUG] [p.s.GetRoutingInfoMessageClass:79 ]- NODE 13: Neighbor nodes: 5 9
Line 754: 2016-06-14 08:23:02.573 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - NEIGHBORS: Transaction complete (GetRoutingInfo:Request) success(true)
Line 755: 2016-06-14 08:23:02.573 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 756: 2016-06-14 08:23:02.573 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 757: 2016-06-14 08:23:02.573 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - NEIGHBORS: queue length(0), free to send(true)
Line 758: 2016-06-14 08:23:02.573 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - NEIGHBORS try 1: stageAdvanced(false)
Line 759: 2016-06-14 08:23:02.574 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to FAILED_CHECK
Line 760: 2016-06-14 08:23:02.574 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - FAILED_CHECK try 0: stageAdvanced(true)
Line 761: 2016-06-14 08:23:02.574 [DEBUG] [i.p.s.IsFailedNodeMessageClass:32 ]- NODE 13: Requesting IsFailedNode status from controller.
Line 764: 2016-06-14 08:23:02.574 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 970: 2016-06-14 08:23:02.629 [WARN ] [i.p.s.IsFailedNodeMessageClass:53 ]- NODE 13: Is currently marked as failed by the controller!
Line 971: 2016-06-14 08:23:02.629 [DEBUG] [.z.internal.protocol.ZWaveNode:260 ]- NODE 13: Node is DEAD.
Line 972: 2016-06-14 08:23:02.629 [DEBUG] [.z.internal.protocol.ZWaveNode:269 ]- NODE 13: Initialisation incomplete, not signalling state change.
Line 979: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true)
Line 980: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 981: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 982: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - FAILED_CHECK: queue length(0), free to send(true)
Line 983: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false)
Line 984: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to WAIT
Line 985: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - WAIT try 0: stageAdvanced(true)
Line 986: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:380 ]- NODE 13: Node advancer: WAIT - Listening=false, FrequentlyListening=false
Line 987: 2016-06-14 08:23:02.630 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:398 ]- NODE 13: Node advancer: WAIT - Still waiting!
Line 2979: 2016-06-14 08:24:52.163 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 2982: 2016-06-14 08:24:52.163 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 3098: 2016-06-14 08:24:52.224 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 3100: 2016-06-14 08:24:52.224 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 3215: 2016-06-14 08:24:52.286 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 3216: 2016-06-14 08:24:52.286 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 3428: 2016-06-14 08:27:15.428 [INFO ] [rialApiGetInitDataMessageClass:60 ]- NODE 13: Node found
Line 3448: 2016-06-14 08:27:15.428 [DEBUG] [b.z.i.protocol.ZWaveController:506 ]- NODE 13: Init node thread start
Line 3471: 2016-06-14 08:27:15.631 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:138 ]- NODE 13: Serializing from file etc\zwave\node13.xml
Line 3493: 2016-06-14 08:27:15.709 [DEBUG] [b.z.i.protocol.ZWaveController:539 ]- NODE 13: Restore from config: Ok.
Line 3494: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - EMPTYNODE: queue length(0), free to send(true)
Line 3501: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false)
Line 3505: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:337 ]- NODE 13: Node advancer: Initialisation starting
Line 3507: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to PROTOINFO
Line 3523: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true)
Line 3526: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:346 ]- NODE 13: Node advancer: PROTOINFO - send IdentifyNode
Line 3529: 2016-06-14 08:27:15.709 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 3530: 2016-06-14 08:27:15.709 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- NODE 13: Init node thread finished
Line 3695: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 13: ProtocolInfo
Line 3696: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 13: Listening = false
Line 3697: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 13: Routing = true
Line 3698: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 13: Beaming = true
Line 3699: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 13: Version = 4
Line 3700: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 13: FLIRS = false
Line 3701: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 13: Security = false
Line 3702: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 13: Max Baud = 40000
Line 3703: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 13: Basic = Routing Slave
Line 3704: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 13: Generic = Binary Sensor
Line 3705: 2016-06-14 08:27:15.740 [DEBUG] [i.p.s.IdentifyNodeMessageClass:110 ]- NODE 13: Specific = Routing Binary Sensor
Line 3706: 2016-06-14 08:27:15.740 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class NO_OPERATION
Line 3707: 2016-06-14 08:27:15.740 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class BASIC
Line 3708: 2016-06-14 08:27:15.740 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:243 ]- NODE 13: Creating new instance of command class SENSOR_BINARY
Line 3715: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - PROTOINFO: Transaction complete (IdentifyNode:Request) success(true)
Line 3716: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 3717: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 3718: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - PROTOINFO: queue length(0), free to send(true)
Line 3719: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - PROTOINFO try 1: stageAdvanced(false)
Line 3720: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to NEIGHBORS
Line 3721: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - NEIGHBORS try 0: stageAdvanced(true)
Line 3722: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:356 ]- NODE 13: Node advancer: NEIGHBORS - send RoutingInfo
Line 3723: 2016-06-14 08:27:15.756 [DEBUG] [p.s.GetRoutingInfoMessageClass:30 ]- NODE 13: Request routing info
Line 3726: 2016-06-14 08:27:15.756 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 3960: 2016-06-14 08:27:15.818 [DEBUG] [p.s.GetRoutingInfoMessageClass:49 ]- NODE 13: Got NodeRoutingInfo request.
Line 3961: 2016-06-14 08:27:15.818 [DEBUG] [p.s.GetRoutingInfoMessageClass:79 ]- NODE 13: Neighbor nodes: 5 9
Line 3970: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - NEIGHBORS: Transaction complete (GetRoutingInfo:Request) success(true)
Line 3971: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 3972: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 3973: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - NEIGHBORS: queue length(0), free to send(true)
Line 3974: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - NEIGHBORS try 1: stageAdvanced(false)
Line 3975: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to FAILED_CHECK
Line 3976: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - FAILED_CHECK try 0: stageAdvanced(true)
Line 3977: 2016-06-14 08:27:15.834 [DEBUG] [i.p.s.IsFailedNodeMessageClass:32 ]- NODE 13: Requesting IsFailedNode status from controller.
Line 3980: 2016-06-14 08:27:15.834 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:240 ]- NODE 13: Node advancer - queued packet. Queue length is 1
Line 4191: 2016-06-14 08:27:15.910 [WARN ] [i.p.s.IsFailedNodeMessageClass:53 ]- NODE 13: Is currently marked as failed by the controller!
Line 4192: 2016-06-14 08:27:15.910 [DEBUG] [.z.internal.protocol.ZWaveNode:260 ]- NODE 13: Node is DEAD.
Line 4193: 2016-06-14 08:27:15.910 [DEBUG] [.z.internal.protocol.ZWaveNode:269 ]- NODE 13: Initialisation incomplete, not signalling state change.
Line 4200: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1034]- NODE 13: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true)
Line 4201: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 1.
Line 4202: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:208 ]- NODE 13: Node advancer - message removed from queue. Queue size 0.
Line 4203: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:267 ]- NODE 13: Node advancer - FAILED_CHECK: queue length(0), free to send(true)
Line 4204: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false)
Line 4205: 2016-06-14 08:27:15.911 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:890 ]- NODE 13: Node advancer - advancing to WAIT
Line 4206: 2016-06-14 08:27:15.912 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:332 ]- NODE 13: Node advancer: loop - WAIT try 0: stageAdvanced(true)
Line 4207: 2016-06-14 08:27:15.912 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:380 ]- NODE 13: Node advancer: WAIT - Listening=false, FrequentlyListening=false
Line 4208: 2016-06-14 08:27:15.912 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:398 ]- NODE 13: Node advancer: WAIT - Still waiting!
Line 4420: 2016-06-14 08:27:16.011 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 4423: 2016-06-14 08:27:16.011 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 5955: 2016-06-14 08:29:05.393 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 5957: 2016-06-14 08:29:05.393 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 6545: 2016-06-14 08:29:33.680 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 6546: 2016-06-14 08:29:33.680 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 6730: 2016-06-14 08:29:46.736 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 6731: 2016-06-14 08:29:46.736 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 6790: 2016-06-14 08:29:58.867 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1020]- NODE 13: Node advancer - WAIT: The WAIT is over!
Line 6791: 2016-06-14 08:29:58.867 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:202 ]- NODE 13: Node advancer - checking initialisation queue. Queue size 0.
Line 8094: 2016-06-14 08:32:45.372 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 8095: 2016-06-14 08:32:45.372 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 9636: 2016-06-14 08:37:20.025 [DEBUG] [.z.i.config.ZWaveConfiguration:977 ]- NODE 13: Heal node
Line 9637: 2016-06-14 08:37:20.027 [DEBUG] [z.internal.ZWaveNetworkMonitor:275 ]- NODE 13: Starting heal
Line 11832: 2016-06-14 08:43:29.076 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11833: 2016-06-14 08:43:29.076 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11836: 2016-06-14 08:43:29.076 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11837: 2016-06-14 08:43:29.076 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11840: 2016-06-14 08:43:29.077 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11841: 2016-06-14 08:43:29.077 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11844: 2016-06-14 08:43:29.077 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11845: 2016-06-14 08:43:29.077 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11848: 2016-06-14 08:43:29.078 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11849: 2016-06-14 08:43:29.078 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11852: 2016-06-14 08:43:29.078 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11853: 2016-06-14 08:43:29.078 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11856: 2016-06-14 08:43:29.079 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11857: 2016-06-14 08:43:29.079 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11866: 2016-06-14 08:43:29.080 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11868: 2016-06-14 08:43:29.080 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11877: 2016-06-14 08:43:29.082 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11878: 2016-06-14 08:43:29.082 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11886: 2016-06-14 08:43:29.084 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11887: 2016-06-14 08:43:29.084 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11895: 2016-06-14 08:43:29.085 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11896: 2016-06-14 08:43:29.085 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11904: 2016-06-14 08:43:29.087 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11905: 2016-06-14 08:43:29.087 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11914: 2016-06-14 08:43:29.089 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11917: 2016-06-14 08:43:29.089 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 11929: 2016-06-14 08:43:29.091 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 11930: 2016-06-14 08:43:29.091 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 17104: 2016-06-14 08:57:27.955 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry_Battery is not completed initialisation
Line 17105: 2016-06-14 08:57:27.955 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 13: Polling list: item Door_Laundry is not completed initialisation
Line 22652: 2016-06-14 09:12:40.384 [DEBUG] [ApplicationCommandMessageClass:40 ]- NODE 13: Application Command Request (FAILED:PING)
Line 22653: 2016-06-14 09:12:40.384 [DEBUG] [.z.internal.protocol.ZWaveNode:244 ]- NODE 13: Node has risen from the DEAD. Init stage is PING:{}.
Line 22654: 2016-06-14 09:12:40.384 [DEBUG] [.z.internal.protocol.ZWaveNode:269 ]- NODE 13: Initialisation incomplete, not signalling state change.
Line 22655: 2016-06-14 09:12:40.384 [DEBUG] [ApplicationCommandMessageClass:58 ]- NODE 13: Incoming command class BASIC
Line 22656: 2016-06-14 09:12:40.384 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:73 ]- NODE 13: Received Basic Request
Line 22657: 2016-06-14 09:12:40.384 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:77 ]- NODE 13: Basic Set sent to the controller will be processed as Basic Report
Line 22658: 2016-06-14 09:12:40.384 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:106 ]- NODE 13: Basic report, value = 0xFF
Do you see anything that stands out? I checked the neighbors in habmin and it’s now seeing the thermostat as a neighbor. In fact, has the same neighbors as the working garage door sensor.
I’m still trying not to buy a repeater until I know for certain that this is a range issue and not a hardware configuration issue. Thanks to all for the help in trying to get this thing working.
