What’s the preferred way of submitting database changes to you in the future?
Also any pointer as to what I was doing wrong?
Installation of snapshot release via apt-get and compilation of zbus binding via maven, source from git repository.
I copied the compiled jar to every location I could find it (find / -name “zbus” or similar was used to find locations, and restated openhab.
The best thing is to register on the database site, and let me know so I can update your access so you can edit the data directly.
You mean zwave, right?
Manual installation of bindings can be a problem as Karaf can cache old versions. However in general you should be able to uninstall the running binding (in PaperUI) then put the manual binding into the addons. The only issue is you need to manage dependencies such as the serial library which also need to be installed.
