2017-03-03 17:00:13.769 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21189 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:01:23.524 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21258 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:02:33.351 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21328 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:03:43.163 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21398 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:04:52.844 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21468 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:06:02.913 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21538 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:07:12.310 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21607 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:08:22.333 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21677 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:09:32.288 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21747 seconds from gateway 'ccu', restarting RPC server
2017-03-03 17:10:42.131 [INFO ] [ternal.communicator.HomematicGateway] - No event since 21817 seconds from gateway 'ccu', restarting RPC server
So every second!
Is this normal? At least its not the best for the SD of the raspberry.
Before i used the online-snapshot with apt-get and also with manuel installation (both was at a time before these 3 package were available which today are).
Everywhere was the same problem till yet.
Also an other raspi (other house) has the same problem with its ccu2…
2017-09-29 14:09:22.617 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 960 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:10:22.628 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1020 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:11:22.638 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1080 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:12:22.649 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1140 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:13:22.658 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1200 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:14:22.667 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1260 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:15:22.679 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1320 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:16:22.690 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1380 seconds from gateway 'ccu', restarting RPC server
2017-09-29 14:17:22.698 [INFO ] [ommunicator.AbstractHomematicGateway] - No event since 1440 seconds from gateway 'ccu', restarting RPC server
I also can observe this problem here, but only when I have two openhab instances connected in parallel to my homegear. When I have only my openhab2 instance connected to homegear it runs fine for weeks.
During migration from openhab1 to openhab2 I had both openhab’s running on two different machines and connected to the same instance of homegear. Here I could observe that openhab2 was loosing connection after some hours, while openhab1 was running fine all the time.
My setup:
openhab 2.1.0
Homegear 0.7.9-1375
2x Raspberry Pi 3, one for homegear, one for openhab
