Map file does not work
I have a rollershutter item connected to a rollershutter thing (configured completely over oh UI). The rollershutter goes down when i press up and vice versa in oh. So I created a rollershutter.map file with those lines:
UP=DOWN
DOWN=UP
0=100
100=0
and configured in the channel settings to use MAP and the file rollershutter.map. Unfortunately it does not change anything in its behaviour. Any idea what is wrong?
MAP transormation 4.2.1 is installed
Since what ever configuration you did is on the Channel config we’ll almost certainly need to see that and any relevant errors in the logs.
