Hi
From Chamberlain (garage door) I get a status “Partially Open/Closed”. Tried to add this to “de.map” to have this message in German:
Partially Open/Closed=Halb geöffnet
Unfortunately this doesn’t work:
Could not transform ‘Partially Open/Closed’ with the file ‘de.map’ : Target value not found in map for ‘Partially Open/Closed’
Everything else (closed, open, closing, opening) are ok. Most probably because of “/”?
A bug or did I miss something?
Michael
Dries
(Dries)
#2
Did you try
"Partially Open/Closed"=“Halb geöffnet”
Just tried it…but with no success
sihui
(SiHui)
#4
A lot of hints regarding escaping:
Thanks!
Partially\ Open/Closed=Halb geöffnet
