I tried to install mapdb, but it doesn’t seem to work.
As default persistence I have rrd4j.
What am I doing wrong?
Carl.
addon:
root@raspberrypi:/etc/openhab/configurations# ls -l /usr/share/openhab/addons/ total 2752 -rw-r--r-- 1 root root 7329 Jan 22 00:05 org.openhab.action.astro-1.8.0.jar -rw-r--r-- 1 root root 80975 Jan 22 00:05 org.openhab.binding.astro-1.8.0.jar -rw-r--r-- 1 root root 63873 Jul 31 2015 org.openhab.binding.exec-1.7.1.jar -rw-r--r-- 1 root root 10404 Jan 30 21:34 org.openhab.binding.ntp-1.8.0.jar -rw-r--r-- 1 root root 154058 Jul 31 2015 org.openhab.binding.rfxcom-1.7.1.jar -rw-r--r-- 1 root root 957696 Jul 31 2015 org.openhab.binding.tellstick-1.7.1.jar -rw-r--r-- 1 root root 498170 Jul 31 2015 org.openhab.io.transport.serial-1.7.1.jar -rw-r--r-- 1 root root 402540 Feb 7 23:42 org.openhab.persistence.mapdb-1.8.0.jar -rw-r--r-- 1 root root 624560 Feb 9 22:18 org.openhab.persistence.rrd4j-1.8.0.jar -rw-r--r-- 1 root root 126 Jul 31 2015 README
openhab.cfg:
root@raspberrypi:/etc/openhab/configurations# grep -E -i "(rrd4j|^[^#]|mapdb)" openhab.cfg
folder:items=10,items
folder:sitemaps=10,sitemap
folder:rules=10,rules
folder:scripts=10,script
folder:persistence=10,persist
security:netmask=192.168.178.0/24
# persistence:default=rrd4j
persistence:default=mapdb
chart:provider=default
########################### RRD4J Persistence Service #################################
#rrd4j:<defname>.def=[ABSOLUTE|COUNTER|DERIVE|GAUGE],<heartbeat>,[<min>|U],[<max>|U],<step>
#rrd4j:<defname>.archives=[AVERAGE|MIN|MAX|LAST|FIRST|TOTAL],<xff>,<steps>,<rows>
#rrd4j:<defname>.items=<list of items for this defname>
rrd4j:carl.def=GAUGE,60,U,U,10
rrd4j:carl.archives=AVERAGE,0.5,1,600
rrd4j:carl.items=LichtIntensiteit_Woonkamer
logging:pattern=%date{ISO8601} - %-25logger: %msg%n
########################### MapDB Persistence Service ##################################
#mapdb:commitinterval=5
#mapdb:commitsamestate=false
ntp:hostname=ptbtime1.ptb.de
hue:secret=openHABRuntime
tcp:refreshinterval=250
astro:latitude=52.0704978
astro:longitude=4.3006999
astro:interval=57
mapdb.persist:
root@raspberrypi:/etc/openhab/configurations# cat persistence/mapdb.persist
Strategies {
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
// if no strategy is specified for an item entry below, the default list will be used
default = everyChange,restoreOnStartup,everyHour
Items {
LightsOnIntensityThreshold
LightsEnableIntensityThreshold
root@raspberrypi:/etc/openhab/configurations# cat items/lichtsensor.items
Voorbeeld voor exec binding. Switch Light_GF_Huiskamer_Achterdeur_Schemerlamp "Achterdeur" (GF_Huiskamer, Lights) { exec=">[ON:sudo /home/pi/projects/klikaanklikuit_flask/tmp/lights/kaku_lock.sh D 1 on] >[OFF:sudo /home/pi/projects/klikaanklikuit_flask/tmp/lights/kaku_lock.sh D 1 off]"} */
Group LightSensor "Lichtmeter" Number LichtIntensiteit_Woonkamer "Lichtintensiteit woonkamer [%.1f]" (LightSensor) {exec="<[/home/pi/LightSensorBH1750/bh1750_2.sh:10000:]"} Number LightsOnIntensityThreshold "Lichtintensiteit waarbij lichten worden ingeschakeld [%.1f]" (LightSensor) // { exec="<[/bin/sh@@-c@@echo -n 24:60000:REGEX((.*?))]" } Number LightsEnableIntensityThreshold "Lichtintensiteit waarbij het automatisch inschakelen wordt geactiveerd [%.1f]" (LightSensor) //{ exec="<[/bin/sh@@-c@@echo -n 200:60000:REGEX((.*?))]" } DateTime BackoffTimer "Tijd waarop automatisch inschakelen wordt geactiveerd (indien nu inactief) [%1$tH:%1$tM]" (LightSensor) //{exec="<[/bin/sh@@-c@@uptime | awk '{ print $1 }':6000:REGEX((.*?))]"} Number AutoOnEnabled "Automatisch inschakelen is geactiveerd (0=nee, 1=ja) [%1d]" (LightSensor)
openhab.log:
root@raspberrypi:/etc/openhab/configurations# grep -E -i "(mapdb|quartz|genericitemprovider|^ )" /var/log/openhab/openhab.log | tail --lines 45 23:30:15.721 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl 23:30:15.723 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created. 23:30:15.732 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized. 23:30:15.740 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED' Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally. NOT STARTED. Currently in standby mode. Number of jobs executed: 0 Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 2 threads. Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered. 23:30:15.742 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler 'openHAB-job-scheduler' initialized from specified file: '/etc/openhab/quartz.properties' 23:30:15.745 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7 23:30:15.748 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started. 23:30:23.027 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider 'GenericItemProvider' has been added. class org.atmosphere.jersey.AtmosphereResourceConfigurator 23:30:31.647 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'mapdb.persist' 23:30:32.063 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'lamp1.items' 23:30:32.086 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lamp1.items' 23:30:32.122 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'lichtsensor.items' 23:30:32.128 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lamp1.items' 23:30:32.131 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lichtsensor.items' 23:30:32.159 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'sunset_with_offset_event.items' 23:30:32.162 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lamp1.items' 23:30:32.164 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lichtsensor.items' 23:30:32.167 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'sunset_with_offset_event.items' 23:30:32.203 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'datum.items' 23:30:32.206 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lamp1.items' 23:30:32.208 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'lichtsensor.items' 23:30:32.211 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'sunset_with_offset_event.items' 23:30:32.214 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'datum.items' 23:30:47.186 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_GF_Huiskamer_Achterdeur_Schemerlamp (Type=SwitchItem, State=Uninitialized)' with 'ExecGenericBindingProvider' reader. 23:30:47.194 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Light_GF_Huiskamer_Achter_Staandelamp (Type=SwitchItem, State=Uninitialized)' with 'ExecGenericBindingProvider' reader. 23:30:47.197 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'LichtIntensiteit_Woonkamer (Type=NumberItem, State=Uninitialized)' with 'ExecGenericBindingProvider' reader. 23:30:47.350 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Sunrise_Time (Type=DateTimeItem, State=Uninitialized)' with 'AstroGenericBindingProvider' reader. 23:30:47.458 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Sunset_Time (Type=DateTimeItem, State=Uninitialized)' with 'AstroGenericBindingProvider' reader. 23:30:47.477 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Sunset_with_Offset_Event (Type=SwitchItem, State=Uninitialized)' with 'AstroGenericBindingProvider' reader. 23:30:47.489 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Sunset_with_Offset_Event1 (Type=SwitchItem, State=Uninitialized)' with 'AstroGenericBindingProvider' reader. 23:30:47.495 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Sunset_minus_1hour (Type=SwitchItem, State=Uninitialized)' with 'AstroGenericBindingProvider' reader. 23:30:47.967 [DEBUG] [.m.i.MapDBPersistenceActivator:31 ] - MapDB persistence bundle has been started. 23:30:48.009 [DEBUG] [.p.m.i.MapDBPersistenceService:86 ] - mapdb persistence service activated 23:30:48.056 [WARN ] [.o.c.p.e.PersistenceExtensions:711 ] - There is no queryable persistence service registered with the name 'mapdb' 23:30:48.760 [DEBUG] [.p.m.i.MapDBPersistenceService:198 ] - Scheduled Commit-Job with interval 5sec. 23:30:48.767 [DEBUG] [.p.internal.PersistenceManager:147 ] - Initializing mapdb persistence service. 23:30:48.779 [DEBUG] [.p.internal.PersistenceManager:441 ] - Scheduled strategy mapdb.everyHour with cron expression 0 0 * * * ? 23:30:48.786 [DEBUG] [.p.internal.PersistenceManager:441 ] - Scheduled strategy mapdb.everyDay with cron expression 0 0 0 * * ?
