otto76
(Otto Swarche)
July 4, 2021, 9:37pm
1
Platform information:
Hardware: Rpi 3
OS: raspbian/docker [openhab/openhab:latest]
openHAB version: 3.1.0
Issue of the topic:
Mapping mqtt values at Channel level
Bridge mqtt:broker:mm2 [ host="xxx.xxx.xxx.xxx", port=1883, clientID="xxxx", secure=false, username="xxx", password="xxx" ]
Thing topic topic1 "name" @"obj" {
Channels:
Type switch: ch_topic1 "ch1" [stateTopic="mqtt/get/topic1", commandTopic="mqtt/set/topic1", ON=1, OFF=0]
} //broker:mm2
mqtt broker sees mqtt/set/topic1: ON
For some reason mapping from ON to 1 is not working
otto76:
ON=1, OFF=0
Watch your CAPS. This should say
on=1,off=0
otto76
(Otto Swarche)
July 5, 2021, 2:19pm
3
nop, cases do not help
Recrated image (latest), even cleared data folders. Issue still there
Rolled back to v3.0.2 and it seems to working again.
Cannot tell is it an issue of 3.1.0 docker image or it does not fully support file based config or something else. Now pulling back cofig data from git, will see result for all landscape
Anyway, for now 3.0.2 seems to working correctly. Will test a bit more
You may be hitting the bug where edits to Things files are not picked up by openHAB at save. Some people restart openHAB, I just do this .
Or yeah, might be a docker issue. All working fine for me installed in non-docker Ubuntu container, latest stable release 3.1 from apt.
I’m pretty sure you have to use quotes:
Channels:
Type switch: ch_topic1 "ch1" [stateTopic="mqtt/get/topic1", commandTopic="mqtt/set/topic1", on="1", off="0"]
} //broker:mm2
