Hi everybody,
in my setup i use the DMX Binding to control four Roomlights.
Switch Alles_Aus "Alles Aus" (Lighting, Global, gDashboard)
Switch Saallicht_Aus "Saallicht Aus" (Lighting, Global, gDashboard)
Switch Kneipe "Kneipe" (Lighting, Global, gDashboard)
Switch Alles_An "Alles 100%" (Lighting, Global, gDashboard)
/* Lighting */
Switch Fade_In_Fast "Fade In <<<" (Lighting, Global, gDashboard) {dmx="CHANNEL[1/4], ON[FADE|5000: 85, 0, 0, 0 :0|5000: 170, 85, 0, 0 :0|5000: 255, 170, 85, 0 :0|5000: 255, 255, 170, 85 :0|5000: 255, 255, 255, 170 :0|5000: 255, 255, 255, 255 :0|]"}
Switch Fade_In_Slow "Fade In <" (Lighting, Global, gDashboard) {dmx="CHANNEL[1/4], ON[FADE|10000: 85, 0, 0, 0 :0|10000: 170, 85, 0, 0 :0|10000: 255, 170, 85, 0 :0|10000: 255, 255, 170, 85 :0|10000: 255, 255, 255, 170 :0|10000: 255, 255, 255, 255 :0|]"}
Switch Fade_Out_Slow "Fade Out >" (Lighting, Global, gDashboard) {dmx="CHANNEL[1/4], ON[FADE|10000: 170, 255, 255, 255 :0|10000: 85, 170, 255, 255 :0|10000: 0, 85, 170, 255 :0|10000: 0, 0, 85, 170 :0|10000: 0, 0, 0, 85 :0|10000: 0, 0, 0, 0 :0|]"}
Switch Fade_Out_Fast "Fade Out >>>" (Lighting, Global, gDashboard) {dmx="CHANNEL[1/4], ON[FADE|5000: 170, 255, 255, 255 :0|5000: 85, 170, 255, 255 :0|5000: 0, 85, 170, 255 :0|5000: 0, 0, 85, 170 :0|5000: 0, 0, 0, 85 :0|5000: 0, 0, 0, 0 :0|]"}
/* DMX Adresse 1-6 auf Dimmer*/
Dimmer Saallicht1 "Spotreihe 1" (Saallicht, Lighting, gDashboard) {dmx="CHANNEL[1:1000]"}
Dimmer Saallicht2 "Spotreihe 2" (Saallicht, Lighting, gDashboard) {dmx="CHANNEL[2:1000]"}
Dimmer Saallicht3 "Spotreihe 3" (Saallicht, Lighting, gDashboard) {dmx="CHANNEL[3:1000]"}
Dimmer Saallicht4 "Spotreihe 4" (Saallicht, Lighting, gDashboard) {dmx="CHANNEL[4:1000]"}
So now i want to push one button which set all other buttons to off.
I.e. Switch “All OFF” ON --> Set DMX to 0 and all Buttons to OFF
My rule look like this:
rule "Alles Aus"
Item Alles_Aus changed from OFF to ON
postUpdate(Kneipe, OFF)
postUpdate(Alles_An, OFF)
postUpdate(Saallicht_Aus, OFF)
sendCommand(Saallicht1, 0)
sendCommand(Saallicht2, 0)
sendCommand(Saallicht3, 0)
sendCommand(Saallicht4, 0)
That works fine for me, but now i have fadetimes with 30sec and 60sec.
So i need a rule
Fade Out Slow (over 60secs) --> Switch DMX Item Fade 60secs to ON and All other to OFF / AFTER 60 secs set “Fade Out Slow” to OFF an “All off” to ON
Any idea?
