during the loading and initialisation of item, thing and rule files
I get a lot of mapping warnings. The map files are all in place and valid. Seems to be a timing issue. Is there any way to start mapping service first?
2022-08-06 15:54:14.338 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2022-08-06 15:54:22.514 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'LockHood' with pattern 'MAP(Kodiaqdoorlock.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.554 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'LED_3_program' with pattern 'MAP(led_preset.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.616 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'StateTop' with pattern 'MAP(KodiaqRoof.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.638 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorKHSTSwitch' with pattern 'MAP(Radiator.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.671 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorOGSwitch' with pattern 'MAP(Radiator.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.675 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'localTodayUVIndex' with pattern 'SCALE(owm.scale):%s': Couldn't transform value because transformation service of type 'SCALE' is not available.
2022-08-06 15:54:22.759 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorSwitch' with pattern 'MAP(RadiatorStatus.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:22.805 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'localTomorrowUVIndex' with pattern 'SCALE(owm.scale):%s': Couldn't transform value because transformation service of type 'SCALE' is not available.
2022-08-06 15:54:22.809 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'TyrePresRFCur' with pattern 'MAP(Kodiaqtyre.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
50 more Warnings
2022-08-06 15:54:23.722 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-08-06 15:54:23.743 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'localCurrentUVIndex' with pattern 'SCALE(owm.scale):%s': Couldn't transform value because transformation service of type 'SCALE' is not available.
2022-08-06 15:54:23.750 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'OpenLRDoor' with pattern 'MAP(Kodiaqdoorstate.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.784 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'LockLRDoor' with pattern 'MAP(Kodiaqdoorlock.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.811 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'StateRFWindow' with pattern 'MAP(Kodiaqwindow.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.817 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'TyrePresLRCur' with pattern 'MAP(Kodiaqtyre.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.822 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorVZSwitch' with pattern 'MAP(Radiator.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.828 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'TyrePresSPCur' with pattern 'MAP(Kodiaqtyre.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.855 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'localDay4UVIndex' with pattern 'SCALE(owm.scale):%s': Couldn't transform value because transformation service of type 'SCALE' is not available.
2022-08-06 15:54:23.898 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'LED_2_program' with pattern 'MAP(led_preset.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.913 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'TyrePresRRCur' with pattern 'MAP(Kodiaqtyre.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.917 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorBZKHSwitch' with pattern 'MAP(Radiator.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.928 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'LockRRDoor' with pattern 'MAP(Kodiaqdoorlock.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.933 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'RadiatorFBBZKHSwitch' with pattern 'MAP(Radiator.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.944 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'TyrePresSPDes' with pattern 'MAP(Kodiaqtyre.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:23.975 [WARN ] [rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'Zodiac_Sign' with pattern 'MAP(astro.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
2022-08-06 15:54:24.433 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WifiLed2.rules'
Thanks for your help.
br. Christian
