Platform information:
- Hardware:INTEL/4GIG/500GIG
- OS: UBUNTU
- openHAB version: 2.4 OPENHABAIN
Issue of the topic: I can’t use the mappings on my item as the system ignores the items file completely. it is for a Sonoff ifan2 with mqtt flashed with Tasmota .
- Items configuration related to the issue
Group MasterBedroom "Master Bedroom" <bedroom_red> (Home)
Switch MasterBedroom_Light_Ingan "Entrance Light" <light> (MasterBedroom) ["Lighting"] {mqtt=">[flatcntr:HoofSlaapKamer/relay/0/set:command:*:MAP(OFF0ON1.map)],<[flatcntr:HoofSlaapKamer/relay/0:state:MAP(0OFF1ON.map)]"}
Switch MasterBedroom_Light "Room Light" <light> (MasterBedroom) ["Lighting"] {mqtt=">[flatcntr:HoofSlaapKamer/relay/1/set:command:*:MAP(OFF0ON1.map)],<[flatcntr:HoofSlaapKamer/relay/1:state:MAP(0OFF1ON.map)]"}
Number MasterBedroom_Humidity "Humidity" <humidity> (MasterBedroom, gHumidity)
Number MasterBedroom_Temperature "Temperature" <temperature> (MasterBedroom, gTemperature)
Switch MasterBedroom_Fan_Light "Fan Light" <fan_ceiling> (MasterBedroom) {channel="mqtt:topic:mosquitto:MasterBedroom:Fan_Light"}
Number MasterBedroom_Fan_spd "Fan Speed" <fan_ceiling> mappings=[0=“Off”, 1=“Slow”, 2=“Med”, 3=“High”] (MasterBedroom) {channel="mqtt:topic:mosquitto:MasterBedroom:Fan_SPD"}
- Sitemap configuration related to the issue
sitemap flat1 label="flat1" {
Frame {
Group item=Bathroom
Group item=Speedtest
Group item=FamilyRoom
Group item=GuestRoom
Group item=HomeCinema
Group item=Hallway
Group item=Kitchen
Group item=MasterBedroom
Group item=Outside
Group item=Terrace
Group item=test
Group item=System
Group item=Alarm
Group item=Pool
Group item=Apple
Group item=gOpenWeatherMap
Group item=Astro
Group item=Sonoff
Frame {
Text label="Light" icon="light" {
Default item=Bathroom_Light label="Bathroom"
Default item=Corridor_Light label="Corridor"
Default item=FamilyRoom_Light label="Family Room"
Default item=GuestRoom_Light label="Guest Room"
Default item=Hallway_Light label="Hallway"
Default item=Kitchen_Light label="Kitchen"
Default item=MasterBedroom_Light label="Master Bedroom"
Default item=Outside_Light label="Outside"
Default item=Terrace_Light label="Terrace"
Text label="Fan" icon="fan_ceiling" {
Default item=Bathroom_Fan label="Bathroom"
Default item=FamilyRoom_Fan label="Family Room"
Default item=GuestRoom_Fan label="Guest Room"
Text label="Heating" icon="heating" {
Default item=Bathroom_Heating label="Bathroom"
Text label="Temperature" icon="temperature" {
Default item=Bathroom_Temperature label="Bathroom"
Default item=Corridor_Temperature label="Corridor"
Default item=FamilyRoom_Temperature label="Family Room"
Default item=GuestRoom_Temperature label="Guest Room"
Default item=Kitchen_Temperature label="Kitchen"
Default item=MasterBedroom_Temperature label="Master Bedroom"
Default item=Outside_Temperature label="Outside"
Text label="Humidity" icon="humidity" {
Default item=Bathroom_Humidity label="Bathroom"
Default item=Corridor_Humidity label="Corridor"
Default item=FamilyRoom_Humidity label="Family Room"
Default item=GuestRoom_Humidity label="Guest Room"
Default item=Kitchen_Humidity label="Kitchen"
Default item=MasterBedroom_Humidity label="Master Bedroom"
Default item=Outside_Humidity label="Outside"
- Services configuration related to the issue
MQtt 2.4
Bridge mqtt:broker:mosquitto "MQTT Broker" [ host="192.168.1.5", port=1883, clientid="openhab", secure=false]
Thing topic materbedroom "MasterBedroom"{
Channels:
Type switch : lamp "Main_Light" [ stateTopic="HoofSlaapKamer/relay/0:state", commandTopic="HoofSlaapKamer/relay/0/set" ]
Type switch : downlight "downlight" [ stateTopic="HoofSlaapKamer/relay/1:state", commandTopic="HoofSlaapKamer/relay/1/set" ]
Type number : temp "MasterBedroom Temp" [ stateTopic="HoofSlaapKamer/Temperature"]
Type number : humi "MasterBedroom Humidity" [ stateTopic="HoofSlaapKamer/Humidity"]
Type switch : Fan_Light "Fan on/off" [stateTopic="stat/sonoff_MBR_fan/POWER1", commandTopic="cmnd/sonoff_MBR_fan/power", transformationPattern="MAP:OFF0ON1.map" , on="ON", off="OFF"]
Type number : Fan_SPD "Fan Speed" [stateTopic="stat/sonoff_MBR_fan/RESULT", commandTopic="cmnd/sonoff_MBR_fan/FanSpeed"]
//Thing topic mything "Book_shelf"{
// Channels:
// Type switch : bookshelf "bookshels" [ stateTopic="Bookshelf/relay/0:state", commandTopic="HoofSlaapKamer/relay/0/set" ]
// Type switch : outside "outside" [ stateTopic="Bookshelf/relay/1:state", commandTopic="HoofSlaapKamer/relay/1/set" ]
Thing topic switch_healty "Swiches_Health"{
Channels:
Type string : sparebedroom_ver "Version" [ stateTopic="SpaarKamer/version" ]
Type string : sparebedroom_ip "IP" [ stateTopic="SpaarKamer/ip"]
Type string : sparebedroom_up "Up-time" [ stateTopic="SpaarKamer/uptime"]
vs code gives me a problem like this :
"resource": "/home/openhab/Desktop/Backups/05-04-2019/Edited/items/MasterBedroom.items",
"owner": "_generated_diagnostic_collection_name_#0",
"code": "org.eclipse.xtext.diagnostics.Diagnostic.Syntax",
"severity": 8,
"message": "missing EOF at 'mappings'",
"startLineNumber": 8,
"startColumn": 86,
"endLineNumber": 8,
"endColumn": 94
not sure what is to be done ? I have searched the forum. and came to this Topic. but looks like it is a dead topic. I tried to use this configs but still no luck.
