Hello all,
I get this error:
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.getState(JdbcBaseDAO.java:510) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.lambda$0(JdbcBaseDAO.java:344) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:345) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) ~[?:?]
2021-08-31 07:36:22.667 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.objectAsInteger(JdbcBaseDAO.java:540) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:340) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) [bundleFile:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) [bundleFile:?]
2021-08-31 07:36:23.097 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': null
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:344) ~[?:?]
2021-08-31 07:36:23.105 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-08-31 07:36:24.274 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.289 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.313 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.324 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.346 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.352 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.434 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.440 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:24.746 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': null
2021-08-31 07:36:24.763 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2021-08-31 07:36:26.748 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:26.755 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:27.219 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@bbffab': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
2021-08-31 07:36:27.226 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
here is my jdbc.cfg file
############################ JDBC Persistence Service ##################################
# I N S T A L L J D B C P E R S I S T E N C E S E R V I C E
# https://github.com/openhab/openhab/wiki/JDBC-Persistence
# Tested databases/url-prefix: jdbc:derby, jdbc:h2, jdbc:hsqldb, jdbc:mariadb, jdbc:mysql, jdbc:postgresql, jdbc:sqlite
# derby, h2, hsqldb, sqlite can be embedded,
# If no database is available it will be created, for example the url 'jdbc:h2:./testH2' creates a new DB in OpenHab Folder.
# Create new database, for example on a MySQL-Server use:
# CREATE DATABASE 'yourDB' CHARACTER SET utf8 COLLATE utf8_general_ci;
# D A T A B A S E C O N F I G
# Some URL-Examples, 'service' identifies and activates internally the correct jdbc driver.
# required database url like 'jdbc:<service>:<host>[:<port>;<attributes>]'
# url=jdbc:derby:./testDerby;create=true
# url=jdbc:h2:./testH2
# url=jdbc:hsqldb:./testHsqlDb
# url=jdbc:mariadb://192.168.0.1:3306/testMariadb
# url=jdbc:mysql://192.168.0.1:3306/testMysql
# url=jdbc:postgresql://192.168.0.1:5432/testPostgresql
# url=jdbc:sqlite:./testSqlite.db
url=jdbc:mariadb://localhost:3306/openhabian?serverTimezone=Europe/Berlin
# required database user
#reconnectCnt=0
user=xxxxxx
#waitTimeout=28800
# required database password
password=xxxxxxx
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL = VARCHAR(200)
#sqltype.COLOR = VARCHAR(70)
#sqltype.CONTACT = VARCHAR(6)
#sqltype.DATETIME = DATETIME
#sqltype.DIMMER = TINYINT
#sqltype.LOCATION = VARCHAR(30)
#sqltype.NUMBER = DOUBLE
#sqltype.ROLLERSHUTTER = TINYINT
#sqltype.STRING = VARCHAR(65500)
#sqltype.SWITCH = VARCHAR(6)
sqltype.STRING = VARCHAR(4096)
sqltype.IMAGE = BLOB
sqltype.LOCATION = VARCHAR(256)
#sqltype.string = VARCHAR(4096)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
#tableNamePrefix=Item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
#tableUseRealItemNames=
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
#tableIdDigitCount=
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
#rebuildTableNames=true
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
#enableLogTime=true
