Massive LazyLinkingResource errors in logfile
I’m using OH for a while now on an Odroid-U3. In the last days I more and more often have the following strange errors in my logfile. Once they were gone after a reboot, but now they are back and rebooting does not do the trick. Those Errormessages are hundreds of lines long between normal log messages and I don’t have any idea about the reason. However - OH seems to work and I can switch my devices etc…
Any hints? Memory leaks? SSD-Card-Errors?
This is the logfile from starting OH until the first error:
2015-08-19 10:02:25.283 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.1).
2015-08-19 10:02:28.387 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2015-08-19 10:02:28.506 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2015-08-19 10:02:33.319 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2015-08-19 10:02:39.757 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
2015-08-19 10:02:40.143 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
2015-08-19 10:02:43.453 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2015-08-19 10:02:44.251 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2015-08-19 10:02:44.354 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist'
2015-08-19 10:02:44.365 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2015-08-19 10:02:44.515 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'heating.rules'
2015-08-19 10:02:45.012 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'info.rules'
2015-08-19 10:02:45.132 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'scene.rules'
2015-08-19 10:02:45.195 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'call.rules'
2015-08-19 10:02:45.232 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'presence.rules'
2015-08-19 10:02:45.334 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'light.rules'
2015-08-19 10:02:45.406 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'shadow.rules'
2015-08-19 10:02:45.451 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'info.items'
2015-08-19 10:02:45.558 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'settings.items'
2015-08-19 10:02:45.575 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.items'
2015-08-19 10:02:45.606 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2015-08-19 10:02:45.635 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'home.items'
2015-08-19 10:02:45.687 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'scene.items'
2015-08-19 10:02:45.708 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'charts.items'
2015-08-19 10:02:49.697 [INFO ] [o.harmonyhub.HarmonyHubGateway] - HarmonyHub gateway activated
2015-08-19 10:02:50.701 [INFO ] [rg.openhab.io.cv.CVApplication] - Started Cometvisu API at /services/cv
2015-08-19 10:02:57.520 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
2015-08-19 10:03:02.912 [INFO ] [.service.AbstractActiveService] - FritzBox refresh Service has been started
2015-08-19 10:03:02.915 [INFO ] [o.b.f.internal.FritzboxBinding] - Fritzbox conditional deActivate: true
2015-08-19 10:03:02.921 [INFO ] [o.b.f.internal.FritzboxBinding] - Attempting connection to FritzBox on fritz.box:1012...
2015-08-19 10:03:02.932 [INFO ] [o.b.f.internal.FritzboxBinding] - Connected to FritzBox on fritz.box:1012
2015-08-19 10:03:03.798 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service (UUID = ************************************, base URL = http://localhost:8080)
2015-08-19 10:03:05.388 [ERROR] [e.x.l.lazy.LazyLinkingResource] - resolution of uriFragment 'xtextLink_::0.1.0.2::0::/1' failed.
java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Lorg.eclipse.emf.common.notify.Adapter;
	at org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eBasicAdapterArray(MinimalEObjectImpl.java:588) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eContainerAdapterArray(BasicEObjectImpl.java:1659) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.setData(MinimalEObjectImpl.java:476) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.common.util.ArrayDelegatingEList.addUnique(ArrayDelegatingEList.java:388) ~[org.eclipse.emf.common_2.8.0.v20130125-0546.jar:na]
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301) ~[org.eclipse.emf.common_2.8.0.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.util.EContentAdapter.addAdapter(EContentAdapter.java:349) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:219) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:182) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:497) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:1) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.common.util.ArrayDelegatingEList.addUnique(ArrayDelegatingEList.java:389) ~[org.eclipse.emf.common_2.8.0.v20130125-0546.jar:na]
	at org.eclipse.xtext.common.types.access.JvmTypeChangeDispatcher.requestNotificationOnChange(JvmTypeChangeDispatcher.java:79) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImplCustom.requestNotificationOnChange(JvmDeclaredTypeImplCustom.java:188) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImplCustom.internalGetAllFeaturesMap(JvmDeclaredTypeImplCustom.java:172) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImplCustom.internalGetAllFeaturesMap(JvmDeclaredTypeImplCustom.java:160) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImplCustom.getAllFeaturesMap(JvmDeclaredTypeImplCustom.java:148) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.common.types.impl.JvmDeclaredTypeImplCustom.findAllFeaturesByName(JvmDeclaredTypeImplCustom.java:99) ~[org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.AbstractStaticMethodsFeatureForTypeProvider.collectFeatures(AbstractStaticMethodsFeatureForTypeProvider.java:72) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.AbstractStaticMethodsFeatureForTypeProvider.getFeaturesByName(AbstractStaticMethodsFeatureForTypeProvider.java:49) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.DefaultJvmFeatureDescriptionProvider.getFeaturesByName(DefaultJvmFeatureDescriptionProvider.java:137) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.DefaultJvmFeatureDescriptionProvider.doCollectDescriptions(DefaultJvmFeatureDescriptionProvider.java:120) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.DefaultJvmFeatureDescriptionProvider.getDescriptionsByName(DefaultJvmFeatureDescriptionProvider.java:101) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.LazyJvmFeatureScopeStrategy.getDescriptionsByName(LazyJvmFeatureScopeStrategy.java:42) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.LazyJvmFeatureScope.getLocalElementsByName(LazyJvmFeatureScope.java:45) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.FilteredDelegatingScope.getLocalElementsByName(FilteredDelegatingScope.java:59) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.featurecalls.FilteredDelegatingScope.getElements(FilteredDelegatingScope.java:105) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.scoping.DelegatingScope.getLocalElementsByName(DelegatingScope.java:50) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.scoping.impl.AbstractScope.getElements(AbstractScope.java:128) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.scoping.impl.AbstractScope.getElements(AbstractScope.java:131) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.linking.BestMatchingJvmFeatureScope.getSingleElement(BestMatchingJvmFeatureScope.java:77) ~[org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:121) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:179) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource.access$0(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:239) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:124) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource.getEObject(XbaseResource.java:237) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:197) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:257) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1473) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.getFeature(XAbstractFeatureCallImpl.java:175) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.eGet(XAbstractFeatureCallImpl.java:434) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.impl.XFeatureCallImpl.eGet(XFeatureCallImpl.java:224) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:998) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource.trackResolution(XbaseResource.java:202) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.XbaseResource.getFeature(XbaseResource.java:187) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.resource.LinkingAssumptions.getFeature(LinkingAssumptions.java:120) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.impl.FeatureCallToJavaMapping.getFeature(FeatureCallToJavaMapping.java:60) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.impl.FeatureCallToJavaMapping.getActualReceiver(FeatureCallToJavaMapping.java:44) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:656) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_51]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_51]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_51]
	at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_51]
	at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
	at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) [org.openhab.model.script_1.7.1.jar:na]
	at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:53) [org.openhab.model.script_1.7.1.jar:na]
	at org.openhab.model.rule.internal.engine.RuleContextHelper.getContext(RuleContextHelper.java:71) [org.openhab.model.rule_1.7.1.jar:na]
	at org.openhab.model.rule.internal.engine.RuleEngine.executeRule(RuleEngine.java:307) [org.openhab.model.rule_1.7.1.jar:na]
	at org.openhab.model.rule.internal.engine.RuleEngine.stateChanged(RuleEngine.java:173) [org.openhab.model.rule_1.7.1.jar:na]
	at org.openhab.core.items.GenericItem.notifyListeners(GenericItem.java:112) [org.openhab.core_1.7.1.jar:na]
	at org.openhab.core.items.GenericItem.setState(GenericItem.java:100) [org.openhab.core_1.7.1.jar:na]
	at org.openhab.core.persistence.internal.PersistenceManager.initialize(PersistenceManager.java:388) [org.openhab.core.persistence_1.7.1.jar:na]
	at org.openhab.core.persistence.internal.PersistenceManager.initializeItems(PersistenceManager.java:212) [org.openhab.core.persistence_1.7.1.jar:na]
	at org.openhab.core.persistence.internal.PersistenceManager.startEventHandling(PersistenceManager.java:184) [org.openhab.core.persistence_1.7.1.jar:na]
	at org.openhab.core.persistence.internal.PersistenceManager.addPersistenceService(PersistenceManager.java:150) [org.openhab.core.persistence_1.7.1.jar:na]
	at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:376) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:444) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.InstanceProcess.dynamicBind(InstanceProcess.java:416) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:334) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
	at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
	at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
Thanks & best regards
Ollie
Same here on Raspberry Pi 2 with OH 1.7.1:
2015-08-25 22:45:06.669 [ERROR] [e.x.l.lazy.LazyLinkingResource] - resolution of uriFragment 'xtextLink_::0.2.1.2.0.0.0.7::0::/1' failed.
    at org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eBasicAdapterArray(MinimalEObjectImpl.java:588) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na] ...
If the system starts with this error, rebooting helps and if the system starts without this error it won’t come up during normal operation …
I have this issue first seen with OH 1.6.x
Anybody else has this problem?
Last night I found out, that it seems to be a problem with the db4o persistence addon. I did not go deeper into this yet, but I suppose to remove this, if you have those problems, too.
If you meant me: I don’t even use db4o persistence … but therefore rrd4j.
I’m seeing this issue again:
error message was present in 1.7.1, disappeared in 1.8.0, is back now since upgrading to 1.8.1.
Update:
Issue was closed and set to wont fix because it only occurs randomly and is not reproducible.
Since my upgrade from 1.7. to 1.8.3 I got the same error…
Did anyone get into this in the meantime?
No:
Ok, but it looks like the source is a non existing item in the items list, right? Or insn’t even this confirmed?
Don’t think so, the user has withdrawn his comment about that:
Edited 22. April 2016
I withdraw my comment.  The error really seems not reproducable.  Today I restarted openHAB:
1x with missing item -> NO error occured
1x w/o missing item ->  NO error occured
Sorry for the confusion.
I recommend to remove all bindings and reactivate them step by step. This helped me at least to find the binding that causes the problem.
