First of all special thx to @tailor for his idea for the widget to control sonos speaker.
Based on this widget, i created my own widget to control my Bose Soundtouch Multiroom System.
Now i woud like to create a Widget to controle the Volume levels of all Soundtouch devices with one Slider.
My Problem: For example i set the volume of Esszimmer to 30% and the Volume of Wohnzimmer to 15%.
When i Group the Volume items and connect them to a masterslider, all volume levels will have the same Value after touching the slider.
Has someone an Idea how to controll all levels with one slider?
Masterslider down 5% --> Esszimmer 25%, Wohnzimmer 10%
Masterslider up 10% --> Esszimmer 35%, Wohnzimmer 20%
Use a dummy slider
In a change rule detect the difference between previousState and newState
Pass the difference to the sliders in a forEach loop for the group
rule "Change all Dimmers"
Item MasterDimmer changed
var previousValue = MasterDimmer.previousState as Number
var newValue = MasterDimmer.state as Number
var Difference = newValue - previousValue
DimmerGroup.forEach( i | i.sendCommand((i.state as Number) + Difference))
The different Dimmers should be dimmer items and put in the DimmerGroup group
Hello Sorry … maybe I am not clear enough … actually quite new on openhab and specially the idea to control also my bose soundtouch group.
Maybe my questions in at least my logical order .
Which Bose binding to be used
My status : right now I am using Ver 2.3 coming with stable Openhab disty 2.3
I managed to get it running : Volume , Mute ON/OFF working … but could not figure out how to send Player Control ( either from Basic UI or using Custom Widget downloaded from HabPanel)
Which widget is best to use , I so the example on top of this threat … which looks exactly like i was planning to set it up …
Maybe my last one … how to handle the zone control in best way
Sorry for many question … even I dont know if its right place to raise.
Thx
