Dear all,
I would like to use non openhab icons such as material and f7 but integrate state dependend colors for openhab default widgets (e.g. oh-label-item). Can I somehow realize this using the color option within the widget and if yes, how would this look like?
Thanks for help or proper hint to doc - I could not find the right thing even though searching for it.
I tried copying such codes from custom widgets already but have not got it working, so I was not sure if this works at all. Is there anything special needed, like “CODE” instead of CODE via Main UI (OH 3.3)?
Does anyone has a working example to start with - then there are tons of examples our there of course.
This kind of expression (test) ? "if true" : "if false" is called a ternary expression and your format appears correct. This won’t change the icon color, however, because as the moment the property you’re using is color which in the toggle widgets changes the color that the toggle’s background becomes when switched on. You correctly use the iconColor property in the second widget.
If that still doesn’t work, then you need to examine your assumption about the the state of the Abwesenheit_Timer item. Does it ever actually equal the string "true". For testing just add another item widget to the list, this time a label item to show you what state the item actually has as far as the widget editor is concerned:
- component: oh-label-item
title: State test
item: Abwesenheit_Timer
