@pmpkk Nice work! Thanks for sharing!
Fantastic template!
However struggeling to get the SVG icons displayed. All files are at the right place… Also tried the tvAppIcons.svg file you provided, but the icons just arent painted. What am I doing wrong? Any hint? Any chance that you upload your complete template?
Did you purchase the icons that are mentioned in first post?
I want to manage the dashboard html directly and not via the habpanel web interface.
Where is the location of the dashboard html files?
Can you provide a file structure example (as requested here) that could then be backed up and restore?
Thanks,
Avner
I know that you purchased them.
This post was a question, to @coasting, who had problems with the icons.
I realized after I hit send
Hi All,
I have successfully added the themes.css to my HabPanel. pmpkk, thanks again for sharing.
I know pmpkk has bought the custom icons, but I’m trying to add my own custom icons and I cannot figure out what this statement in the original post mean:
- Is “svg viewBox = xxxx” is the size of the icon?
- What does “/static/button.svg#thermometer” mean? Is the icon name button.svg? if so what does #thermometer mean?
- How will the folder structure for this icon look like?
- If I can get my custom icons to display, can I also use the smarthome-set (widget-icon iconset=“‘smarthome-set’” icon=“‘temperature’” size=“60”) for some of the other icons?
Hey,
I’m putting together a tutorial on how to add your own icons to the theme, stay tuned.
In the meantime:
In a single svg file you can have many symbols (or icons). They are accessed via an id. If you open the svg file (for example the tvAppIcons file) you will see the different symbols identified by id. Those ids are the ones after the hashtag.
The view box attribute is used to specify the size of the drawing board in respect to the paths/objects. When displayed in HTML they can be sized by CSS to any size.
I meanwhile managed it. The SVG file(s) need to have a specific structure, as coloring of the SVG icons is done in theme.css by means of STROKE or FILL parameters. Here below is a basic sprite SVG file using some SVG icons from the Smart House Icon Set (Roman Malashkov https://dribbble.com/shots/2084609-Smart-House-Icon-Set-Free). You can edit the SVG sprites with a editor like Notepad++.
Hope same is of help to others facing the same problem.
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg version="1.1" id="Layer_1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" x="0px" y="0px"
viewBox="0 0 48 48" enable-background="new 0 0 48 48" xml:space="preserve">
<symbol id="drop">
<g>
<path d="M4,20 C4,13.7372206 9.31149107,10.9606699 15.0029824,1.68773079 C15.5,1 16.5,1 17.0240493,1.73848329 C22.7239959,11.0422428 28,13.7458429 28,20 C28,26.627417 22.627417,32 16,32 C9.372583,32 4,26.627417 4,20 Z M14.9662304,5.01303063 C12.6849824,7.94803148 7.55258291,15.1489689 7.43611882,15.3380026 C6.44520133,16.9463678 6,18.343598 6,20 C6,25.5228475 10.4771525,30 16,30 C21.5228475,30 26,25.5228475 26,20 C26,18.34381 25.5574243,16.9556938 24.5697394,15.3573542 C24.4844847,15.2193893 19.3264043,7.97081698 17.0502563,5.01835622 C16.4935872,4.29628389 15.5249676,4.2941722 14.9662304,5.01303063 Z M16,27.5447247 C16,28.0447247 15.2619671,28.0225103 14.9257293,27.9794225 C11.3214673,27.5175477 8.46745417,24.6572016 8.01523409,21.0499283 C7.98381871,20.7993338 7.95268975,20 8.45268973,20 C8.95268972,20 9.03600925,21.1280442 9.03600925,21.1280442 C9.50185782,24.1265527 11.8708617,26.4955566 14.8693702,26.9614051 C14.8693702,26.9614051 16,27.0447247 16,27.5447247z">
</path>
</g>
</symbol>
<symbol id="power">
<g>
<path d="M16,32 C24.836556,32 32,24.836556 32,16 C32,7.163444 24.836556,0 16,0 C7.163444,0 0,7.163444 0,16 C0,24.836556 7.163444,32 16,32 L16,32 Z M16,30 C8.2680135,30 2,23.7319865 2,16 C2,8.2680135 8.2680135,2 16,2 C23.7319865,2 30,8.2680135 30,16 C30,23.7319865 23.7319865,30 16,30 L16,30 Z M12.2575393,17.7112593 L12.1868707,17.7112593 C11.0779698,17.7112593 10.6478221,16.9467914 11.2212184,16.0037726 L16.4805582,7.35415962 C17.67876,5.38357359 18.0624739,5.55948915 17.3376772,7.746963 L15.7252918,12.6132252 C15.3772095,13.6637556 15.9942825,14.5048291 17.0992511,14.5048291 L20.1977772,14.5048291 L20.1846183,14.5177121 L20.2552868,14.5177121 C21.3641878,14.5177121 21.7943355,15.2821799 21.2209392,16.2251988 L16.1844844,24.5082506 C14.864477,26.6791606 14.4411534,26.4839632 15.241777,24.0676402 L16.7168658,19.6157462 C17.0649481,18.5652158 16.447875,17.7241422 15.3429064,17.7241422 L12.2443804,17.7241422 L12.2575393,17.7112593 L12.2575393,17.7112593z">
</path>
</g>
</symbol>
<symbol id="sun">
<g>
<path d="M10.7878017,28.5833599 L10.7878017,28.5833599 C9.97956177,28.2485759 9.4161758,28.2142601 8.29387705,28.3294851 C7.147197,28.4472132 6.68503398,28.4437606 5.9948931,28.1848231 C5.52665568,28.0091428 5.09503731,27.7224543 4.6862915,27.3137085 C4.27754569,26.9049627 3.99085724,26.4733443 3.81517687,26.0051069 C3.55623942,25.314966 3.55278681,24.852803 3.67051494,23.706123 C3.78573987,22.5838242 3.75142407,22.0204382 3.41664014,21.2121983 C3.15165448,20.5724663 2.80939234,20.1202916 2.29849594,19.6618451 C2.19130602,19.5656595 2.07903528,19.4706346 1.92664559,19.3458637 C1.99434961,19.4012972 1.62189171,19.0978662 1.52833472,19.0196686 C0.480903976,18.1441953 0,17.3440478 0,16 C0,14.6559522 0.480903976,13.8558047 1.52833472,12.9803314 C1.62189171,12.9021338 1.99434961,12.5987028 1.92664559,12.6541363 C2.07903528,12.5293654 2.19130602,12.4343405 2.29849594,12.3381549 C2.80939234,11.8797084 3.15165448,11.4275337 3.41664014,10.7878017 C3.75142407,9.97956177 3.78573987,9.4161758 3.67051494,8.29387705 C3.55278681,7.147197 3.55623942,6.68503398 3.81517687,5.9948931 C3.99085724,5.52665568 4.27754569,5.09503731 4.6862915,4.6862915 C5.09503731,4.27754569 5.52665568,3.99085724 5.9948931,3.81517687 C6.68503398,3.55623942 7.147197,3.55278681 8.29387705,3.67051494 C9.4161758,3.78573987 9.97956177,3.75142407 10.7878017,3.41664014 C11.4275337,3.15165448 11.8797084,2.80939234 12.3381549,2.29849594 C12.4343405,2.19130602 12.5293654,2.07903528 12.6541363,1.92664559 C12.5987028,1.99434961 12.9021338,1.62189171 12.9803314,1.52833472 C13.8558047,0.480903976 14.6559522,0 16,0 C17.3440478,0 18.1441953,0.480903976 19.0196686,1.52833472 C19.0978662,1.62189171 19.4012972,1.99434961 19.3458637,1.92664559 C19.4706346,2.07903528 19.5656595,2.19130602 19.6618451,2.29849594 C20.1202916,2.80939234 20.5724663,3.15165448 21.2121983,3.41664014 C22.0204382,3.75142407 22.5838242,3.78573987 23.706123,3.67051494 C24.852803,3.55278681 25.314966,3.55623942 26.0051069,3.81517687 C26.4733443,3.99085724 26.9049627,4.27754569 27.3137085,4.6862915 C27.7224543,5.09503731 28.0091428,5.52665568 28.1848231,5.9948931 C28.4437606,6.68503398 28.4472132,7.147197 28.3294851,8.29387705 C28.2142601,9.4161758 28.2485759,9.97956177 28.5833599,10.7878017 C28.8483455,11.4275337 29.1906077,11.8797084 29.7015041,12.3381549 C29.808694,12.4343405 29.9209647,12.5293654 30.0733544,12.6541363 C30.0056504,12.5987028 30.3781083,12.9021338 30.4716653,12.9803314 C31.519096,13.8558047 32,14.6559522 32,16 C32,17.3440478 31.519096,18.1441953 30.4716653,19.0196686 C30.3781083,19.0978662 30.0056504,19.4012972 30.0733544,19.3458637 C29.9209647,19.4706346 29.808694,19.5656595 29.7015041,19.6618451 C29.1906077,20.1202916 28.8483455,20.5724663 28.5833599,21.2121983 C28.2485759,22.0204382 28.2142601,22.5838242 28.3294851,23.706123 C28.4472132,24.852803 28.4437606,25.314966 28.1848231,26.0051069 C28.0091428,26.4733443 27.7224543,26.9049627 27.3137085,27.3137085 C26.9049627,27.7224543 26.4733443,28.0091428 26.0051069,28.1848231 C25.314966,28.4437606 24.852803,28.4472132 23.706123,28.3294851 C22.5838242,28.2142601 22.0204382,28.2485759 21.2121983,28.5833599 C20.5724663,28.8483455 20.1202916,29.1906077 19.6618451,29.7015041 C19.5656595,29.808694 19.4706346,29.9209647 19.3458637,30.0733544 C19.4012972,30.0056504 19.0978662,30.3781083 19.0196686,30.4716653 C18.1441953,31.519096 17.3440478,32 16,32 C14.6559522,32 13.8558047,31.519096 12.9803314,30.4716653 C12.9021338,30.3781083 12.5987028,30.0056504 12.6541363,30.0733544 C12.5293654,29.9209647 12.4343405,29.808694 12.3381549,29.7015041 C11.8797084,29.1906077 11.4275337,28.8483455 10.7878017,28.5833599 L10.7878017,28.5833599 Z M11.1704851,27.6594803 C13.8221355,28.7578299 13.5852426,31 16,31 C18.4147574,31 18.1778645,28.7578299 20.8295149,27.6594803 C23.4811653,26.5611308 24.8991104,28.3140931 26.6066017,26.6066017 C28.3140931,24.8991104 26.5611308,23.4811653 27.6594803,20.8295149 C28.7578299,18.1778645 31,18.4147574 31,16 C31,13.5852426 28.7578299,13.8221355 27.6594803,11.1704851 C26.5611308,8.51883469 28.3140931,7.10088964 26.6066017,5.39339828 C24.8991104,3.68590692 23.4811653,5.43886924 20.8295149,4.34051967 C18.1778645,3.2421701 18.4147574,1 16,1 C13.5852426,1 13.8221355,3.2421701 11.1704851,4.34051967 C8.51883469,5.43886924 7.10088964,3.68590692 5.39339828,5.39339828 C3.68590692,7.10088964 5.43886924,8.51883469 4.34051967,11.1704851 C3.2421701,13.8221355 1,13.5852426 1,16 C1,18.4147574 3.2421701,18.1778645 4.34051967,20.8295149 C5.43886924,23.4811653 3.68590692,24.8991104 5.39339828,26.6066017 C7.10088964,28.3140931 8.51883469,26.5611308 11.1704851,27.6594803 L11.1704851,27.6594803 Z M16,26 C10.4771525,26 6,21.5228475 6,16 C6,10.4771525 10.4771525,6 16,6 C21.5228475,6 26,10.4771525 26,16 C26,21.5228475 21.5228475,26 16,26 L16,26 Z M16,24 C20.418278,24 24,20.418278 24,16 C24,11.581722 20.418278,8 16,8 C11.581722,8 8,11.581722 8,16 C8,20.418278 11.581722,24 16,24 L16,24z">
</path>
</g>
</symbol>
</svg>
I like also the glowing battery icon you did.
Any hint how that one can be done
@pmpkk, I got stucked at step 5.
I did first 4 steps completed successfully. Then how to move it further.
Give the client id and secret to OpenHab
Save the Client ID to spotify_client_id in OpenHab (e.g. through openhab CLI smarthome:update spotify_client_id {your_id})
Copy the Client Secret to spotify_client_secret in OpenHab (e.g. through the rest API)
Here how to give Client ID to spotify_client_id and Client Secret to spotify_client_secret in openhab.
Please guide me how to move forward it.
1 Word:
Waauw !
now an interface for the app like this
3 options:
1, use REST UI:
Make sure you have the REST UI installed (it’s an add-on), then go to the REST UI, and set the state:
http://demo.openhab.org:8080/doc/index.html
2, REST CURL
3, use CLI (command line interface):
http://docs.openhab.org/administration/console.html
command is:
Hope this helps!
I uploaded a new version of the theme into GitHub with detailed instructions on how to install, create the SVGs, etc.:
Hope this helps. Let me know if you have more questions or suggestions for improvements!
@pmpkk Thanks a lot Patrick! i appreciate the time and effort!..
Cheers from Colombia!
Hey Patrick,
i really like your theme.
I want to integrate the svg icons from here:
https://www.materialdesignicons.com/
But to be honest: svg is yet not my friend. Could you give me a little advice how to embed this icons?
Cheers,Nic
Sorry for the noobs question, but your guide says:
7. Test spotify.py in SSH
* Set the REDIRECT_URI in spotify.py to the right value
* Run this in terminal /usr/bin/python /etc/openhab2/scripts/spotify.py
How do I find my REDIRECT_URI?
Thanks so much for sharing!
The redirect uri is the full URL of the location of this page:
http://openhabianpi.local:8080/static/spotify-auth.html
But this depends on the IP or domain name of your set up. In the example above, openhab runs on a Raspberry Pi and this is the default domain name.
You may replace “openhabianpi.local:8080” with the domain of your openhab instance.
Makes sense?
Hi @pmpkk
As others have said this looks awesome. My only constructive criticism so far would be to ask you to exploit the use of config items in your custom widgets so that it is not all hardcoded.
