Matter Binding (Marketplace, Deprecated)
Yes, sometimes openHAB doesn’t complete shutdown after 60 seconds and it’s killed.
There’s a new Jar with Electrical Measurement support, since i don’t have a device to test with, its likely something won’t work, but give it a shot and let me know how it goes.
There are also other behind the scene changes including upstream matter.js updates, deserialization improvements, Lighting fixes and general quality improvements.
To update, we have to uninstall and install again from marketplace?
I have no idea :confused: I pushed a new jar, and updated the first post, not sure what else i need to do ?
That’s how I did it (uninstall/install) and it worked :grinning:
Swear to god, the updates always come out when I’m out of home xD soooo looking forward to testing this out.
Ohh lookie lookie!
@digitaldan this is weird, notice the root node. Not entirely certain from where that information comes from…
Should all devices provide the signal strength or does it depend on the oem? I have currently three devices but only one provides that information.
Dan, I still of the “ON/OFF” Problem with my lights.
  • I have two lights, on of which I removed as a thing and rescanned it to see if anything new comes up. The thing is discovered and I added it (it reuses the channel setup I had before=
  • Then the THING stays in “NOT YET READY” but it does “work” somehow. It sends and receives data (see logs below), however the state doesn’t become ONLINE.
  • The main problem is that switching on via an ITEM doesn’t work because when switching off via the item it, it does switch of the light but then immediately sets the status back to ON (but the light stays OFF).
  • I did the whole actions that I present below all while the Thing is “not yet ready”
  • Only after that I stopped the Thing and restarted it and after that it went ONLINE and stayed as such ever since.
  • After that the item was OFF (as the light). I switched it ON via the the item, the light goes on. I switch the item OFF, the light goes OFF and then the item immediately goes back to ON (like above).
I am on version installed via the marketplace today
375 │ Active │ 80 │ 4.3.0.202501161730 │ openHAB Add-ons :: Bundles :: Matter Binding
Here are the details of the setup
Thing Definition
UID: matter:node:012d8d3e09:9976085064129733980
label: WZ Nanoleaf Cono1
thingTypeUID: matter:node_9976085064129733980
configuration:
  nodeId: "9976085064129733980"
bridgeUID: matter:controller:012d8d3e09
channels:
  - id: 1#colorcontrol-temperature-abs
    channelTypeUID: matter:colorcontrol-temperature-abs
    label: Color Temperature
    configuration: {}
  - id: 1#colorcontrol-color
    channelTypeUID: matter:colorcontrol-color
    label: Color Control
    configuration: {}
    configuration: {}
Item definition:
label: WZ Nanoleaf Cono 1 Power
type: Switch
category: ColorLight
groupNames:
  - GF_IndirectLights
  - WZLichter
tags:
  - Point
linked to Channel:
Color Control
NOT YET READY
WZ Nanoleaf Cono1
matter:node:012d8d3e09:9976085064129733980:1#colorcontrol-color (Color)
I first removed the Thing, then I rediscovered it and tried to use the switch with on and off which is shown in the following logs, but see a more systematic approach further down below
 16:10:15.241 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23582 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:15.241 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23582/176008512 type: 0x1/0x5 reqAck size: 11 payload: 15260038d0dd5324ff0b18
 16:10:15.242 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 empty msgId: 24187/23582/51644788 type: 0x1/0x1 acked: 176008512 reqAck size: 8 payload: 1524000024ff0c18
 16:10:15.334 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23582/176008513 type: 0x0/0x10 acked: 51644788
 16:10:18.290 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:89d0:396b:b951:506f:5540 on session secure/24188 protocol: 1 exId: 12781 sess: secure/24188 peerSess: 24188 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:18.290 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24188/12781/183250035 type: 0x1/0x5 reqAck size: 11 payload: 152600eb96257f24ff0b18
 16:10:18.291 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 2133169899 empty msgId: 24188/12781/107775222 type: 0x1/0x1 acked: 183250035 reqAck size: 8 payload: 1524000024ff0c18
 16:10:18.336 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24188/12781/183250036 type: 0x0/0x10 acked: 107775222
 16:10:21.392 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Nanoleaf_Cono_1_Power' received command ON
 16:10:21.392 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Nanoleaf_Cono_1_Power' predicted to become OFF
 16:10:21.511 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:10:21.512 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Nanoleaf_Cono_1_Power' changed from OFF to ON
 16:10:21.521 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:10:21.396 [DEBUG] [ontroller.devices.types.LightingType] - Handling command for channel: matter:node:012d8d3e09:9976085064129733980:1#colorcontrol-color
 16:10:21.397 [DEBUG] [al.controller.MatterControllerClient] - sendMessage: {"id":"1ff75d4c-ff80-4973-be98-d9dfbbd6b216","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","on",{}]}
 16:10:21.399 [TRACE] [MatterWebsocketService] - Controller: Received request: {"id":"1ff75d4c-ff80-4973-be98-d9dfbbd6b216","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","on",{}]}
 16:10:21.400 [TRACE] [MatterWebsocketService] - ClientController: Executing function clusters.command(["9976085064129733980",1,"OnOff","on",{}])
 16:10:21.400 [TRACE] [MatterWebsocketService] - Clusters: command 9976085064129733980 1 OnOff on {}
 16:10:21.401 [TRACE] [MatterWebsocketService] - InteractionClient: Invoking command: 0x1/OnOff(0x6)/on(0x1) with "undefined"
 16:10:21.401 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 42582 sess: secure/24187 peerSess: 59083 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:21.402 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/InvokeRequest msgId: 59083/42582/51644789 type: 0x1/0x8 reqAck size: 29 payload: 1528002801360215370024000124010624020118350118181824ff0c18
 16:10:21.488 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/InvokeResponse msgId: 24187/42582/176008514 type: 0x1/0x9 acked: 51644789 reqAck size: 33 payload: 152800360115350137002400012401062402011835012400001818181824ff0b18
 16:10:21.489 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: SC/StandaloneAck msgId: 59083/42582/51644790 type: 0x0/0x10 acked: 176008514
 16:10:21.490 [TRACE] [MatterWebsocketService] - matter: Sending response: {"type":"response","message":{"type":"resultSuccess","id":"1ff75d4c-ff80-4973-be98-d9dfbbd6b216","result":"undefined","error":"undefined"}}
 16:10:21.490 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"response","message":{"type":"resultSuccess","id":"1ff75d4c-ff80-4973-be98-d9dfbbd6b216","result":"undefined","error":"undefined"}}
 16:10:21.492 [DEBUG] [al.controller.MatterControllerClient] - result type: resultSuccess
 16:10:21.501 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23583 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:21.502 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23583/176008515 type: 0x1/0x5 reqAck size: 118 payload: 15260038d0dd5336011535012600a7c5200e370124020124030624040018290218181535012600a7c5200e37012402012403062504004018290218181535012600a7c5200e3701240201240306250402401824020018181535012600bfd79dc937012402012403082404001824020118181824ff0b18
 16:10:21.503 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 4 msgId: 24187/23583/51644791 type: 0x1/0x1 acked: 176008515 reqAck size: 8 payload: 1524000024ff0c18
 16:10:21.504 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = true (version=237028775)
 16:10:21.506 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to true (changed: true)
 16:10:21.507 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028775,"value":true}
 16:10:21.507 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028775,"value":true}}}
 16:10:21.508 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028775,"value":true}}}
 16:10:21.508 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028775,"value":true}
 16:10:21.509 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/globalSceneControl(0x4000) = true (version=237028775)
 16:10:21.509 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:21.509 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/offWaitTime(0x4002) = 0 (version=237028775)
 16:10:21.510 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value true
 16:10:21.510 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 1 (version=3382564799)
 16:10:21.516 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564799,"value":1}}}
 16:10:21.516 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 1 (changed: true)
 16:10:21.516 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564799,"value":1}
 16:10:21.517 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564799,"value":1}}}
 16:10:21.517 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564799,"value":1}
 16:10:21.518 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:21.519 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 1.0
 16:10:21.627 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23583/176008516 type: 0x0/0x10 acked: 51644791
 16:10:22.543 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:10:22.526 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23588 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:22.528 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23588/176008517 type: 0x1/0x5 reqAck size: 66 payload: 15260038d0dd53360115350126000fd89dc9370124020124030824040018240229181815350126000fd89dc937012402012403082404011824020018181824ff0b18
 16:10:22.530 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 2 msgId: 24187/23588/51644792 type: 0x1/0x1 acked: 176008517 reqAck size: 8 payload: 1524000024ff0c18
 16:10:22.531 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 41 (version=3382564879)
 16:10:22.536 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 41 (changed: true)
 16:10:22.537 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564879,"value":41}
 16:10:22.538 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564879,"value":41}}}
 16:10:22.538 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564879,"value":41}}}
 16:10:22.539 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 0 (version=3382564879)
 16:10:22.539 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564879,"value":41}
 16:10:22.540 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:22.541 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 41.0
 16:10:22.581 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23588/176008518 type: 0x0/0x10 acked: 51644792
 16:10:28.355 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Nanoleaf_Cono_1_Power' received command OFF
 16:10:28.356 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Nanoleaf_Cono_1_Power' predicted to become ON
 16:10:28.538 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:10:28.364 [DEBUG] [ontroller.devices.types.LightingType] - Handling command for channel: matter:node:012d8d3e09:9976085064129733980:1#colorcontrol-color
 16:10:28.366 [DEBUG] [al.controller.MatterControllerClient] - sendMessage: {"id":"7f50a2c9-54f9-49f4-bdea-582c2011aa81","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","off",{}]}
 16:10:28.371 [TRACE] [MatterWebsocketService] - Controller: Received request: {"id":"7f50a2c9-54f9-49f4-bdea-582c2011aa81","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","off",{}]}
 16:10:28.372 [TRACE] [MatterWebsocketService] - ClientController: Executing function clusters.command(["9976085064129733980",1,"OnOff","off",{}])
 16:10:28.373 [TRACE] [MatterWebsocketService] - Clusters: command 9976085064129733980 1 OnOff off {}
 16:10:28.375 [TRACE] [MatterWebsocketService] - InteractionClient: Invoking command: 0x1/OnOff(0x6)/off(0x0) with "undefined"
 16:10:28.376 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 42583 sess: secure/24187 peerSess: 59083 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:28.378 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/InvokeRequest msgId: 59083/42583/51644793 type: 0x1/0x8 reqAck size: 29 payload: 1528002801360215370024000124010624020018350118181824ff0c18
 16:10:28.479 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/InvokeResponse msgId: 24187/42583/176008519 type: 0x1/0x9 acked: 51644793 reqAck size: 33 payload: 152800360115350137002400012401062402001835012400001818181824ff0b18
 16:10:28.481 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: SC/StandaloneAck msgId: 59083/42583/51644794 type: 0x0/0x10 acked: 176008519
 16:10:28.484 [TRACE] [MatterWebsocketService] - matter: Sending response: {"type":"response","message":{"type":"resultSuccess","id":"7f50a2c9-54f9-49f4-bdea-582c2011aa81","result":"undefined","error":"undefined"}}
 16:10:28.485 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"response","message":{"type":"resultSuccess","id":"7f50a2c9-54f9-49f4-bdea-582c2011aa81","result":"undefined","error":"undefined"}}
 16:10:28.487 [DEBUG] [al.controller.MatterControllerClient] - result type: resultSuccess
 16:10:28.513 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23589 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:28.515 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23589/176008520 type: 0x1/0x5 reqAck size: 66 payload: 15260038d0dd533601153501260011d89dc93701240201240308240400182402281818153501260011d89dc937012402012403082404011824020118181824ff0b18
 16:10:28.518 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 2 msgId: 24187/23589/51644795 type: 0x1/0x1 acked: 176008520 reqAck size: 8 payload: 1524000024ff0c18
 16:10:28.520 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 40 (version=3382564881)
 16:10:28.525 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 40 (changed: true)
 16:10:28.526 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564881,"value":40}
 16:10:28.527 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564881,"value":40}}}
 16:10:28.528 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 1 (version=3382564881)
 16:10:28.529 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564881,"value":40}}}
 16:10:28.531 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564881,"value":40}
 16:10:28.532 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:28.532 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.1 to 1 (changed: true)
 16:10:28.532 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 40.0
 16:10:28.533 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564881,"value":1}
 16:10:28.533 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564881,"value":1}}}
 16:10:28.534 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564881,"value":1}}}
 16:10:28.536 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564881,"value":1}
 16:10:28.538 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:28.539 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: remainingTime with value 1.0
 16:10:28.539 [DEBUG] [.controller.devices.types.DeviceType] - onEvent: No converter found for cluster: 8
 16:10:28.722 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23589/176008521 type: 0x0/0x10 acked: 51644795
 16:10:29.677 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to OFF
 16:10:29.677 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Nanoleaf_Cono_1_Power' changed from ON to OFF
 16:10:29.690 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:10:29.694 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Nanoleaf_Cono_1_Power' changed from OFF to ON
 16:10:29.578 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23595 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:10:29.579 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23595/176008522 type: 0x1/0x5 reqAck size: 1157 payload: 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
 16:10:29.582 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 moreChunkedMessages attr: 39 msgId: 24187/23595/51644796 type: 0x1/0x1 acked: 176008522 reqAck size: 8 payload: 1524000024ff0c18
 16:10:29.663 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23595/176008523 type: 0x1/0x5 acked: 51644796 reqAck size: 205 payload: 15260038d0dd5336011535012600d6c15d883701240201250300032504fdff1824020618181535012600d6c15d883701240201250300032504f8ff1836021818181535012600d6c15d883701240201250300032504f9ff1836020400040104020403040404050406040704080409040a0447044b044c1818181535012600d6c15d883701240201250300032504fbff1836020400040104020403040404070408040f0410050140050a40050b40050c40050d4005104005f8ff05f9ff05fbff05fcff05fdff1818181824ff0b18
 16:10:29.665 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 4 msgId: 24187/23595/51644797 type: 0x1/0x1 acked: 176008523 reqAck size: 8 payload: 1524000024ff0c18
 16:10:29.668 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = false (version=237028778)
 16:10:29.671 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to false (changed: true)
 16:10:29.672 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028778,"value":false}
 16:10:29.672 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028778,"value":false}}}
 16:10:29.672 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028778,"value":false}}}
 16:10:29.673 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/globalSceneControl(0x4000) = true (version=237028778)
 16:10:29.673 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028778,"value":false}
 16:10:29.674 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onTime(0x4001) = 0 (version=237028778)
 16:10:29.674 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:29.674 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value false
 16:10:29.674 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/offWaitTime(0x4002) = 0 (version=237028778)
 16:10:29.675 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/startUpOnOff(0x4003) = 1 (version=237028778)
 16:10:29.679 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/featureMap(0xfffc) = {"lighting":true,"deadFrontBehavior":false,"offOnly":false} (version=237028778)
 16:10:29.680 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/clusterRevision(0xfffd) = 4 (version=237028778)
 16:10:29.680 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/generatedCommandList(0xfff8) = [] (version=237028778)
 16:10:29.681 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/acceptedCommandList(0xfff9) = [0,1,2,64,65,66] (version=237028778)
 16:10:29.681 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/attributeList(0xfffb) = [0,16384,16385,16386,16387,65528,65529,65531,65532,65533] (version=237028778)
 16:10:29.681 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 41 (version=3382564961)
 16:10:29.684 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 41 (changed: true)
 16:10:29.685 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564961,"value":41}
 16:10:29.685 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564961,"value":41}}}
 16:10:29.685 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564961,"value":41}}}
 16:10:29.686 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564961,"value":41}
 16:10:29.687 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 0 (version=3382564961)
 16:10:29.687 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:29.688 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 41.0
 16:10:29.689 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.1 to 0 (changed: true)
 16:10:29.691 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564961,"value":0}
 16:10:29.692 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564961,"value":0}}}
 16:10:29.692 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564961,"value":0}}}
 16:10:29.693 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/minLevel(0x2) = 1 (version=3382564961)
 16:10:29.693 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564961,"value":0}
 16:10:29.694 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/maxLevel(0x3) = 254 (version=3382564961)
 16:10:29.694 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:10:29.695 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: remainingTime with value 0.0
 16:10:29.695 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/options(0xf) = {"executeIfOff":false,"coupleColorTempToLevel":false} (version=3382564961)
 16:10:29.695 [DEBUG] [.controller.devices.types.DeviceType] - onEvent: No converter found for cluster: 8
 16:10:29.695 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onOffTransitionTime(0x10) = 1 (version=3382564961)
 16:10:29.696 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onLevel(0x11) = 41 (version=3382564961)
 16:10:29.697 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/startUpCurrentLevel(0x4000) = 254 (version=3382564961)
 16:10:29.697 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/featureMap(0xfffc) = {"onOff":true,"lighting":true,"frequency":false} (version=3382564961)
 16:10:29.698 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/clusterRevision(0xfffd) = 5 (version=3382564961)
 16:10:29.698 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/generatedCommandList(0xfff8) = [] (version=3382564961)
 16:10:29.699 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7] (version=3382564961)
 16:10:29.700 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/attributeList(0xfffb) = [0,1,2,3,15,16,17,16384,65528,65529,65531,65532,65533] (version=3382564961)
 16:10:29.700 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentHue(0x0) = 27 (version=2287845846)
 16:10:29.701 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentSaturation(0x1) = 213 (version=2287845846)
 16:10:29.701 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/remainingTime(0x2) = 0 (version=2287845846)
 16:10:29.702 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentX(0x3) = 0 (version=2287845846)
 16:10:29.703 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentY(0x4) = 0 (version=2287845846)
 16:10:29.703 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTemperatureMireds(0x7) = 413 (version=2287845846)
 16:10:29.703 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorMode(0x8) = 0 (version=2287845846)
 16:10:29.704 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/options(0xf) = {"executeIfOff":false} (version=2287845846)
 16:10:29.705 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/numberOfPrimaries(0x10) = null (version=2287845846)
 16:10:29.705 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/enhancedColorMode(0x4001) = 0 (version=2287845846)
 16:10:29.706 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorCapabilities(0x400a) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845846)
 16:10:29.707 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMinMireds(0x400b) = 153 (version=2287845846)
 16:10:29.707 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMaxMireds(0x400c) = 470 (version=2287845846)
 16:10:29.707 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/coupleColorTempToLevelMinMireds(0x400d) = 0 (version=2287845846)
 16:10:29.708 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/startUpColorTemperatureMireds(0x4010) = 413 (version=2287845846)
 16:10:29.708 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/featureMap(0xfffc) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845846)
 16:10:29.708 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/clusterRevision(0xfffd) = 6 (version=2287845846)
 16:10:29.709 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/generatedCommandList(0xfff8) = [] (version=2287845846)
 16:10:29.709 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7,8,9,10,71,75,76] (version=2287845846)
 16:10:29.709 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/attributeList(0xfffb) = [0,1,2,3,4,7,8,15,16,16385,16394,16395,16396,16397,16400,65528,65529,65531,65532,65533] (version=2287845846)
 16:10:29.709 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23595/176008524 type: 0x0/0x10 acked: 51644797
Item Nanoleaf_Cono_1_Power is currently ON
Thing (and channel) says NOT YET READY but receives data when I press the power button on the device
→ Switching ON at the device (note that no item event is received)
 16:18:58.747 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23653 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:18:58.748 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23653/176008553 type: 0x1/0x5 reqAck size: 203 payload: 15260038d0dd5336011535012600b0c5200e3701240201240306240400182902181815350126006dd89dc9370124020124030824040018240229181815350126006dd89dc937012402012403082404111824022918181535012600eec15d88370124020125030003240407182502720118181535012600eec15d883701240201250300032404081824020218181535012600eec15d88370124020125030003250401401824020218181535012600eec15d8837012402012503000325041040182502720118181824ff0b18
 16:18:58.749 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 7 msgId: 24187/23653/51644815 type: 0x1/0x1 acked: 176008553 reqAck size: 8 payload: 1524000024ff0c18
 16:18:58.751 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = true (version=237028784)
 16:18:58.755 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to true (changed: true)
 16:18:58.758 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028784,"value":true}
 16:18:58.759 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028784,"value":true}}}
 16:18:58.759 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028784,"value":true}}}
 16:18:58.761 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028784,"value":true}
 16:18:58.762 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 41 (version=3382564973)
 16:18:58.763 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:18:58.764 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value true
 16:18:58.769 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 41 (changed: true)
 16:18:58.770 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564973,"value":41}
 16:18:58.770 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564973,"value":41}}}
 16:18:58.770 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564973,"value":41}}}
 16:18:58.771 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564973,"value":41}
 16:18:58.772 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onLevel(0x11) = 41 (version=3382564973)
 16:18:58.773 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTemperatureMireds(0x7) = 370 (version=2287845870)
 16:18:58.773 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorMode(0x8) = 2 (version=2287845870)
 16:18:58.774 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/enhancedColorMode(0x4001) = 2 (version=2287845870)
 16:18:58.774 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/startUpColorTemperatureMireds(0x4010) = 370 (version=2287845870)
 16:18:58.775 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:18:58.775 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 41.0
 16:18:58.831 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23653/176008554 type: 0x0/0x10 acked: 51644815
→ Switching OFF at the device (note that no item event is received)
 16:19:31.948 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23658 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:19:31.949 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23658/176008555 type: 0x1/0x5 reqAck size: 203 payload: 15260038d0dd5336011535012600b1c5200e3701240201240306240400182802181815350126006fd89dc9370124020124030824040018240201181815350126006fd89dc937012402012403082404111824022918181535012600f2c15d88370124020125030003240407182502720118181535012600f2c15d883701240201250300032404081824020218181535012600f2c15d88370124020125030003250401401824020218181535012600f2c15d8837012402012503000325041040182502720118181824ff0b18
 16:19:31.952 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 7 msgId: 24187/23658/51644816 type: 0x1/0x1 acked: 176008555 reqAck size: 8 payload: 1524000024ff0c18
 16:19:31.953 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = false (version=237028785)
 16:19:31.957 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to false (changed: true)
 16:19:31.958 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028785,"value":false}
 16:19:31.959 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028785,"value":false}}}
 16:19:31.960 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028785,"value":false}
 16:19:31.960 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028785,"value":false}}}
 16:19:31.961 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:19:31.961 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 1 (version=3382564975)
 16:19:31.962 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value false
 16:19:31.965 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 1 (changed: true)
 16:19:31.966 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564975,"value":1}
 16:19:31.970 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564975,"value":1}}}
 16:19:31.971 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564975,"value":1}}}
 16:19:31.973 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564975,"value":1}
 16:19:31.973 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onLevel(0x11) = 41 (version=3382564975)
 16:19:31.974 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:19:31.974 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTemperatureMireds(0x7) = 370 (version=2287845874)
 16:19:31.975 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 1.0
 16:19:31.975 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorMode(0x8) = 2 (version=2287845874)
 16:19:31.975 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/enhancedColorMode(0x4001) = 2 (version=2287845874)
 16:19:31.976 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/startUpColorTemperatureMireds(0x4010) = 370 (version=2287845874)
 16:19:32.047 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23658/176008556 type: 0x0/0x10 acked: 51644816
Light is ON, Item is ON, trying to switch it OFF via Item
 16:25:19.083 [DEBUG] [ontroller.devices.types.LightingType] - Handling command for channel: matter:node:012d8d3e09:9976085064129733980:1#colorcontrol-color
 16:25:19.084 [DEBUG] [al.controller.MatterControllerClient] - sendMessage: {"id":"3298deaa-bbb5-4a57-b202-06a04ff10868","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","off",{}]}
 16:25:19.088 [TRACE] [MatterWebsocketService] - Controller: Received request: {"id":"3298deaa-bbb5-4a57-b202-06a04ff10868","namespace":"clusters","function":"command","args":["9976085064129733980",1,"OnOff","off",{}]}
 16:25:19.089 [TRACE] [MatterWebsocketService] - ClientController: Executing function clusters.command(["9976085064129733980",1,"OnOff","off",{}])
 16:25:19.089 [TRACE] [MatterWebsocketService] - Clusters: command 9976085064129733980 1 OnOff off {}
 16:25:19.090 [TRACE] [MatterWebsocketService] - InteractionClient: Invoking command: 0x1/OnOff(0x6)/off(0x0) with "undefined"
 16:25:19.090 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 42586 sess: secure/24187 peerSess: 59083 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:25:19.092 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/InvokeRequest msgId: 59083/42586/51644824 type: 0x1/0x8 reqAck size: 29 payload: 1528002801360215370024000124010624020018350118181824ff0c18
 16:25:19.236 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/InvokeResponse msgId: 24187/42586/176008571 type: 0x1/0x9 acked: 51644824 reqAck size: 33 payload: 152800360115350137002400012401062402001835012400001818181824ff0b18
 16:25:19.237 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: SC/StandaloneAck msgId: 59083/42586/51644825 type: 0x0/0x10 acked: 176008571
 16:25:19.238 [TRACE] [MatterWebsocketService] - matter: Sending response: {"type":"response","message":{"type":"resultSuccess","id":"3298deaa-bbb5-4a57-b202-06a04ff10868","result":"undefined","error":"undefined"}}
 16:25:19.238 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"response","message":{"type":"resultSuccess","id":"3298deaa-bbb5-4a57-b202-06a04ff10868","result":"undefined","error":"undefined"}}
 16:25:19.240 [DEBUG] [al.controller.MatterControllerClient] - result type: resultSuccess
 16:25:19.341 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:25:19.341 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'GF_IndirectLights' updated to OFF through Nanoleaf_Cono_1_Power
 16:25:19.342 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through GF_IndirectLights
 16:25:19.343 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'WZLichter' updated to ON through Nanoleaf_Cono_1_Power
 16:25:19.344 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through WZLichter
 16:25:19.344 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
 16:25:19.329 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23694 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:25:19.330 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23694/176008572 type: 0x1/0x5 reqAck size: 66 payload: 15260038d0dd533601153501260073d89dc93701240201240308240400182402281818153501260073d89dc937012402012403082404011824020118181824ff0b18
 16:25:19.331 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 2 msgId: 24187/23694/51644826 type: 0x1/0x1 acked: 176008572 reqAck size: 8 payload: 1524000024ff0c18
 16:25:19.332 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 40 (version=3382564979)
 16:25:19.334 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 40 (changed: true)
 16:25:19.335 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564979,"value":40}
 16:25:19.335 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564979,"value":40}}}
 16:25:19.336 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564979,"value":40}}}
 16:25:19.337 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 1 (version=3382564979)
 16:25:19.337 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382564979,"value":40}
 16:25:19.337 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:25:19.338 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 40.0
 16:25:19.339 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.1 to 1 (changed: true)
 16:25:19.341 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564979,"value":1}
 16:25:19.341 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564979,"value":1}}}
 16:25:19.343 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564979,"value":1}
 16:25:19.344 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382564979,"value":1}}}
 16:25:19.344 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:25:19.344 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: remainingTime with value 1.0
 16:25:19.345 [DEBUG] [.controller.devices.types.DeviceType] - onEvent: No converter found for cluster: 8
 16:25:19.429 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23694/176008573 type: 0x0/0x10 acked: 51644826
 16:25:20.458 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'batteryEX' updated to 41
 16:25:20.463 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Phones' updated to OFF through batteryEX
 16:25:20.464 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'locationEX' updated to 50.1022448,8.4038648
 16:25:20.466 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'locationEX' changed from 50.1022486,8.4038657 to 50.1022448,8.4038648
 16:25:20.469 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'lastSeenEX' updated to T16:25:16.000+0100
 16:25:20.472 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'lastSeenEX' changed from T16:24:13.000+0100 to T16:25:16.000+0100
 16:25:20.473 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'accuracyEX' updated to 11 m
 16:25:20.474 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'distanceHomeEx' updated to 0.0037839827105507428
 16:25:20.475 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'distanceHomeEx' changed from 0.0033946682910995277 to 0.0037839827105507428
 16:25:20.476 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'distanceSystemEx' updated to 0.006544216990865893
 16:25:20.477 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'distanceSystemEx' changed from 0.006971889057533712 to 0.006544216990865893
 16:25:20.492 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to OFF
 16:25:20.496 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Nanoleaf_Cono_1_Power' changed from ON to OFF
 16:25:20.497 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'WZLichter' updated to ON through Nanoleaf_Cono_1_Power
 16:25:20.497 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'GF_IndirectLights' updated to OFF through Nanoleaf_Cono_1_Power
 16:25:20.498 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through GF_IndirectLights
 16:25:20.498 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
 16:25:20.499 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through WZLichter
 16:25:20.515 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Nanoleaf_Cono_1_Power' updated to ON
 16:25:20.516 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Nanoleaf_Cono_1_Power' changed from OFF to ON
 16:25:20.516 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'GF_IndirectLights' updated to OFF through Nanoleaf_Cono_1_Power
 16:25:20.517 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'WZLichter' updated to ON through Nanoleaf_Cono_1_Power
 16:25:20.517 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through GF_IndirectLights
 16:25:20.518 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through WZLichter
 16:25:20.518 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
 16:25:20.293 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23699 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:25:20.295 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23699/176008574 type: 0x1/0x5 reqAck size: 1157 payload: 15260038d0dd5336011535012600b5c5200e370124020124030624040018280218181535012600b5c5200e37012402012403062504004018290218181535012600b5c5200e3701240201240306250401401824020018181535012600b5c5200e3701240201240306250402401824020018181535012600b5c5200e3701240201240306250403401824020118181535012600b5c5200e37012402012403062504fcff1824020118181535012600b5c5200e37012402012403062504fdff1824020418181535012600b5c5200e37012402012403062504f8ff1836021818181535012600b5c5200e37012402012403062504f9ff1836020400040104020440044104421818181535012600b5c5200e37012402012403062504fbff183602040005004005014005024005034005f8ff05f9ff05fbff05fcff05fdff1818181535012600c3d89dc937012402012403082404001824022918181535012600c3d89dc937012402012403082404011824020018181535012600c3d89dc937012402012403082404021824020118181535012600c3d89dc93701240201240308240403182402fe18181535012600c3d89dc9370124020124030824040f1824020018181535012600c3d89dc937012402012403082404101824020118181535012600c3d89dc937012402012403082404111824022918181535012600c3d89dc9370124020124030825040040182402fe18181535012600c3d89dc937012402012403082504fcff1824020318181535012600c3d89dc937012402012403082504fdff1824020518181535012600c3d89dc937012402012403082504f8ff1836021818181535012600c3d89dc937012402012403082504f9ff183602040004010402040304040405040604071818181535012600c3d89dc937012402012403082504fbff1836020400040104020403040f0410041105004005f8ff05f9ff05fbff05fcff05fdff1818181535012600fac15d883701240201250300032404001824021b18181535012600fac15d88370124020125030003240401182402d518181535012600fac15d883701240201250300032404021824020018181535012600fac15d883701240201250300032404031824020018181535012600fac15d883701240201250300032404041824020018181535012600fac15d88370124020125030003240407182502720118181535012600fac15d883701240201250300032404081824020218181535012600fac15d8837012402012503000324040f1824020018181535012600fac15d8837012402012503000324041018340218181535012600fac15d88370124020125030003250401401824020218181535012600fac15d8837012402012503000325040a401824021918181535012600fac15d8837012402012503000325040b401824029918181535012600fac15d8837012402012503000325040c40182502d60118181535012600fac15d8837012402012503000325040d401824020018181535012600fac15d8837012402012503000325041040182502720118181535012600fac15d883701240201250300032504fcff18240219181818290324ff0b18
 16:25:20.302 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 moreChunkedMessages attr: 39 msgId: 24187/23699/51644827 type: 0x1/0x1 acked: 176008574 reqAck size: 8 payload: 1524000024ff0c18
 16:25:20.448 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23699/176008575 type: 0x1/0x5 acked: 51644827 reqAck size: 205 payload: 15260038d0dd5336011535012600fac15d883701240201250300032504fdff1824020618181535012600fac15d883701240201250300032504f8ff1836021818181535012600fac15d883701240201250300032504f9ff1836020400040104020403040404050406040704080409040a0447044b044c1818181535012600fac15d883701240201250300032504fbff1836020400040104020403040404070408040f0410050140050a40050b40050c40050d4005104005f8ff05f9ff05fbff05fcff05fdff1818181824ff0b18
 16:25:20.460 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 4 msgId: 24187/23699/51644828 type: 0x1/0x1 acked: 176008575 reqAck size: 8 payload: 1524000024ff0c18
 16:25:20.468 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = false (version=237028789)
 16:25:20.476 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to false (changed: true)
 16:25:20.480 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028789,"value":false}
 16:25:20.481 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028789,"value":false}}}
 16:25:20.483 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028789,"value":false}}}
 16:25:20.484 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028789,"value":false}
 16:25:20.484 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:25:20.485 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/globalSceneControl(0x4000) = true (version=237028789)
 16:25:20.485 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value false
 16:25:20.486 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onTime(0x4001) = 0 (version=237028789)
 16:25:20.487 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/offWaitTime(0x4002) = 0 (version=237028789)
 16:25:20.490 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/startUpOnOff(0x4003) = 1 (version=237028789)
 16:25:20.492 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/featureMap(0xfffc) = {"lighting":true,"deadFrontBehavior":false,"offOnly":false} (version=237028789)
 16:25:20.493 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/clusterRevision(0xfffd) = 4 (version=237028789)
 16:25:20.493 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/generatedCommandList(0xfff8) = [] (version=237028789)
 16:25:20.495 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/acceptedCommandList(0xfff9) = [0,1,2,64,65,66] (version=237028789)
 16:25:20.495 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/attributeList(0xfffb) = [0,16384,16385,16386,16387,65528,65529,65531,65532,65533] (version=237028789)
 16:25:20.496 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 41 (version=3382565059)
 16:25:20.501 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 41 (changed: true)
 16:25:20.502 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565059,"value":41}
 16:25:20.503 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565059,"value":41}}}
 16:25:20.503 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565059,"value":41}}}
 16:25:20.504 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 0 (version=3382565059)
 16:25:20.504 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565059,"value":41}
 16:25:20.506 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:25:20.507 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 41.0
 16:25:20.508 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.1 to 0 (changed: true)
 16:25:20.510 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565059,"value":0}
 16:25:20.511 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565059,"value":0}}}
 16:25:20.511 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565059,"value":0}}}
 16:25:20.512 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565059,"value":0}
 16:25:20.512 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:25:20.513 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: remainingTime with value 0.0
 16:25:20.513 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/minLevel(0x2) = 1 (version=3382565059)
 16:25:20.513 [DEBUG] [.controller.devices.types.DeviceType] - onEvent: No converter found for cluster: 8
 16:25:20.514 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/maxLevel(0x3) = 254 (version=3382565059)
 16:25:20.517 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/options(0xf) = {"executeIfOff":false,"coupleColorTempToLevel":false} (version=3382565059)
 16:25:20.518 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onOffTransitionTime(0x10) = 1 (version=3382565059)
 16:25:20.518 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onLevel(0x11) = 41 (version=3382565059)
 16:25:20.519 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/startUpCurrentLevel(0x4000) = 254 (version=3382565059)
 16:25:20.520 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/featureMap(0xfffc) = {"onOff":true,"lighting":true,"frequency":false} (version=3382565059)
 16:25:20.520 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/clusterRevision(0xfffd) = 5 (version=3382565059)
 16:25:20.521 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/generatedCommandList(0xfff8) = [] (version=3382565059)
 16:25:20.521 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7] (version=3382565059)
 16:25:20.522 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/attributeList(0xfffb) = [0,1,2,3,15,16,17,16384,65528,65529,65531,65532,65533] (version=3382565059)
 16:25:20.522 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentHue(0x0) = 27 (version=2287845882)
 16:25:20.523 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentSaturation(0x1) = 213 (version=2287845882)
 16:25:20.523 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/remainingTime(0x2) = 0 (version=2287845882)
 16:25:20.524 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentX(0x3) = 0 (version=2287845882)
 16:25:20.525 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentY(0x4) = 0 (version=2287845882)
 16:25:20.525 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTemperatureMireds(0x7) = 370 (version=2287845882)
 16:25:20.526 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorMode(0x8) = 2 (version=2287845882)
 16:25:20.526 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/options(0xf) = {"executeIfOff":false} (version=2287845882)
 16:25:20.527 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/numberOfPrimaries(0x10) = null (version=2287845882)
 16:25:20.527 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/enhancedColorMode(0x4001) = 2 (version=2287845882)
 16:25:20.527 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorCapabilities(0x400a) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845882)
 16:25:20.527 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMinMireds(0x400b) = 153 (version=2287845882)
 16:25:20.528 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMaxMireds(0x400c) = 470 (version=2287845882)
 16:25:20.528 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/coupleColorTempToLevelMinMireds(0x400d) = 0 (version=2287845882)
 16:25:20.528 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/startUpColorTemperatureMireds(0x4010) = 370 (version=2287845882)
 16:25:20.529 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/featureMap(0xfffc) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845882)
 16:25:20.529 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/clusterRevision(0xfffd) = 6 (version=2287845882)
 16:25:20.529 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/generatedCommandList(0xfff8) = [] (version=2287845882)
 16:25:20.529 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7,8,9,10,71,75,76] (version=2287845882)
 16:25:20.530 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/attributeList(0xfffb) = [0,1,2,3,4,7,8,15,16,16385,16394,16395,16396,16397,16400,65528,65529,65531,65532,65533] (version=2287845882)
 16:25:20.533 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23699/176008576 type: 0x0/0x10 acked: 51644828
 16:25:36.460 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:89d0:396b:b951:506f:5540 on session secure/24188 protocol: 1 exId: 12866 sess: secure/24188 peerSess: 24188 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:25:36.460 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24188/12866/183250069 type: 0x1/0x5 reqAck size: 11 payload: 152600eb96257f24ff0b18
 16:25:36.461 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 2133169899 empty msgId: 24188/12866/107775239 type: 0x1/0x1 acked: 183250069 reqAck size: 8 payload: 1524000024ff0c18
 16:25:36.502 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24188/12866/183250070 type: 0x0/0x10 acked: 107775239
LIGHT is OFF but Item moves back to ON
Now I cannot switch it ON via the item because Item IS already on.
Stop thing, restart thing, Item goes to OFF
Now (which is in the logs) : switch item ON, light goes ON, switch item OFF, light goes OFF, item goes back ON
this is reproducable
 16:48:33.231 [TRACE] [MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 23854 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
 16:48:33.232 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23854/176008858 type: 0x1/0x5 reqAck size: 1157 payload: 15260038d0dd5336011535012600c1c5200e370124020124030624040018280218181535012600c1c5200e37012402012403062504004018290218181535012600c1c5200e3701240201240306250401401824020018181535012600c1c5200e3701240201240306250402401824020018181535012600c1c5200e3701240201240306250403401824020118181535012600c1c5200e37012402012403062504fcff1824020118181535012600c1c5200e37012402012403062504fdff1824020418181535012600c1c5200e37012402012403062504f8ff1836021818181535012600c1c5200e37012402012403062504f9ff1836020400040104020440044104421818181535012600c1c5200e37012402012403062504fbff183602040005004005014005024005034005f8ff05f9ff05fbff05fcff05fdff181818153501260009da9dc93701240201240308240400182402291818153501260009da9dc93701240201240308240401182402001818153501260009da9dc93701240201240308240402182402011818153501260009da9dc93701240201240308240403182402fe1818153501260009da9dc9370124020124030824040f182402001818153501260009da9dc93701240201240308240410182402011818153501260009da9dc93701240201240308240411182402291818153501260009da9dc9370124020124030825040040182402fe1818153501260009da9dc937012402012403082504fcff182402031818153501260009da9dc937012402012403082504fdff182402051818153501260009da9dc937012402012403082504f8ff183602181818153501260009da9dc937012402012403082504f9ff18360204000401040204030404040504060407181818153501260009da9dc937012402012403082504fbff1836020400040104020403040f0410041105004005f8ff05f9ff05fbff05fcff05fdff181818153501260002c25d883701240201250300032404001824021b1818153501260002c25d88370124020125030003240401182402d51818153501260002c25d88370124020125030003240402182402001818153501260002c25d88370124020125030003240403182402001818153501260002c25d88370124020125030003240404182402001818153501260002c25d8837012402012503000324040718250272011818153501260002c25d88370124020125030003240408182402021818153501260002c25d8837012402012503000324040f182402001818153501260002c25d883701240201250300032404101834021818153501260002c25d8837012402012503000325040140182402021818153501260002c25d8837012402012503000325040a40182402191818153501260002c25d8837012402012503000325040b40182402991818153501260002c25d8837012402012503000325040c40182502d6011818153501260002c25d8837012402012503000325040d40182402001818153501260002c25d883701240201250300032504104018250272011818153501260002c25d883701240201250300032504fcff18240219181818290324ff0b18
 16:48:33.237 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 moreChunkedMessages attr: 39 msgId: 24187/23854/51645297 type: 0x1/0x1 acked: 176008858 reqAck size: 8 payload: 1524000024ff0c18
 16:48:33.291 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/23854/176008859 type: 0x1/0x5 acked: 51645297 reqAck size: 205 payload: 15260038d0dd533601153501260002c25d883701240201250300032504fdff182402061818153501260002c25d883701240201250300032504f8ff183602181818153501260002c25d883701240201250300032504f9ff1836020400040104020403040404050406040704080409040a0447044b044c181818153501260002c25d883701240201250300032504fbff1836020400040104020403040404070408040f0410050140050a40050b40050c40050d4005104005f8ff05f9ff05fbff05fcff05fdff1818181824ff0b18
 16:48:33.292 [TRACE] [MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 attr: 4 msgId: 24187/23854/51645298 type: 0x1/0x1 acked: 176008859 reqAck size: 8 payload: 1524000024ff0c18
 16:48:33.294 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onOff(0x0) = false (version=237028801)
 16:48:33.296 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.OnOff.0 to false (changed: true)
 16:48:33.297 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028801,"value":false}
 16:48:33.297 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028801,"value":false}}}
 16:48:33.297 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028801,"value":false}}}
 16:48:33.298 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":6,"attributeId":0,"attributeName":"onOff"},"version":237028801,"value":false}
 16:48:33.299 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/globalSceneControl(0x4000) = true (version=237028801)
 16:48:33.299 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:48:33.299 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/onTime(0x4001) = 0 (version=237028801)
 16:48:33.299 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: onOff with value false
 16:48:33.299 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/offWaitTime(0x4002) = 0 (version=237028801)
 16:48:33.300 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/startUpOnOff(0x4003) = 1 (version=237028801)
 16:48:33.301 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/featureMap(0xfffc) = {"lighting":true,"deadFrontBehavior":false,"offOnly":false} (version=237028801)
 16:48:33.304 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/clusterRevision(0xfffd) = 4 (version=237028801)
 16:48:33.304 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/generatedCommandList(0xfff8) = [] (version=237028801)
 16:48:33.305 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/acceptedCommandList(0xfff9) = [0,1,2,64,65,66] (version=237028801)
 16:48:33.305 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/OnOff(0x6)/attributeList(0xfffb) = [0,16384,16385,16386,16387,65528,65529,65531,65532,65533] (version=237028801)
 16:48:33.306 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/currentLevel(0x0) = 41 (version=3382565385)
 16:48:33.307 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.0 to 41 (changed: true)
 16:48:33.308 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565385,"value":41}
 16:48:33.308 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565385,"value":41}}}
 16:48:33.308 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565385,"value":41}}}
 16:48:33.309 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":0,"attributeName":"currentLevel"},"version":3382565385,"value":41}
 16:48:33.309 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/remainingTime(0x1) = 0 (version=3382565385)
 16:48:33.310 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:48:33.310 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: currentLevel with value 41.0
 16:48:33.312 [TRACE] [MatterWebsocketService] - PairedNode: Node 9976085064129733980 Trigger attribute update for 1.LevelControl.1 to 0 (changed: true)
 16:48:33.314 [TRACE] [MatterWebsocketService] - ClientController: attributeChangedCallback 9976085064129733980 {"path":{"nodeId":"undefined","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565385,"value":0}
 16:48:33.315 [TRACE] [MatterWebsocketService] - matter: Sending event: {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565385,"value":0}}}
 16:48:33.315 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"event","message":{"type":"attributeChanged","data":{"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565385,"value":0}}}
 16:48:33.316 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/minLevel(0x2) = 1 (version=3382565385)
 16:48:33.316 [DEBUG] [al.controller.MatterControllerClient] - attributeChanged message {"path":{"nodeId":"9976085064129733980","endpointId":1,"clusterId":8,"attributeId":1,"attributeName":"remainingTime"},"version":3382565385,"value":0}
 16:48:33.317 [DEBUG] [.matter.internal.handler.NodeHandler] - AttributeChangedMessage for endpoint 1
 16:48:33.317 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/maxLevel(0x3) = 254 (version=3382565385)
 16:48:33.317 [DEBUG] [ontroller.devices.types.LightingType] - OnEvent: remainingTime with value 0.0
 16:48:33.317 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/options(0xf) = {"executeIfOff":false,"coupleColorTempToLevel":false} (version=3382565385)
 16:48:33.317 [DEBUG] [.controller.devices.types.DeviceType] - onEvent: No converter found for cluster: 8
 16:48:33.318 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onOffTransitionTime(0x10) = 1 (version=3382565385)
 16:48:33.318 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/onLevel(0x11) = 41 (version=3382565385)
 16:48:33.319 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/startUpCurrentLevel(0x4000) = 254 (version=3382565385)
 16:48:33.320 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/featureMap(0xfffc) = {"onOff":true,"lighting":true,"frequency":false} (version=3382565385)
 16:48:33.320 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/clusterRevision(0xfffd) = 5 (version=3382565385)
 16:48:33.321 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/generatedCommandList(0xfff8) = [] (version=3382565385)
 16:48:33.321 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7] (version=3382565385)
 16:48:33.322 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/LevelControl(0x8)/attributeList(0xfffb) = [0,1,2,3,15,16,17,16384,65528,65529,65531,65532,65533] (version=3382565385)
 16:48:33.322 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentHue(0x0) = 27 (version=2287845890)
 16:48:33.323 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentSaturation(0x1) = 213 (version=2287845890)
 16:48:33.323 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/remainingTime(0x2) = 0 (version=2287845890)
 16:48:33.324 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentX(0x3) = 0 (version=2287845890)
 16:48:33.324 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/currentY(0x4) = 0 (version=2287845890)
 16:48:33.324 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTemperatureMireds(0x7) = 370 (version=2287845890)
 16:48:33.324 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorMode(0x8) = 2 (version=2287845890)
 16:48:33.325 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/options(0xf) = {"executeIfOff":false} (version=2287845890)
 16:48:33.325 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/numberOfPrimaries(0x10) = null (version=2287845890)
 16:48:33.325 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/enhancedColorMode(0x4001) = 2 (version=2287845890)
 16:48:33.326 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorCapabilities(0x400a) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845890)
 16:48:33.326 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMinMireds(0x400b) = 153 (version=2287845890)
 16:48:33.326 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/colorTempPhysicalMaxMireds(0x400c) = 470 (version=2287845890)
 16:48:33.326 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/coupleColorTempToLevelMinMireds(0x400d) = 0 (version=2287845890)
 16:48:33.327 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/startUpColorTemperatureMireds(0x4010) = 370 (version=2287845890)
 16:48:33.327 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/featureMap(0xfffc) = {"hueSaturation":true,"enhancedHue":false,"colorLoop":false,"xy":true,"colorTemperature":true} (version=2287845890)
 16:48:33.327 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/clusterRevision(0xfffd) = 6 (version=2287845890)
 16:48:33.328 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/generatedCommandList(0xfff8) = [] (version=2287845890)
 16:48:33.328 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/acceptedCommandList(0xfff9) = [0,1,2,3,4,5,6,7,8,9,10,71,75,76] (version=2287845890)
 16:48:33.328 [TRACE] [MatterWebsocketService] - InteractionClient: Received attribute update: 0x1/ColorControl(0x300)/attributeList(0xfffb) = [0,1,2,3,4,7,8,15,16,16385,16394,16395,16396,16397,16400,65528,65529,65531,65532,65533] (version=2287845890)
 16:48:33.329 [TRACE] [MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/23854/176008860 type: 0x0/0x10 acked: 51645298
 16:48:34.042 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'SZNanoCanvas54B2_Effect' updated to Falling Whites
 16:48:34.043 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'SZNanoCanvas54B2_Power' updated to OFF
 16:48:34.044 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'SZNanoCanvas54B2_Color' updated to 0,0,0
 16:48:34.044 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterSZ' updated to OFF through SZNanoCanvas54B2_Power
 16:48:34.044 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterOG' updated to OFF through LichterSZ
 16:48:34.044 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterOG
So before we try debugging anything else, lets first focus on this issue of it not being online as that could be the root of the other issues. I would need to see the logs as this thing is initialized, it would probably be best to restart the controller thing so we can see this come up the first time. We can troubleshoot the other issues if they are still present once we figure out why this is not online.
What exactly should I do stop / start the thing? This works, as it ONLINE then
stopping
2025-01-18 17:44:39.880 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from ONLINE to UNINITIALIZED
2025-01-18 17:44:39.894 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2025-01-18 17:44:39.948 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Kuche_Eingang_Reihe_links_unten_Schalter_oben' updated to OFF
2025-01-18 17:44:39.948 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterKueche' updated to ON through Kuche_Eingang_Reihe_links_unten_Schalter_oben
2025-01-18 17:44:39.949 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through LichterKueche
2025-01-18 17:44:39.949 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
2025-01-18 17:44:40.019 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Kuche_Eingang_Reihe_links_unten_Schalter_unten' updated to ON
2025-01-18 17:44:40.020 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterKueche' updated to ON through Kuche_Eingang_Reihe_links_unten_Schalter_unten
2025-01-18 17:44:40.020 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through LichterKueche
2025-01-18 17:44:40.025 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
2025-01-18 17:44:40.125 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Kuecheninsel_Brightness' received command ON
2025-01-18 17:44:40.125 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Kueche_Lichtschalter_Kochecke_unten' received command ON
2025-01-18 17:44:40.126 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Kuecheninsel_Brightness' predicted to become ON
2025-01-18 17:44:40.126 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Kueche_Lichtschalter_Kochecke_unten' predicted to become ON
2025-01-18 17:44:40.128 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Kuecheninsel_Brightness' updated to 100
2025-01-18 17:44:40.128 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'Kueche_Lichtschalter_Kochecke_unten' updated to ON
2025-01-18 17:44:40.129 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterKueche' updated to ON through Kueche_Lichtschalter_Kochecke_unten
2025-01-18 17:44:40.129 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Lights' updated to ON through LichterEG
2025-01-18 17:44:40.129 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'LichterEG' updated to ON through LichterKueche
2025-01-18 17:44:39.885 [DEBUG] [r.internal.handler.ControllerHandler] - childHandlerDisposed org.openhab.binding.matter.internal.handler.NodeHandler@9d064ac
2025-01-18 17:44:39.886 [DEBUG] [r.internal.handler.ControllerHandler] - removing node 9976085064129733980
2025-01-18 17:44:39.891 [DEBUG] [r.internal.actions.MatterNodeActions] - bundle org.openhab.binding.matter:4.3.0.202501161730 (375)[org.openhab.binding.matter.internal.actions.MatterNodeActions(530)] : ServiceFactory.ungetService()
2025-01-18 17:44:39.892 [DEBUG] [r.internal.actions.MatterNodeActions] - bundle org.openhab.binding.matter:4.3.0.202501161730 (375)[org.openhab.binding.matter.internal.actions.MatterNodeActions(530)] : DependencyManager: osgi.ds.satisfying.condition close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@51e6215b at tracking count 1 refpairs: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2025-01-18 17:44:40.020 [TRACE] [dule.handler.ItemStateTriggerHandler] - Received Event: Source: null Topic: openhab/items/Kuche_Eingang_Reihe_links_unten_Schalter_unten/stateupdated Type: ItemStateUpdatedEvent  Payload: {"type":"OnOff","value":"ON"}
starting
see attached file
starting.log (248.7 KB)
So, Stop / Start Thing works.
Should I remove the thing and then readd it and see if it comes online and trace the logs? (there will be a lot other stuff in the log as well, though, I guess)
Now deleting thing
2025-01-18 17:50:22.259 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:e21e:aac5:f718:c150:5540 on session secure/24187 protocol: 1 exId: 24192 sess: secure/24187 peerSess: 24187 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
2025-01-18 17:50:22.260 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24187/24192/176009334 type: 0x1/0x5 reqAck size: 11 payload: 15260038d0dd5324ff0b18
2025-01-18 17:50:22.262 [TRACE] [ternal.client.MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 1407045688 empty msgId: 24187/24192/51646025 type: 0x1/0x1 acked: 176009334 reqAck size: 8 payload: 1524000024ff0c18
2025-01-18 17:50:22.365 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24187/24192/176009335 type: 0x0/0x10 acked: 51646025
2025-01-18 17:50:25.409 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from ONLINE to REMOVING
2025-01-18 17:50:25.411 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from REMOVING to REMOVED
2025-01-18 17:50:25.418 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from REMOVED to UNINITIALIZED
2025-01-18 17:50:25.433 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'matter:node:012d8d3e09:9976085064129733980' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2025-01-18 17:50:25.409 [DEBUG] [r.internal.handler.ControllerHandler] - removing node 9976085064129733980
2025-01-18 17:50:25.423 [DEBUG] [r.internal.handler.ControllerHandler] - childHandlerDisposed org.openhab.binding.matter.internal.handler.NodeHandler@560fdb7c
2025-01-18 17:50:25.424 [DEBUG] [r.internal.handler.ControllerHandler] - removing node 9976085064129733980
2025-01-18 17:50:25.431 [DEBUG] [r.internal.actions.MatterNodeActions] - bundle org.openhab.binding.matter:4.3.0.202501161730 (375)[org.openhab.binding.matter.internal.actions.MatterNodeActions(530)] : ServiceFactory.ungetService()
2025-01-18 17:50:25.432 [DEBUG] [r.internal.actions.MatterNodeActions] - bundle org.openhab.binding.matter:4.3.0.202501161730 (375)[org.openhab.binding.matter.internal.actions.MatterNodeActions(530)] : DependencyManager: osgi.ds.satisfying.condition close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@2d7bbd1c at tracking count 1 refpairs: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2025-01-18 17:50:36.360 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fd92:7e17:aa04:1:89d0:396b:b951:506f:5540 on session secure/24188 protocol: 1 exId: 13328 sess: secure/24188 peerSess: 24188 SAT: 4000 SAI: 800 SII: 800 maxTrans: 5 MRP
2025-01-18 17:50:36.361 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: Message « for: I/ReportData msgId: 24188/13328/183250261 type: 0x1/0x5 reqAck size: 11 payload: 152600eb96257f24ff0b18
2025-01-18 17:50:36.362 [TRACE] [ternal.client.MatterWebsocketService] - ExchangeManager: Message » for: I/StatusResponse status: Success(0x0) subId: 2133169899 empty msgId: 24188/13328/107775335 type: 0x1/0x1 acked: 183250261 reqAck size: 8 payload: 1524000024ff0c18
2025-01-18 17:50:36.419 [TRACE] [ternal.client.MatterWebsocketService] - MessageExchange: Message « for: SC/StandaloneAck msgId: 24188/13328/183250262 type: 0x0/0x10 acked: 107775335
Readding thing by scanning it
scanning.log (464.6 KB)
and adding
adding.log (244.2 KB)
and it is directly ONLINE ::frowning: !!! This did not work several times … now it does… :frowning:
So, no NOT_YET_READY is currently not an issue but the above ON/OFF-Issue remains the same.
I think i see the issue, the device sends a current level (brightness) message with a positive value, although the device is off (those are not coupled most of the time in matter), we handle this in other places, but i was missing an OnOff check in one in the ColorControl.currentLevel logic. I’ll push an update shortly.
@stefan.hoehn i have uploaded a new jar if you want to give it a shot. I’m writing unit tests right now for the converters, this is a good one to add.
Ok, running now
376 │ Active │ 80 │ 4.3.0.202501181747 │ openHAB Add-ons :: Bundles :: Matter Binding
and voila! heureka :smiley: it works - good job :sign_of_the_horns:t2:
for the record - the logs for on and off:
on-off-success.log (33.6 KB)
Thanks, Dan :folded_hands:t2:
Great, glad to hear, thanks for the help.
Hi Dan,
thanks for developing this binding and for your efforts. Great work!
I’m using this binding with an Eve Thermo thread device connected to a SmartThings TV hub and an Apple TV, both acting as border routers within the same thread network and wanted to share my matter experiences so far.
  • At First I had some trouble pairing other controllers because I wasn’t aware that this device only supports a maximum of five paired controllers. SmartThings, Apple Home and openHAB still let you create a new pairing code but a new commissioning fails silently then. Only Alexa made it clear that no new controller can be connected anymore and therefore didn’t generate a pairing code.
  • Several times the pairing process with openHAB got stuck right after reconnect (step 14.1) although the device was pingable from the openHAB host in the meantime. This problem seems to be fixed with the latest matter.js upgrade.
  • The only missing channels I see from other controllers are the battery channel and I think some vendor specific clusters which can only be seen in the Eve app.
  • Another problem I have is that the Apple TV assigns a 2a11 address to the thread device if it’s the main border router – especially after reboot of the Apple TV or IPv6 prefix change (checked the address with mdns discovery). OpenHAB then isn’t able to connect to the thermostat although I can ping it successfully from the openHAB host. The correct IPv6 route advertisement is also shown in terminal. Other controllers like Alexa, … don’t have any problems with this address at all. Below I added a log file from discovery with this address. Sometimes the Apple TV assigns a fd95 address to the thermostat and then everything works perfectly with openHAB. Is there a way to prevent the Apple TV from assigning 2a11 addresses as it is also really annoying that these change two times a day? With SmartThings TV hub as the main border router I don’t have this problem.
    matterAppleTVDiscoveryLogfile.txt (26.6 KB)
I also tested the matter bridge of this binding with Apple Home, Alexa and SmartThings and it worked perfectly.
Hardware and Virtualization info: x86_64 host, no docker (only used for some other programms)
Operating System and Versions: Debian 12 (Bookworm)
Network configurations: no Vlan, connected with ethernet
openHAB version: 4.3.2 matter binding: 4.3.0.202501161730
Confirm you have read the Matter README thoroughly: Yes
Is this an issue with the controller or bridge feature?: Controller
Thanks for sharing your experiences so far
Could you PM me the JSON blob of this device when it is initialized ? You can pause/unpause the thing in openHAB to trigger this. We do have battery support, so i’m not sure why thats not showing up (could be a different cluster then what’s supported right now)
Thats interesting, so you can ping the actual ipv6 2a11 address from openHAB ? Did you have to specify an interface when pinging, or were you able to ping with
> ping6 2a11:fb80:2ba:97fc:97e:d6b6:6565:ce36 ?
I’m not sure why that would work, but we are not able to send/receive matter packets to it. I have not tried my apple tv yet as a thread router, i’ll see if i can duplicate that.
Good to know, i’ll have to look into if thats something thats advertised by the device or not.
Fyi i have a new jar posted with a few fixes to the electrical energy cluster and a few small fixes that surfaced from unit tests
I sent a PM to you with the JSON data.
Yes I can successfully ping the actual ipv6 2a11 address of the device directly from the openHAB host machine in the terminal. This works without specifying the interface when pinging just with the command:
> ping 2a11:fb80:2ba:97fc:97e:d6b6:6565:ce36
Thank you for sending that, unfortunately there is not a battery cluster (or any power cluster) advertised by this device. There is one vendor specific cluster, at first glance its not clear what this is, maybe its battery/power related?
Since moving to 4.3.2, the occupancy sensors on my Big Ass Fans have stopped responding. I haven’t taken any steps to fix (could be isolated to me), just wondering if there are any steps I should take related to the binding.
