I got a new Wiz Smart Plug. My idea is, to not use the Wiz App to connect the plug, but using openhab MATTER HUB instead. I hope that my idea is a supported scenario.
My openhab is deployed as Docker container on RASPI4 with HOST network.
IPv6 is activated and verified using
ping -6 google.com(on HOST)
and
ping6 google.com (in DOCKER)
But as soon as I try to pair the plug with the given Matter ID it is not recognized by the binding.
2026-03-28 19:41:49.276 [DEBUG] [al.controller.MatterControllerClient] - sendMessage: {"id":"52476fb9-48c6-4e63-af4e-6427d08d63d1","namespace":"nodes","function":"pairNode","args":["10416514025"]}
2026-03-28 19:41:49.287 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Received request: {"id":"52476fb9-48c6-4e63-af4e-6427d08d63d1","namespace":"nodes","function":"pairNode","args":["10416514025"]}
2026-03-28 19:41:49.289 [TRACE] [ternal.client.MatterWebsocketService] - ClientController: Executing function nodes.pairNode(["10416514025"])
2026-03-28 19:41:49.301 [TRACE] [ternal.client.MatterWebsocketService] - PeerCommissioner: Connecting to device with identifier {"shortDiscriminator":4} and 1 scanners and knownAddress "undefined"
2026-03-28 19:41:49.303 [TRACE] [ternal.client.MatterWebsocketService] - ControllerDiscovery: Start Discovering devices using identifier {"shortDiscriminator":4} ...
2026-03-28 19:41:49.306 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Registered waiter for query _S4._sub._matterc._udp.local with timeout 30 seconds
2026-03-28 19:41:49.308 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Set 2 query records for query _S4._sub._matterc._udp.local: [{"name":"_matterc._udp.local","recordClass":1,"recordType":12},{"name":"_S4._sub._matterc._udp.local","recordClass":1,"recordType":12}]
2026-03-28 19:41:49.313 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Sending 2 query records for 1 queries with 0 known answers. Re-Announce in 1.5 seconds
2026-03-28 19:41:49.317 [TRACE] [ternal.client.MatterWebsocketService] - NodejsChannel: Socket created and bound remoteAddress: undefined:5353 localAddress: 0.0.0.0:5353
2026-03-28 19:41:49.318 [TRACE] [ternal.client.MatterWebsocketService] - NodejsChannel: Socket created and bound remoteAddress: undefined:5353 localAddress: :::5353
2026-03-28 19:41:49.320 [TRACE] [ternal.client.MatterWebsocketService] - NodejsChannel: Initialize multicast address: 192.168.178.51:5353 interface: wlan0 type: udp4
2026-03-28 19:41:49.323 [TRACE] [ternal.client.MatterWebsocketService] - NodejsChannel: Initialize multicast address: ::%wlan0:5353 interface: wlan0 type: udp6
2026-03-28 19:41:50.815 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Sending 2 query records for 1 queries with 0 known answers. Re-Announce in 3 seconds
2026-03-28 19:41:53.817 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Sending 2 query records for 1 queries with 0 known answers. Re-Announce in 6 seconds
2026-03-28 19:41:59.822 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Sending 2 query records for 1 queries with 0 known answers. Re-Announce in 12 seconds
2026-03-28 19:42:11.823 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Sending 2 query records for 1 queries with 0 known answers. Re-Announce in 24 seconds
2026-03-28 19:42:19.310 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Finishing waiter for query _S4._sub._matterc._udp.local, resolving: true
2026-03-28 19:42:19.312 [TRACE] [ternal.client.MatterWebsocketService] - MdnsScanner: Removing last query _S4._sub._matterc._udp.local and stopping announce timer
2026-03-28 19:42:19.316 [TRACE] [ternal.client.MatterWebsocketService] - ControllerDiscovery: Found 0 devices using identifier {"shortDiscriminator":4}
2026-03-28 19:42:19.320 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Error executing function pairNode: No device discovered using identifier {"shortDiscriminator":4}! Please check that the relevant device is online.
2026-03-28 19:42:19.324 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Stack trace: Error: No device discovered using identifier {"shortDiscriminator":4}! Please check that the relevant device is online.
2026-03-28 19:42:19.325 [TRACE] [ternal.client.MatterWebsocketService] - at eval (webpack://matter-server/./node_modules/@matter/protocol/dist/cjs/peer/ControllerDiscovery.js?:56:15)
2026-03-28 19:42:19.326 [TRACE] [ternal.client.MatterWebsocketService] - at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2026-03-28 19:42:19.328 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Error name: Error
2026-03-28 19:42:19.330 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Error id: commissionable-device-discovery-failed
2026-03-28 19:42:19.332 [TRACE] [ternal.client.MatterWebsocketService] - Controller: Full error object: {
2026-03-28 19:42:19.333 [TRACE] [ternal.client.MatterWebsocketService] - "stack": "Error: No device discovered using identifier {\"shortDiscriminator\":4}! Please check that the relevant device is online.\n at eval (webpack://matter-server/./node_modules/@matter/protocol/dist/cjs/peer/ControllerDiscovery.js?:56:15)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)",
2026-03-28 19:42:19.335 [TRACE] [ternal.client.MatterWebsocketService] - "message": "No device discovered using identifier {\"shortDiscriminator\":4}! Please check that the relevant device is online."
2026-03-28 19:42:19.336 [TRACE] [ternal.client.MatterWebsocketService] - }
2026-03-28 19:42:19.338 [TRACE] [ternal.client.MatterWebsocketService] - Controller: --------------------------------
2026-03-28 19:42:19.347 [TRACE] [ternal.client.MatterWebsocketService] - Controller: [commissionable-device-discovery-failed] No device discovered using identifier {"shortDiscriminator":4}! Please check that the relevant device is online.
2026-03-28 19:42:19.349 [TRACE] [ternal.client.MatterWebsocketService] - at eval (webpack://matter-server/./node_modules/@matter/protocol/dist/cjs/peer/ControllerDiscovery.js?:56:15)
2026-03-28 19:42:19.350 [TRACE] [ternal.client.MatterWebsocketService] - matter: Sending response: {"type":"response","message":{"type":"resultError","id":"52476fb9-48c6-4e63-af4e-6427d08d63d1","result":null,"error":"No device discovered using identifier {\"shortDiscriminator\":4}! Please check that the relevant device is online.","errorId":"commissionable-device-discovery-failed"}}
2026-03-28 19:42:19.350 [TRACE] [ternal.client.MatterWebsocketService] - at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2026-03-28 19:42:19.354 [DEBUG] [al.controller.MatterControllerClient] - onWebSocketText {"type":"response","message":{"type":"resultError","id":"52476fb9-48c6-4e63-af4e-6427d08d63d1","result":null,"error":"No device discovered using identifier {\"shortDiscriminator\":4}! Please check that the relevant device is online.","errorId":"commissionable-device-discovery-failed"}}
2026-03-28 19:42:19.362 [DEBUG] [al.controller.MatterControllerClient] - result type: resultError
I kindly ask the community to support me identifying the root cause.
Or just tell me, this is not a supported scenario
Thanks in advance!
