Matter Binding
Hmm, thats not something i have seen before and will need to run by the matter.js devs, but it seems like the Google session has corrupted its ACL and so our bridge thinks its does not have the correct permissions to read attributes.
So it either screwed up ACLs or the resumption record. I saw an issue with resumption record loosing the β€œCAT” once with Alexa and we were also not able to find the reason. That would mainly require logs from before the timepoint where the issue happened. Yes repairing helps
@ Josh_Schachat how long you have logs back in time? :slight_smile:
