I’m using the MAX! system from eQ-3 as a couple of people here do as well.
I came across this tool and thought about sharing this.
@marcel_verpaalen Do you know that already? Most interesting part to me was that the protocol was open sourced (sort of). Maybe there’s something to discover in…
No, did not see this before. It is well described.
The command for the cube are mostly described in https://github.com/Bouni/max-cube-protocol
Though not all commands are there.
There are also few ‘hidden’ features in the current binding, (e.g setting the room id)
but as OH does not lean itself as an admin/config tool (e.g. I would have loved to do the day programming with oh), and the error handling part of it is quite tricky I did not continue on the path
