2b2bff
(Frank Niethardt)
October 10, 2016, 5:01pm
#1
I have a cube and several connected thermostats. Using beta4 nothing will be found by scanning, but I can add the cube manually and it will be shown online. The thermostats weren’t found either. But when I add one of them manually, it will be shown offline all the time.
Any hints for trouble shooting?
hmerk
(Hans-Jörg Merk)
October 10, 2016, 5:05pm
#2
Any Max! related errors or messages in the log ?
2b2bff
(Frank Niethardt)
October 10, 2016, 7:42pm
#3
Seems like my Cube lost all his settings. I wonder when and why, but I barely used it the last couple of months.
As I did all the settings in the original Max App again, now I have all the thermostats in OH, too.
Hi the error was most likely be related to a update in the framework that created some initiation issues.
This should now be fixed. See also
marcel_verpaalen:
It is in now. If you un-install the binding & install again, it should pick up the latest version. (you can check it by typing into the console bundle:list than the current date should be in the max version e.g. somehting like 195 | Active | 80 | 2.0.0.201611281907 | MaxCube Binding where the date should not be before 20161128
