some weeks ago i configured a openhab2 (2.0 beta4) environment with the use of the MAX! binding on a Raspberry Pi. Everything was running fine. Now i have some time to work again on my home automation. But i had to realize that the MAX! binding isn’t working anymore. In the “Things Overview” only the MAX! Cube is marked with “online” but all other “Things” like “Wallmounted Thermostat” or normal “Thermostat” are marked as “UNINITIALIZED - HANDLER_INITIALIZING_ERROR” and i got no values on the channels.
But in the karaf console i got the following messages:
13:25:45.223 [DEBUG] [nternal.handler.MaxCubeBridgeHandler] - Sending request #369 to MAX! Cube
13:25:45.305 [DEBUG] [b.binding.max.internal.device.Device] - Device 0f8034 (Thermostat+): Actual Temperature : 0.0
13:25:45.320 [DEBUG] [b.binding.max.internal.device.Device] - Device 1592a2 (Wallmounted Thermostat): Actual Temperature : 20.9
13:25:45.336 [DEBUG] [b.binding.max.internal.device.Device] - Device 0f7af7 (Thermostat+): Actual Temperature : 0.0
13:25:45.352 [DEBUG] [b.binding.max.internal.device.Device] - Device 0f806b (Thermostat+): Actual Temperature : 0.0
13:25:45.367 [DEBUG] [b.binding.max.internal.device.Device] - Device 11c528 (Thermostat+): Actual Temperature : 0.0
13:25:45.382 [DEBUG] [b.binding.max.internal.device.Device] - Device 11c52b (Thermostat+): Actual Temperature : 0.0
13:25:45.398 [DEBUG] [b.binding.max.internal.device.Device] - Device 0f7b01 (Thermostat+): Actual Temperature : 0.0
13:25:45.413 [DEBUG] [b.binding.max.internal.device.Device] - Device 09af27 (Wallmounted Thermostat): Actual Temperature : 14.8
If i remove all the “Things” and let them discover again, i got the following error message in the log output, if i try add a newly discovered MAX! “Thing”:
10:22:31.943 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'max:wallthermostat:MEQ0375507:NEQ0906289': java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_112]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_112]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[98:org.eclipse.smarthome.core:0.9.0.201610101820]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[98:org.eclipse.smarthome.core:0.9.0.201610101820]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[98:org.eclipse.smarthome.core:0.9.0.201610101820]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:755)[105:org.eclipse.smarthome.core.thing:0.9.0.201610101820]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_112]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_112]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_112]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_112]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
Caused by: java.lang.NoSuchMethodError: org.eclipse.smarthome.core.thing.Bridge.getHandler()Lorg/eclipse/smarthome/core/thing/binding/BridgeHandler;
at org.openhab.binding.max.internal.handler.MaxDevicesHandler.getMaxCubeBridgeHandler(MaxDevicesHandler.java:330)
at org.openhab.binding.max.internal.handler.MaxDevicesHandler.initialize(MaxDevicesHandler.java:117)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:758)
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
... 3 more
I have removed the MAX! binding and performed a new install but the error still exists. Any hint hats wrong with my setup now?
Thanks,
Lars
