Hi all,
Here is the feedback after having done what is explained in this thread during two months.
Result : everything is working perfectly, I didn’t encounter any issue such as lost of configuration… and I can see on my graphs that it’s doing the job !!!
so thank you guys for your help and for the binding !
My wife is very happy because she feels well, so I got +10000 points on the WAF (Wife Acceptance Factor)
@marcel_verpaalen, I have two other suggestions for the binding features, based on the same principle than the one you used for the new channel type… Not sure it is possible, but here are the suggestions :
Feature to request a reboot of the Max Cube, using directly an item (instead of going in PaperUI)
Feature to reset the number of Duty Cycle. Indeed, as I have a lot of radiators (17), I have a lot of limitations concerning the number of commands I can send within one hour. For example, sending a command to all radiators takes around 55% of Duty cycle, so I quickly reach 100% with other rules such as “stop heating if the window is opened”, “relaunch heating if the window is closed”, …
I guess the first suggestion is not too hard to develop, but for the second I’m not sure it will even be possible to develop it if you don’t have any interface available.
If it’s not possible, I would be easy to create a simple rule in order to reboot the cube depending on the level of Duty cycle.
Does it make sense ?
Disagree. There’s usually no need for a reboot and if there really is, it’s an administration task not a user one, so PaperUI clearly is the (only) right place.
Also disagree on the duty cycle. We mustn’t mess with, in the end it’s mandatory by law.
You won’t need to program rules to stop heating if a window is opened, it’s autonomously done if you use MAX! window sensors. And you can tweak the response times etc. so you can reduce the number of messages if you really need to.
OK, you’re right on the fact than the first suggestion is not a user one, so it doesn’t have to be in another place than PaperUI… I totally agree !
Concerning the duty cycle, I don’t understand why you said “it’s mandatory by law”… What is defined in the law ? the number of authorized duty cycle per hour ? or the fact that a number of duty cycles have to be set per hour for ecological reasons ? I totally understand the second one, I’m not saying that’s unnecessary, I’m just saying that the number defined in the Max! cube today doesn’t take into account large houses… I know I have the opportunity to buy a second Max! cube, but is it ecological ?
Concerning your remark saying “You won’t need to program rules to stop heating if a window is opened, it’s autonomously done if you use MAX! window sensors”. It is likely you’re right, but I don’t have these MAX! windows sensors, and I won’t buy any of them as I already have sensors thanks to my alarm system. The purpose of OpenHAB solution is precisely to provide a huge interoperability
I can tell you I already optimized communications between openHab and MAX! cube, in a logical and ecological way, but sometimes I need more percent on the duty cycle. It was the idea of the suggestions.
The restoring of the room info went fine.it has all your rooms back (3 rooms, 7 thermostats). But… unlike @schnibel you only get a single C: line, right? ( this would be the cube itself)
In that case indeed it is more corrupted than only the room info. There is no known way to restore the linking info (that I’m aware of) ones the cube ‘forgets’ it.
Hi @thisisIO, yep… no problem… here is what I have exactly done :
At the present time, everything seems to be OK after a full reset by doing these steps :
Remove all thermostats things using OpenHAB
Stop Max OpenHAB binding using Karaf
Factory Reset of the Max! Gateway
Factory Reset for each Thermostat+
Pair all thermostats (One thermostat per room) using MAX! Software on MacOSX
Remove internet access using MAX! Software on MacOSX
Stop Max! software
Start Max OpenHAB binding using Karaf
Configure Gateway to be in exclusive mode + refresh interval to 30 seconds
Add Thermostats things which have been automatically detected
If you want to ger this problem, set polling to 1-3 sec and non ecxclusive mode. At least it was my situation.
I have Max! system for about 5-6 years, used it always with Max!Remote and original windows software.
I have NEVER had this problem.
But since i started to use OH (2 weeks) i got it!
I set polling to 3 sec because i wanted to use windows sensors as entrance door sensors, but if it will loose settings every time, will go back to 30 sec and exclusive mode, if it helps.
By the way, have you made Backup and Restore feature?
It would be extremeley usefull!
Thanks a lot!
Alex, and no issues till now or not?
Thank u.
And one thermostate in one room?
You have no window sensors at all?
10 rooms (in 8 of them 1 thermostat, each room) in 1 room 3 thermostats, two window contacts and 1 wall thermostat. 1 room with 1 contact only.
Polling intervall: default
This is exact the problem… the device can’t handle that speed and will corrupt at some point.
The original FW also does not request as such a rate. Go to 30 sec and exclusive and you have way less chance that this happens,. (mine never had this corruption since 5y)
I think this is not really usable unless you replace your cube with maxCul type of connection instead of the cube due to its response times.
Hm, so with maxCul i can use smaller polling rate with no problems?
How do you thing in common - is this maxCul better then Cube or it have also another problems?
