2015-10-19 23:57:52.617 [INFO ] [ui.internal.servlet.PaperUIApp] - Started Paper UI at /ui
2015-10-19 23:57:53.121 [INFO ] [.u.d.internal.DashboardService] - Started dashboard at /start
2015-10-19 23:57:53.379 [INFO ] [.o.b.m.internal.MaxCubeBinding] - Discovered MAX!Cube lan gateway at
'192.168.188.222'
2015-10-19 23:57:53.449 [INFO ] [.service.AbstractActiveService] - MAX!Cube Refresh Service has been started
2015-10-19 23:57:53.863 [INFO ] [.o.b.m.internal.MaxCubeBinding] - Error while parsing MAX!Cube message.
Stopping processing, and continue with next Line.
2015-10-19 23:57:54.269 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.271 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.272 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.273 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.274 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.275 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.276 [INFO ] [o.b.m.internal.message.Battery] - Battery charge changed from UNKNOWN to OK
2015-10-19 23:57:54.319 [INFO ] [.s.u.c.i.servlet.WebAppServlet] - Started Classic UI at /classicui
2015-10-19 23:57:54.413 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build alpha2).
2015-10-19 23:58:04.664 [INFO ] [.o.b.m.internal.MaxCubeBinding] - Error while parsing MAX!Cube message. Stopping processing, and continue with next Line.
? Does somebody has any idea?
