Hi, i have the same issue. Can you point me in the right direction ( where I can get this snapshot build) ? Is it a snapshot of the Binding, the addons or OH ?
I am currently on OH 2.4 latest Milestone. Thx
or if youâre on openHABian, itâs a menu option
Sorry, one more question - you mean the Upgrade Option in openhabian-config or you mean switching to OH Snapshot build ?
switching to OH snapshot build
Thank you. I will give it a try.
I ran into another problem with latest snapshot:
On setting target temperatures, debugging shows the binding instructs the cube but it fails to execute.
No error messages for now.
I moved back to 2.3.0 binding and it started working again, so I believe itâs related to the recent connection related changes.
Want me to open an issue ?
I did here but Iâm lacking the logs for now.
Possibly it is as easy to reproduce as to install latest (current) snapshot (#1400) - would you mind to try that yourself ?
Did you try running a recent snapshot such as #1400 or latest #1405 ?
@mstormi I tried to reproduce this on a fresh M5 install.
I installed max binding, accepted the discovered thermostat.
Than set the temperature via paperUI.
Thermostat updated the temperature within seconds.
Hence⊠canât directly reproduce the error in a basic setup.
Not sure if i have the same problem, but Iâm not able to set any temperature for the max thermostats ?
I can switch the modes from manual to automatic or boost. thats working fine. Iâll ger valve and temperature values, but no success with temperatures ?
running
openHAB 2.4.0~20180910180938-1 (Build #1358)
what I tried
max cube as max.thing as well as over Paper UI
uninstall n reinstall the max binding
downgrade to 2.3.0 for the max binding
Log-File
11-Nov-2018 23:04:27.374 [smarthome.event.ItemCommandEvent ] - Item âmaxSetTempWohnzimmer_2â received command 18 °C
11-Nov-2018 23:04:27.375 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - Removed Command id 1 (NEQ0667886-set_temp) from queue. Superceeded by 2
11-Nov-2018 23:04:27.377 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - Command queued id 2 (NEQ0667886-set_temp:18 °C).
11-Nov-2018 23:04:27.381 [smarthome.event.ItemStatePredictedEvent ] - maxSetTempWohnzimmer_2 predicted to become 18 °C
11-Nov-2018 23:05:15.128 [DEBUG] [hab.binding.max.internal.handler.MaxDevicesHandler] - No changes for Thermostat Thermostat 1 (NEQ0667886) id: max:thermostat:Cube:Wohnzimmer_2
e.g. try changing the temp in boost mode, then switchning to manual:
11-Nov-2018 23:10:15.406 [smarthome.event.ItemCommandEvent ] - Item âmaxSetTempWohnzimmer_3â received command 18 °C
11-Nov-2018 23:10:15.412 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - Removed Command id 4 (JEQ0691044-set_temp) from queue. Superceeded by 5
11-Nov-2018 23:10:15.416 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - Command queued id 5 (JEQ0691044-set_temp:18 °C).
11-Nov-2018 23:10:15.424 [smarthome.event.ItemStatePredictedEvent ] - maxSetTempWohnzimmer_3 predicted to become 18 °C
11-Nov-2018 23:10:18.490 [smarthome.event.ItemCommandEvent ] - Item âmaxModeWohnzimmer_3â received command MANUAL
11-Nov-2018 23:10:18.494 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - Command queued id 6 (JEQ0691044-mode:MANUAL).
11-Nov-2018 23:10:18.496 [smarthome.event.ItemStatePredictedEvent ] - maxModeWohnzimmer_3 predicted to become MANUAL
11-Nov-2018 23:10:22.496 [DEBUG] [.binding.max.internal.handler.MaxCubeBridgeHandler] - updates to MANUAL mode with temperature â17.0â
At the end the thermostat will always keep the same temperatureâŠ
Any Ideas ?
thx
This is due to a change wrt to the type of the channel. (normal numbers are ignored it seems, it only takes the new QuantityType )
To fix it, update your binding, delete your thing and add it again.
I tried this already, but I did again, still no change
update max binding
209 â Active â 80 â 2.4.0.201809101528 â org.openhab.binding.max
Delete max.things
and create new
still no way to change temperature neither by paper ui or sitemap
I can change the temperature using the maxcube libary directly in a bash script so it seems to be an openhab issue but I donât have any idea how to find the problem ?
I Stumbled into the same problem.
Everything looks fine but setpoint is not executed by the cube.
Did recognize it todayâŠ
openHAB 2.4.0~M5-1 (Milestone Build)
Hi Michael, Hi Udo,
It seems like both of you are using a milestone or snapshot build. Today the openHAB 2.4.0 M6 milestone has been released. It contains a fix which hopefully solves your issues with the MAX! binding. Is one (or both) of you interested in upgrading and testing?
Yes for sure!
243 â Active â 80 â 2.4.0.M6 â org.openhab.binding.max
And it worked!
After switching to M6 temperatures can be set again
Perfekt! thx
Sounds great. Nice.
Thx!
I was able to uptdate today.
Working again - winter may come
Strange Behaviour: (solved)
Iâve 8 max eq3 thermostats with a max cube and Iâm struggling with a âstrangeâ behaviour
When changing set_temp e.g. of the thermostat in the kids room via paper_ui or sitemap not only the thermostat in the kids room is changing, but also the thermostat of the sleeping roomâŠ
All thermostats are set to manual
changing temp directly on the thermostat works fine
Iâve already
Reset the max cube and connected all thermostats new.
newly installed the binding
deleted my max.thing and max.item
set up new by paper_ui
still the same problem and no idea to find out whats wrong?
there seems to be no wrong link in openhab, all items fit to the correct thermostat
the thermostats in openhab fit to the configuration in the max cube (room/name)
Any ideas to find the root cause ?
After reckeck of the cube settings, i found the structure messed up
So I moved all thermostates to the correct rooms and now it seem to work.
as often, the reason was sitting in front of the screenâŠ
