Hi All,
it seems that i found out a in my opinion quite strange behaviour of the maxcul binding. I use a max cul usb stick with 5 heating radiators and 4 window sensors.
Whenever I want to set a desired temperature for the radiators via openhab, i see the following log file entry:
2018-10-03 09:57:59.575 [ERROR] [ing.maxcul.internal.MaxCulMsgHandler] - Not enough credit after waiting. This is bad. Queued command is discarded
The result is, nothing is changed and the radiators dont receive the desired temperature.
But whenever i set a desired temperature directly at the radiators or whenever i open a window, openhab gets the change and the logfile containts entries…
2018-10-03 09:56:55.743 [vent.ItemStateChangedEvent] - Fenstersensor_Wohnzimmer changed from OPEN to CLOSED
2018-10-03 09:56:39.072 [vent.ItemStateChangedEvent] - Max_Wohnzimmer_Solltemperatur changed from 20 to 20.5
For me, this is quite unlogical, because the information are send oneway, but not bi-directonal.
Any ideas?
