- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: Raspbian GNU/Linux 9 (stretch)
- Java Runtime Environment: which java platform is used and what version
- openHAB version: openhabian 2.5.11-1
- Issue of the topic: When I try to specify more than 6 channels for one topic in the mqtt.things file, mqtt does not return any values - not only for this topic, but for all topics specified in the mqtt.things file. I am using mosquitto.
- Please post configurations (if applicable):
- Items configuration related to the issue
//Martins Tesla RedRacer via Teslalogger mqtt 2.5
Number RedRacer_Restkm “Reichweite RedRacer [%.1f km]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_ideal_battery_range” }
String RedRacer_sleeping “RedRacer schläft [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_sleeping” }
String RedRacer_is_preconditioning “RedRacer heizt vor [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_is_preconditioning” }
String RedRacer_charging “RedRacer lädt [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_charging” }
Number RedRacer_charger_actual_current “RedRacer Ladestrom [%.1f A]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_charger_actual_current” }
Number RedRacer_charger_phases “RedRacer lädt mit [%s Phase(n)]” <poweroutlet_eu> (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_charger_phases” }
Number RedRacer_charge_energy_added “RedRacer Ladung [%.1f kWh]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_charge_energy_added” }
Number RedRacer_SOC “Ladestand RedRacer [%.1f %%]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_battery_level” }
Number RedRacer_km “km Stand RedRacer [%.1f km]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_odometer” }
Number RedRacer_outside_temp “RedRacer Außentemperatur [%.1f °C]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_outside_temp” }
String RedRacer_driving “RedRacer fährt [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_driving” }
Number RedRacer_speed “akt. Tempo RedRacer [%.1f km/h]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_speed” }
String RedRacer_trip_start “RedRacer letzte Fahrt Startzeit [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_start” }
Number RedRacer_trip_distance “RedRacer letzte Fahrt [%.1f km]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_distance” }
Number RedRacer_trip_kwh “RedRacer letzte Fahrt Verbrauch [%.1f kWh]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_kwh” }
Number RedRacer_trip_avg_kwh “RedRacer Trip Durchschnittsverbrauch [%.1f Wh/km]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_avg_kwh” }
Number RedRacer_trip_max_speed “RedRacer Trip Höchstgeschwindigkeit [%.1f km/h]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_max_speed” }
Number RedRacer_trip_max_power “RedRacer Trip max. PS [%.1f PS]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_trip_max_power” }
String RedRacer_firmware “RedRacer Software Stand [%s]” (gTesla1) { channel=“mqtt:topic:mosquitto:RedRacer:RedRacer_car_version” }
- working things configuration related to the issue
// Tesla
Thing topic RedRacer “RedRacer” @ “Carport” {
Channels:
Type number : RedRacer_ideal_battery_range "Reichweite" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.ideal_battery_range_km" ]
Type string : RedRacer_sleeping "RedRacer schlaeft" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.sleeping" ]
Type string : RedRacer_charging "RedRacer laedt" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.charging" ]
Type number : RedRacer_charger_actual_current "RedRacer Ladestrom" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.charger_actual_current"]
Type number : RedRacer_battery_level "Batteriestand" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.battery_level" ]
Type string : RedRacer_is_preconditioning "RedRacer heizt vor" [ stateTopic="tele/RedRacer", transformationPattern="JSONPATH:$.is_preconditioning" ]
- not working things file related to the issue
// Tesla
Channels:
- If logs where generated please post these here using code fences:
So everything is working fine as long as I only specify up to 6 channels for the topic RedRacer.
As soon as I add one ore more addt’l channels, the mqtt.things file stops working.
Sorry for asking, but is there a maximum number of 6 channels per topic in the mqtt.things file? Can this be changed by any parameter? I am not that familiar with the environment…
Many thanks in advance!
