Just posting this as an FYI.
When I included it in my Z-Wave network, it worked fine, initially. After a few hours though, the current temp was not been updated in the Control section of PaperUI.
To be fair, if I changed the setpoint temp in PaperUI then the stat received the change every time but I just found it annoying that the current temp was not getting updated. Only after a restart would it update.
Anyhoo, to cut a long story short, once I went in to HABmin, Configuration, Things. Selected my stat then went to Association Groups and manually set Controller as the Lifeline. Since doing that it’s updating the temp every time it changes, immediately. Working perfectly now.
Only passing it on to the community.
