Hi Again,
after reading the things.xtext-File [0] I finally created this config:
Thing mcp23017:mcp23017:chipA “MCP23017 chip A” [address=20,bus=1] {
Type output : output#B0 [default_state=“HIGH”]
Type input : input#A7 [pull_mode=“PULL_UP”]
but this results in the error-messages below… I have no clue what to do… please help!
Thank you!
Igor
[0] https://github.com/eclipse/smarthome/blob/master/bundles/model/org.eclipse.smarthome.model.thing/src/org/eclipse/smarthome/model/thing/Thing.xtext
2018-05-07 19:02:36.686 [ERROR] [.thing.internal.GenericThingProvider] - Channel type mcp23017:output could not be resolved.
2018-05-07 19:02:36.698 [ERROR] [.thing.internal.GenericThingProvider] - Channel type mcp23017:input could not be resolved.
2018-05-07 19:02:36.890 [hingStatusInfoChangedEvent] - ‘mcp23017:mcp23017:chipA’ changed from UNINITIALIZED to INITIALIZING
2018-05-07 19:02:36.940 [hingStatusInfoChangedEvent] - ‘mcp23017:mcp23017:chipA’ changed from INITIALIZING to ONLINE
2018-05-07 19:02:36.995 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleOutputCommand(Mcp23017Handler.java:100) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.handleCommand(Mcp23017Handler.java:85) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:278) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.channelLinked(Mcp23017Handler.java:206) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-05-07 19:02:37.094 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:545) ~[?:?]
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionPin(GpioControllerImpl.java:538) ~[?:?]
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalInputPin(GpioControllerImpl.java:639) ~[?:?]
at com.pi4j.io.gpio.impl.GpioControllerImpl.provisionDigitalInputPin(GpioControllerImpl.java:667) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.initializeInputPin(Mcp23017Handler.java:167) ~[?:?]
at org.openhab.binding.mcp23017.handler.Mcp23017Handler.channelLinked(Mcp23017Handler.java:202) ~[?:?]
