Anyone got any tips on how to measure sound in decibels? A cheap sensor that is arduino compatible?
lots and lots of sensors available. You just need to google them What truly matters is how you calibrate the levels. You can use them as-is but if you really want accuracy, get a sound level meter so you can adjust (ratio) your code accordingly. As for the sensor, this should get you started
