I tried to install the MELCloud Binding but i couldn’t add Things to the Binding.
I can see the Binding under Configuration - Bindings.
These steps i have done:
Hello Luca
I installed the plugin on openhab to interface and control an ecodan air / water system with mac-567if-e interface
when I do the search it does not find the device
if I add it manually it doesn’t work
Thanks for your help
Ciao Luca
ho installato il plugin su openhab per interfacciare e controllare un sistema aria/acqua ecodan con interfaccia mac-567if-e
quando faccio la ricerca non trova il device
se lo aggiungo manualmente non funziona
grazie per l’aiuto
in previous versions only devices in main building and no area were listed.
I added listing of all devices and this was merged into master and present in release 2.3.
It lists my 3 AC devices just fine so you can give it a try.
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
Hi Vincent,
if you’re not using the 2.5 milestone release you need to install the dependencies manually to run 2.0+ versions.
You can also download an older version and this should work fine on openHAB 2.4.
Good morning all !
I have an ecodan air / water system with PAC-WF010-E interface
I installed thepluginhttps://github.com/lucacalcaterra/org.openhab.binding.melcloud/releases/download/2.1/org.openhab.binding.melcloud-2.5.0-SNAPSHOT.jar
but then when I try to use it, what is it that I can tell me what I do wrong?
2019-10-17 13:23:35.853 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.melcloud.internal.handler.MelCloudDeviceHandler@98065b’: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 3 column 1 path $
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 3 column 1 path $
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:226) ~[254:com.google.gson:2.8.5]
at com.google.gson.Gson.fromJson(Gson.java:927) ~[254:com.google.gson:2.8.5]
at com.google.gson.Gson.fromJson(Gson.java:892) ~[254:com.google.gson:2.8.5]
at com.google.gson.Gson.fromJson(Gson.java:841) ~[254:com.google.gson:2.8.5]
at com.google.gson.Gson.fromJson(Gson.java:813) ~[254:com.google.gson:2.8.5]
at org.openhab.binding.melcloud.internal.api.MelCloudConnection.sendCommand(MelCloudConnection.java:134) ~[?:?]
at org.openhab.binding.melcloud.internal.handler.MelCloudAccountHandler.sendCommand(MelCloudAccountHandler.java:135) ~[?:?]
at org.openhab.binding.melcloud.internal.handler.MelCloudDeviceHandler.handleCommand(MelCloudDeviceHandler.java:191) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy142.handleCommand(Unknown Source) [259:org.openhab.binding.melcloud:2.5.0.201906261023]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 3 column 1 path $
at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:385) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:215) ~[?:?]
... 26 more
glad you managed to get the binding installed.
The current version only supports AC device and treats every device as such.
It tries to control your air / water system with the commands from an AC unit which won’t work.
There are 2 issues open on GitHub for this:
and a version with initial support for your device is linked into one of those issues.
trying the heatpump build, added jar to addons folder, set permissions. It appears in PaperUI, configuration -> Bindings. When attempting to add Thing for Bridge in Paper UI, Inbox -> + -> MelCloud Binding, nothing appears on screen. Similarly, nothing appears in log files.
It connect directly to MELCloud so the interface on the device shouldn’t matter.
At this point only AC devices and heatpumps are supported.
I’m interested why it doesn’t work for you outside EU.
huh… that’s interesting.
Can you check if you already have a “MELCloud account” thing in “Configuration - Things”?
If not, can you set debug level for the binding and check the logs when clicking on Inbox - + - MELCloud Binding?
I would expect to see something useful then.
ok I think I was getting screwed results due to how I was copying the jar in. I needed to chown it outside the addons directory and then move it in there.
Anyhow…
Is it possible to request some more channels for heat pumps as I see all the info in the json returned and shown in karaf debug?
Flow temps for all zones
outdoor temp
zone idle states?
