MELCloud Binding Mitubishi
Ok, what do you expected?
I published this addition for MELCloud binding at the Marketplace. So either install it from the Marketplace like shown in picture or you drop it into addons folder.
It’s not offficial now! Just to be sure: Don’t run both bindings in parallel!
Finally I now have a Mitsubishi split device air conditioner (two devices inside). I managed to setup a MELCloud account and can control my devices over a webbrowser and with the MELCloud app on my mobile.
Now I would like to integrate it in openHAB but i struggle: I installed the MELCloud Binding from marketplace, run the discovery and inserted email and password in the found MELCLoud Account Thing.
But i does not come online, there is a red batch “ERROR.CONFIG” and "CONFIGURATION_ERROR" “Login failed, error code: 1.0”
This is the code shown in the Thing definition:
version: 1
things:
  melcloud:melcloudaccount:1bafb133e6:
    isBridge: true
      username: (MY EMAIL)
      password: (MY PASSW)
      language: "4"
At the beginning I had a passord with quotation marks inside, I changed this but did not help. I also tried to do a textual config, this also did not work. Even a reboot did not help.
Am I doing something wrong?
Let’s find out!
This is curious! The account cannot be found via discovery, it needs to be created manually and after this your attached devices are discovered automatically!
Which of these adresses are you using for web browser login?
Thank you for your help!
Oh, oh, I think with your question you already pointed me to my mistake:
For browser login I use
At the moment I just tried the other address app.melcloud.com but then I recieve “EMail or PW incorrect”.
So I now removed the MELCloud binding, installed the MELCloud-home binding - and tataa, the bridge comes online.
I want to note that again I found the bridge via discovery by binding. After it was online I pressed “Scan” button and my both AC devices where also found and went online!
Thank you again and sorry for the trouble. I saw there are two bindings, don´t know why I selected the wrong.
